Remote Control - Bruce !! - — Parallax Forums
edited 2004-01-07 18:36 in General Discussion
hello bruce,
in 2001, i puchased the rentron 8 bit RF kit (434), since then you have
changed the design of the transmitter and reciever. are they backwards
compatible with my model? If i wanted to add more transmitters, would it
recognize on the receiver? thanks
- Gary D
Kyocera-Wireless
Garyd@k...
At 06:21 AM 1/7/2004 -0700, you wrote:
> >Subject: [noparse][[/noparse]basicstamps] Remote Control
> > I am reasonably new to robotics, electronics, and stuff. I did build
> > one basic robot with a BS2 that worked reasonably well. I am now
> > trying to build a robot with a BS2 that I want to be able to remote
> > control. I initially planned to use the 418 mHz transmitter keychain
> > remote thing but it only has five buttons and I want quite a few
> > more than that. I was wondering if anyone has other suggestions?
>You have quite a few options.
>1. As Jon mentioned, you can press combinations of buttons on the Parallax
> keychain type transmitter.
>2. Construct your own RF transmitter/receiver circuits using the Holtek series
> 8-bit encoder/decoder ICs. You have 8-bits latching + 1 momentary.
>3. Use infrared. Parallax has several app-notes for decoding Sony IR
>transmitters.
>4. Use a dedicated Sony decoder IC.
>We carry the Holtek 4-bit & 8-bit encoder/decoder ICs with several RF
>transmitter
>receiver modules, custom 8-pin (address learning) 4-bit decoder ICs for
>the 4-bit
>encoder series, and two versions of Sony IR decoder ICs.
>Take a peek at our remote control store for many different options.
>http://www.rentron.com/PicBasic/RemoteControl.htm
>Our IR-D15A IC provides 14 "momentary" outputs that remain ON while
>holding the
>transmitter button down, and 1 "latching" output that is toggled ON & OFF when
>depressing and releasing the transmitters power or ON / OFF button.
>Regards,
>-Bruce
>tech@r...
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
    > - Gary D
    > Kyocera-Wireless
    > Garyd@k...
    The receivers are the same. The only change was going from a 6-pin version
    TWS transmitter to a 4-pin version. The receiver you have will work fine with
    the newer 4-pin TWS transmitters. They're the same frequency. Just smaller.
    -Bruce
    tech@r...
