Security, Basic Stamps and integration of Bluetooth or WiFi — Parallax Forums
edited 2004-01-15 08:36 in General Discussion
One thing I noticed about the Bluetooth eb500 was the complete lack of
security. Anyone can access the basic stamp device. Is anyone out there
paying attention to security issues, i.e. networking, password protecting
devices, encryption etc.
I would be interested in any URLs which deal with these issues in
networking basic stamps.
thanks
joe baptista
Joe Baptista: USG Portal www.joebaptista.com, Personal www.baptista.god
Chief Internet Scientist, / System Administrator to .GOD and .SATAN
TTF-Bucksfan www.gov.ttf / www.nic.god, www.nic.satan or www.dot-god.com
    edited 2004-01-09 04:59
    complete lack of security. Anyone can access the basic
    stamp device. Is anyone out there paying attention to
    issues in networking basic stamps.
    thanks
    joe baptista
    tis true, but this device does only support the simple
    serial protocol. That was the way it was originaly intended
    for the whole device. The original specs for Bluetooth was
    just a simple serial link. Over the years it has evolved
    much farther than anyone has anticipated. Now it does all
    kinds of things. Problem is that many of the embedded
    processors lack the resources to implement security well.
    You can do what normally is done in this case and encrypt
    the datam though with a stamp, you'd be pushing the
    envelope.
    Maybe the next version of the eb500 will address this issue.
    There are other things planned for it, I've talked to the
    developer but not about that. Maybe they can implement the
    matched pair functions. In any case, the security is
    lacking, but the whole Bluetooth spec is still evolving and
    people are scrambling to implement it properly. Hang in
    there. It'll happen and in the meantime, you get to play
    with some of the newset technology out there before everyone
    else does. I've been watching the bluetooth industry now for
    about 3 years. A couple of years ago, I paid $15,000 dollars
    (well you all did) for a pair of developer boards that
    couldn't do much more than the eb500 does now.
    I think the eb500 is a very exciting development, still
    primitive but I believe all of its problems will get worked
    out, it's inevitable they will fix it or someone else will.
    Regards
    Dave Evartt
    American Hovercraft
    edited 2004-01-09 17:22
    Joe,
    I have used the DS1963S SHA iButton for security when using bluetooth from a
    bs2p. This works great. This link has some additional information you may want
    to look at : http://pdfserv.maxim-ic.com/en/an/app150.pdf
    Geoffrey
    Sent: Thursday, January 08, 2004 6:39 PM
    Subject: [noparse][[/noparse]basicstamps] Security, Basic Stamps and integration of Bluetooth or
    WiFi
    thanks
    joe baptista
    from the same email address that you subscribed. Text in the Subject and Body
    Yahoo! Groups Links
    To visit your group on the web, go to:
    http://groups.yahoo.com/group/basicstamps/
    To unsubscribe from this group, send an email to:
    Your use of Yahoo! Groups is subject to:
    edited 2004-01-15 06:58
    Hi Joe,
    The eb500 does actually have two basic security mechanisms, but you
    may not have recognized them as such when reading through the
    manual. The first mechanism controls whether the eb500 is
    discoverable (visible to other Bluetooth radios). The radio can be
    made invisible by sending the following command.
    SET DIS OFF
    If you want to persist this setting simply add an asterisk to the
    end of the command as follows.
    SET DIS OFF *
    This command and its full syntax are discussed further on page 78 of
    the eb500 manual.
    When the eb500 is not discoverable no Bluetooth device will be able
    to see it when looking for other radios. If they knew the specific
    Bluetooth device address of the radio however, they could still
    connect to it.
    A second built in security mechanism allows you to control whether
    the radio will accept or deny new connection requests. This is
    significant in that it gives you control over connections even if
    the remote radio already knows your device address. To make the
    eb500 refuse all connection attempts send the following command.
    SET CON OFF
    end of the command.
    SET CON OFF *
    the eb500 manual.
    This is just the tip of the iceberg where Bluetooth security is
    concerned, but it should provide you with some basic control over
    your radio in unfriendly environments. Higher level security
    functionality is planned for this module such as pairing,
    authentication, and encryption, but unfortunately time did not allow
    these features to be put into version 1.0.
    Let me know if you have any further questions.
    Bryan Hall
    A7 Engineering
    www.a7eng.com
    --- In basicstamps@yahoogroups.com, Joe Baptista <baptista@d...>
    lack of
    out there
    protecting
    > thanks
    > joe baptista
    www.baptista.god
    and .SATAN
    god.com
    edited 2004-01-15 07:52
    Dumb newbie question but what is 'eb500'?
    --- Bryan Hall <bryan@f...> wrote:
    > Hi Joe,
    > mechanisms, but you
    > through the
    > eb500 is
    > The radio can be
    > SET DIS OFF
    > asterisk to the
    > SET DIS OFF *
    > the eb500 manual.
    > device will be able
    > knew the specific
    > could still
    > connect to it.
    > control whether
    > requests. This is
    > connections even if
    > To make the
    > following command.
    > SET CON OFF
    > asterisk to the
    > end of the command.
    > SET CON OFF *
    > the eb500 manual.
    > security is
    > control over
    > security
    > pairing,
    > time did not allow
    > Bryan Hall
    > A7 Engineering
    > www.a7eng.com
    > <baptista@d...>
    > the complete
    > lack of
    > device. Is anyone
    > out there
    > protecting
    > these issues in
    > > thanks
    > > joe baptista
    > Personal
    > www.baptista.god
    > to .GOD
    > and .SATAN
    > god.com
    > Text in the Subject and Body of the message will be
    > ignored.
    > Yahoo! Groups Links
    __________________________________
    Do you Yahoo!?
    Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
    http://hotjobs.sweepstakes.yahoo.com/signingbonus
    Danielle -
    Not so dumb at all. It's a new embedded Bluetooth RF Transceiver Module being
    offered by Parallax: http://www.parallax.com/detail.asp?product_id=30068
    Bruce Bates
