how many LEDs can be run off a battery
Archiver
This is a pretty basic question, but hopefully you will bare with me.
I am wondering how I can figure out how many LEDs I can run off a power source?
I am rusty at this stuff, so the basics of this one are eluding me.
Lets say for example that I have LEDs that are 2 V at 20mA, and a 9V battery.
How many LEDs can I power from this battery? How do you go about figuring this
out?
thank you for you time,
xoxoxoxoxoxoxoxoxoxoxoxoxoxoxoxoxoxoxoxo
.-..-. .-..-. /),/) Ned Schwartz (\,(\ .-..-. .-..-.
"-.-" "-.-" ( ';' ) 760 Irene St. ( ';' ) "-.-" "-.-"
.-..-. .-..-. (o..)o Montreal c(..c) .-..-. .-..-.
"-.-" "-.-" OO Quebec OO "-.-" "-.-"
neddothekiddo@h...
out?
neddothekiddo@h...
neddo@s... writes:
this out?
In a perfect world do the following:
1) See how many LEDs can be connected in series without the sum of each LED
forward voltage exceeding the voltage source.
9 volt battery, LEDs 2 volts each.
You can connect 4 in series which will "use up" 8 volts. This leaves 1 volt
"left over."
2) The left over one volt, and ohms law will be used to calculate what
resistor is needed for the series circuit to have 20 mA.
R = E/I......R = 1/0.02....R = 50 Ohms. That's it!
In reality, the battery voltage will drop. When the battery voltage drops,
the voltage across the 50 ohm current limiting ( or setting ) resistor is
reduced.
If the battery voltage is now 8.5 volts, there is now only 0.5 volts across
the 50 ohm resistor. Now the current in the circuit is set to 0.5 volts / 50
ohms = 10 mA...Leds half as bright.
To lessen the affect of losing LED brightness versus battery voltage
reduction, use only 3 LEDs in series ( 6 volts) and you will start with 2 volts
"left
over."
The resistor value that gives 20 mA with 2 volts is 100 ohms.
Now, when the battery voltage is 8.5 volts, there is now 1.5 volts across the
100 ohm resistor. Now the current in the circuit is set to 1.5 volts / 100
ohms = 15 mA, which will appear brighter than 10 mA.
One last technial point....as the current through the LED changes, so to does
the forward voltage across the LEDs, and this curve is on the LED data sheet.
It is a small factor, but worth mentioning.
> In a message dated 1/4/2004 5:13:05 PM Pacific Standard Time,
> neddo@s... writes:
9V battery.
figuring
> this out?
each LED
leaves 1 volt
> "left over."
what
drops,
resistor is
> reduced.
volts across
volts / 50
voltage
with 2 volts "left
> over."
across the
volts / 100
so to does
data sheet.
I would look at it from the point of view of each LED has one
resistor and the battery is 9 volts. then for really bright LED's
you might use 20mA, or for dim one's, 10mA.
100 LED's at 20mA would be 100 x 20 = 2,000 mA or 2 amps.
Then figure out how many amps the battery is good for before the
voltage drops too low for a useable rating.
If cost were not important, but battery life was, then one could
pulse the LED's to something like a 25% duty cycle and have the LED's
glow, but get almost 4 times the battey life.
Get data on the battery. 9 V alkaline ?
niMH ? NiCad ? The mA/hr ratings will reveal what the total life
would be for the quantity of LED's you might have.
Dave
davemucha@j... writes:
Dave
For a battery operated system, and in such systems low power consumption is
usually desirable. Having only one LED in series with 9 volts is a large waste
of power.
I think I am getting a handle on this now. How about if I wired the LEDs in
parallel? I suppose then I would be up against the total amps of the power
source and how fast I would suck the battery dry? Is this right?
If I were to wire the LEDs parallel, assuming they are the exact same kind
of LEDs, would I be able to get away with just one resistor? Or would they
each need a resistor?
neddothekiddo@h...
Sent: Sunday, January 04, 2004 9:16 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: how many LEDs can be run off a battery
> In a message dated 1/4/2004 6:06:37 PM Pacific Standard Time,
> Dave
is
waste
> of power.
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
Since each LED will have a slightly different reverse bias voltage, each
will require a separate resistor. If not, then some will hog the current,
while other would be not so bright.
If you parallel a bunch of LEDs, you'll be wasting a lot of heat from all
those current limiting resistors, and yes the battery amperage is then the
determining factor....
Mike Sokol
www.modernrecording.com
mikes@m...
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Tuesday, January 06, 2004 4:58 PM
> thank you all for the replies,
in
> neddothekiddo@h...
> From: <smartdim@a...>
> > Dave
> is
> waste
> > of power.
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
