Baud rate conversion
Hi y'all,
I need to convert baud from 300 to 9600 before it goes in to a radio
transmitter (internal converter doesn't quite do the job from 300).
SO, no doubt this is easy enough for the BS2.
3007N1 to 96007N1.
I can use the 220ohm resistor to read in the RS232 data and could use
P16(the DB9 jack w/RS232 levels) to spit it out to the radio.
So, the next step beyond this is to just use a couple of MAX232 chips (or
other brand), but my issue, then, is the buffering. Is there an easy way to
buffer (if the chip doesn't do that for you?).
Also, would anyone know if a PC could pick up (at a short distance <6ft)
rs232 TTL levels out of the BS2?
Sb
3007N1 to 96007N1.
Sb
do 7 data bits, no parity. The only options
it supports are 8 data bits, no parity, or
7 data bits, even parity.
In theory, if your radio is not too fussy,
you could set the BS2 to receive and send
8 data bits, no parity -- then only send
7 N 1 to the stamp. The last data bit will always
be a 1 to the BS2 (as the stop bit is read as a
data bit), but your radio should read the
'set' last bit as the stop bit, and still
be happy.
Really you should then send 7 N 2, so there
would be two stop bits -- one to be the last
data bit, and one to be the 'idle' bit before
the next byte starts.
As to using TTL levels to the PC, it depends
on the PC's 232 port circuit how it would work.
--- In basicstamps@yahoogroups.com, "Brady,Steven [noparse][[/noparse]PYR]"
<steven.brady2@e...> wrote:
> Hi y'all,
> 3007N1 to 96007N1.
use
chips (or
easy way to
<6ft)
> Thanks
> Sb
I thought I had heard someone on here talk about the issues of newer laptops
of the day and with the power constraints, how they've got to a 5V RS232
rather than the 12Vswing.
sb
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jhJPLATCjdIZhawgt0aMooZiAfayLQS_GYGsQUSHAicW-5K15LJ9vB7JU-QuUJ2Sv-TzqyxgzrJI3ou2X1tGzHsP]allan.lane@h...[/url
Sent: January 6, 2004 10:33
Subject: [noparse][[/noparse]basicstamps] Re: Baud rate conversion
Bad news, I'm afraid -- the BS2 does not
be happy.
> Hi y'all,
> 3007N1 to 96007N1.
use
chips (or
easy way to
<6ft)
> Thanks
> Sb
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/
Buffering: How long a message are you wanting
to send? How much time between bytes?
Note the BS2 can only do one thing at a time.
When it is recieving bytes, it can't send them.
It can receive ONE byte, then send ONE byte,
then recieve ONE MORE byte, etc. But if the
BS2 is still sending when you want it to
receive, it will drop the byte you just tried
to send it.
The BS2 has 26 bytes of memory. You can do:
MyBuf VAR BYTE[noparse][[/noparse]26]
I300_7E CON 27889 ' 300 Baud, 7E1, 'inverted'
I9600_7E CON 24660 ' 9600 Baud, 7E1, 'inverted'
MAIN:
SERIN 16, I300_7E, [noparse][[/noparse]STR MyBuf\26\0]
'ie -- Get bytes into MyBuf until 26, or CHR(0)
SEROUT 16, I9600_7E, [noparse][[/noparse]STR MyBuf]
GOTO MAIN
'Note the '16' above indicates the built-in
' serial port. See the manual under 'SERIN' for
' non-inverted values (needed if you're using
' just a 22K ohm resistor to recieve)
Note also the above assumes you're sending
26 bytes or less packets, then it echos the
packet. (You may also want a time-out
parameter in the SERIN)
> My mistake on the baud...it is 300E71.
newer laptops
RS232
> sb
> From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
> be happy.
> > Hi y'all,
radio
300).
> > 3007N1 to 96007N1.
> use
> chips (or
> easy way to
> <6ft)
> > Thanks
> > Sb
Subject and
> Yahoo! Groups Links
This is my message format
(you might remember this from the wind system I was working on some 6months
ago)
STX DDDSSS/dddsss/GGGENN ETX BCC EOT CR LF
STX Star of Text character
DDD 2Minute average direction
SSS 2Minute average speed
Ddd 10Minute average direction
Sss 10Minute average speed
GGG 10Minute maximum 5second scalar speed
ENN Error code (NN for specific error)
ETX End of transmission character
BCC Block Check character
EOT End of Text Character
CR Carriage return
LF Line feed
I can use the STX (02H) with the wait(02H). I'll need all the bits and
doo-dads up to the LF for the display at the other end.
The only buffering I require is for the BS2. It has to wait 'a while' at
300baud for the entire message to come in. As soon as it has a 'GOOD'
message (complete message -- now losing the odd bit) it will then fire out
the string at 9600baud.
So I think that's 36characters in all plus the /'s and that's 38.
Could I just suck in the entire string and then spit it out. Rather than
parsing the string and then glueing it back together for outputting.
All in all....the BS2 is just a 'handler!' Slow up the string and make sure
all the bits are there and then fire it out again.
I'm using this 'very basic' project to get my boss to buy on to stamps.
sb
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0VHbxOnNXAZyPalpZz3s8cjejAuUon5VXTuMFiKoDltlz_2ylJsSXj8E8jPvvOdhEiqU4D89WI7ppybeTBkCj_u4_xCT]allan.lane@h...[/url
Sent: January 6, 2004 10:51
Baudrates: looks like this will work then.
to send it.
MAIN:
GOTO MAIN
newer laptops
RS232
> sb
> be happy.
> > Hi y'all,
radio
300).
> > 3007N1 to 96007N1.
> use
> chips (or
> easy way to
> <6ft)
> > Thanks
> > Sb
Subject and
> Yahoo! Groups Links
Yahoo! Groups Links
