connecting serial led display driver
I'm new to Basicstamps and would like to connect a serial led display
B25M04N (Opto Images - Nexus Machines). 4 digits.
The device has a data line and a clock line for data input.
36 bits of data have to be set on the data line.
The clock line expects a frequency of 500 kHz.
Can I use the I2C bus and commands of the basic stamp ? or do I need
another approach.
Eric Messens
another approach.
Eric Messens
>Hi,
>another approach.
>Regards,
>Eric Messens
Eric -
The datasheet for that display makes no claim to be I2C compatible, so I'd just
use the SHIFTOUT directive. Additionally, the 500 KHz speed is a MAXIMUM speed,
and not something I suspect you'll have to worry about.
Bruce Bates
SHIFTOUT is flexible and can deal with the bit positions of the display.
I don't have a display (yet), but think this will work:
Update_BxxMO4:
LOW CE
SHIFTOUT Dpin, Cpin, LSBFIRST, [noparse][[/noparse]1\1, digit0, digit1, digit2, digit3,
annun\3]
HIGH CE
RETURN
'1\1' at the beginning of the stream is the start bit.
The digit segments are mapped like this: Bit0 = A, Bit1 = B, ... Bit7 =
DP. A "1" in any bit position lights the segment.
The variable annun is for the optional annuciators; AN1 = Bit0, AN2 =
Bit1 (Bits 2 and higher are not used, but the Bit2 is expected for 36
total bits).
-- Jon Williams
-- Dallas Office
From: emessens [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RH5LmjxKsArGNeeSPr_TwSQ8H1S0-FfwLKnjftnFqUNvBql4_sTQnvN0fgtIbsbeNi3KwyAyuNk4GrnlODJ998AZqn5NRXM]eric.messens@o...[/url
Sent: Friday, January 09, 2004 4:48 AM
Subject: [noparse][[/noparse]basicstamps] connecting serial led display driver
another approach.
Eric Messens
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
