bs1 source code
Hello,
I just recently started working with basic stamps, bs2-home work
board, sumo-bot, and now a bs1-ic. There is plenty of documentation
on the bs2 but I am having trouble finding anything on the bs1. In
particular I am trying to add reverse and turn to my breadbot
constucted from directions in nuts and volts mag by Robert Nansel. I
can get all whiskers to do a reverse but cannot figure out how to add
turn (left or right whiskers) or about face (front bumper). studying
the syntax is not helping I am more of a do type of person. anyway
any help would be appreciated.
thanks Jon
thanks Jon
projects from us -- I've already used the BS1 a couple times in my Nuts
& Volts column, in fact, the February column has to do with a simple
robot core using the BS1 and a Pololu motor controller.
If you do a search on the Net you'll find lots of BS1 code (many of my
old programs are still floating around cyberspace).
As far as your specific question, just keep in mind that turning is
caused by rotating the motors in opposite directions. So, if you can
make your bot go forward and go in reverse, you're almost there. Let's
say you want to process a whisker input by backing up, turning, then
continuing. You process would go something like this:
On whisker input...
* both motors reverse
* pause long enough to back up
* whisker-side motor forward
* pause for turn
* both motors forward
Your actual code will depend on the type of motors you're using, the
inputs and how they operate, etc.
-- Jon Williams
-- Dallas Office
From: peterman921 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zXIsmkKD_InZZLPVUa7qRCQ4jJdeNwIs4a2gWI-mdtGqVQTyNEQ4SFDV9FnXPm3u_krELt_AMQFacA]signjon@e...[/url
Sent: Tuesday, January 06, 2004 10:17 PM
Subject: [noparse][[/noparse]basicstamps] bs1 source code
Hello,
thanks Jon
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
wrote:
> With BS1 support in our latest compiler you'll start seeing more BS1
Nuts
my
can
Let's
> On whisker input...
> * pause for turn
> -- Jon Williams
> -- Dallas Office
so each action has its own line in the code with a short pause
between actions? I was trying basically two then statements after the
if
'straight line drive routine
drive:
IF drive_direction <> fwd THEN drive_reverse
drive_forward:
l_spd = lstop + l_drive_speed
r_spd = rstop - r_drive_speed
GOTO drive_loop
drive_reverse:
l_spd = lstop - l_drive_speed
r_spd = rstop + r_drive_speed
drive_loop:
FOR delta = 0 TO drive_distance
PULSOUT left, l_spd
PULSOUT right, r_spd
PAUSE pauseval
IF fbumper = bump THEN drive_reverse
IF lwhisker = bump THEN drive_reverse
IF rwhisker = bump THEN drive_reverse
NEXT delta
RETURN
thanks for the help
Jon
bit. And before I forget, it's bad practice to GOTO a subroutine (there
is nothing on the GOSUB stack when you hit RETURN and this can lead to
problems). You can construct a rover like this:
Setup:
DIRS = %11000000 ' motors on P7 (L) and
P6 (R)
Main:
PAUSE 20 ' standard servo
refresh delay
bumpers = PINS & %00000011 ' bumpers on P1 (L) and
P0 (R)
BRANCH bumpers, [noparse][[/noparse]Fwd, Go_Left, Go_Right, About_Face]
Fwd:
PULSOUT LMotor, LStop + LDriveSpeed
PULSOUT RMotor, RStop - RDriveSpeed
GOTO Main
Go_Left:
GOTO Main
Go_Right:
GOTO Main
About_Face:
PAUSE 20
' reverse
FOR idx = 1 TO 50 ' adjust for backup
distance
PULSOUT LMotor, LStop - LDriveSpeed
PULSOUT RMotor, RStop + RDriveSpeed
PAUSE 20
NEXT
' spin
FOR idx = 1 TO 100 ' adjust for 180 turn
PAUSE 20
NEXT
GOTO Main
You can use this (with some tweaking) as a starting point for your bot.
-- Jon Williams
-- Dallas Office
From: peterman921 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2cYCEnQpF_raPvUNqtUiDp9lOz0ogqgo-eS3k-J3tSuWCGqlj6p5h2TA0TBCX-skMbpQ5--J7_DG]signjon@e...[/url
Sent: Wednesday, January 07, 2004 11:39 PM
Subject: [noparse][[/noparse]basicstamps] Re: bs1 source code
if
drive:
drive_forward:
GOTO drive_loop
drive_reverse:
drive_loop:
PULSOUT left, l_spd
PAUSE pauseval
NEXT delta
RETURN
thanks for the help
Jon
Yahoo! Groups Links
abuse@p....
