Back when I was in engineering school some 30 years ago, hardness testing
produced a Brinell hardness number, sort of like a seismic scale
reading. This used to be done using a cone or cylinder shaped indenter
applied to the surface to be tested with a specific force via a hydraulic
ram. Then you see how big of a hole you made and came up with the hardness
number. Of course, this is destructive and not very automated. Still, the
idea of poking a surface with a pointer and seeing how far it indents for a
given pressure is the idea. For really hard things you use a diamond point.
See http://www.gordonengland.co.uk/hardness/brinell.htm for a pretty good
link on the specifics.
Reading the pressure with a stamp is easy. Seeing how far it goes in could
be a problem since you have to account for any flex in the system. Measuring
the hole/impression diameter would need a camera of sorts.
I'm just throwing out the basic principals of hardness testing to see if
anyone can tweak my brain on an alternate method. There's got to be a
better, automatable way to do this.
Mike,
I think he meant "harness" tester to pass/fail conductivity
on multiple conductors rather than a 'hardness' tester.
-Beau Schwabe
>Hmmmmmmm......
>Mike Sokol
>www.modernrecording.com
>mikes@m...
>" One should not increase, beyond what is necessary,
>the number of entities required to explain anything"...
>-William of Occam-
>From: "h40miami" <h40miami@y...>
>To: <basicstamps@yahoogroups.com>
>Sent: Thursday, January 08, 2004 2:07 PM
>Subject: [noparse][[/noparse]basicstamps] Harness Tester
> > Hi, Any ane has any idea how can a do a hardness tester using a BS?
> > Thank you,
> > Edson
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
> > Yahoo! Groups Links
> > To visit your group on the web, go to:
> > http://groups.yahoo.com/group/basicstamps/
> > To unsubscribe from this group, send an email to:
> > Your use of Yahoo! Groups is subject to:
> > http://docs.yahoo.com/info/terms/
>Yahoo! Groups Links
Still, I like the idea of a little stamp controlling a big hydraulic press
and smashing up things, don't you????
Sent: Thursday, January 08, 2004 4:18 PM
Subject: Re: [noparse][[/noparse]basicstamps] Harness Tester
> Mike,
> -Beau Schwabe
> >Hmmmmmmm......
hardness
a
point.
could
Measuring
> >Mike Sokol
> >mikes@m...
> >-William of Occam-
> > > Thank you,
> > > Edson
and
> > > Yahoo! Groups Links
> >Yahoo! Groups Links
> Yahoo! Groups Links
Ah... I had an American Saddlebred that often engaged in that activity, but
I wasn't aware it was worthy of a whole category of test instruments.
Mike Sokol
mikes@m...
-William of Occam-
> Thank you,
> Edson
> Yahoo! Groups Links
-Beau Schwabe
>Hmmmmmmm......
>Mike Sokol
>mikes@m...
>-William of Occam-
> > Thank you,
> > Edson
> > Yahoo! Groups Links
>Yahoo! Groups Links
> Mike,
> -Beau Schwabe
> >Hmmmmmmm......
hardness
a
point.
could
Measuring
> >Mike Sokol
> >mikes@m...
> >-William of Occam-
> > > Thank you,
> > > Edson
and
> > > Yahoo! Groups Links
> >Yahoo! Groups Links
> Yahoo! Groups Links
Gary
