OT - Circuit Help (CORRECTION)
Archiver
Oops. I didn't even get the problem right. Sorry.
I need to hold the input to ground and LIFT it at the duty cycle of the
trigger and the max frequency is 1.5 kHz.
Thanks again.
Jeff Abrams
jeff@m...
I bet when the Neanderthal kids would make a snowman, someone
would always end up saying, "Don't forget the thick, heavy brows."
Then they would all get embarrassed because they remembered
they had the big hunky brows too, and they'd get mad and eat the snowman.
From: Jeff Abrams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GmF58bHwSznECffLcCnMU_9oiF0cJHGxOl40dq953BpcAOwLL6nBI-BCOI3MU859-WN9SXIxV2vjjo3a9FU]clavier@b...[/url
Sent: Saturday, January 10, 2004 12:33 PM
To: Basicstamps@Yahoogroups. Com
Subject: [noparse][[/noparse]basicstamps] OT - Circuit Help
I know I've only been good at asking OT electronics help, but you people are
all such a fountain of knowledge it is hard to resist! (°;
Sorry I'm so ignorant.
I need to take a pulse (1ms - 3ms width, 500Hz max, 1.5v to 3v) and use it
to drive an input low (that is held high at 12v) at the same duty cycle with
as little lag as possible.
I would like to do this with as few components as possible (like a single
transistor if possible) as this is an automotive application and needs to be
robust and compact.
Help?
TiA!
Jeff Abrams
jeff@m...
Thanks again.
Jeff Abrams
jeff@m...
robust and compact.
Help?
TiA!
Jeff Abrams
jeff@m...
volt" device held at ground, and visa versa? Is the device a solenoid? Also,
for the 12 volt device that will be held to ground, how much current does it
use?
Ken
In a message dated 1/10/2004 9:43:50 AM Pacific Standard Time,
clavier@b... writes:
Thanks again.
Rather than have the output be a simple "mirror" of the input, is there a
way for the low output to be pulled high on the trailing edge of the input
pulse?
Jeff Abrams
jeff@m...
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iVfQdHFlbhgBdSyfM5dllflrgzbpQ0MKGMhQslaw8z8i6wmVhoYspRcc1s5bObUvosqbojpLL17EauE]smartdim@a...[/url
Sent: Saturday, January 10, 2004 12:49 PM
Subject: Re: [noparse][[/noparse]basicstamps] OT - Circuit Help (CORRECTION)
Is this correct? You have a pulse, when the pulse is low, you want the "12
Also,
use?
Ken
Thanks again.
