help for power source..thanks
hi guys,
I am currently doing a project which need to use basic stamp to
drive a few servo motors. As I am quite new in this field, I hope
that my enquiries can be answered here.
I am currently working on 4 basic stamp2 SX which need to be
connected by totally 12 servo motors. Since only simply motion is
desired, thus for starting, I will only connect 3 servo motors to
each basic stamp, or may be I may connect 4 servo motors to one
stamp. The question is, is this possible ?
I would like to use 4 AAsize 1.5v battery, can I use only 4 AAsize
1.5v battery to power up 4 basic stamps2SX and 12 servo motors ? Or
is there any other better way to connect it to the power source ?
Other than that, I would like to know do I need to add any resistor
or capacitor or fuse to my circuit to prevent short circuit ? If
yes, what is the exact component I needed ?
It may sound silly to ask all this, but I really need to know as I
am really new and I need a proper guide from someone who is
experienced. I am using FUTABA S3003 servo motor.
Thanks for your patience to spend some time to read on this. Thanks
in advanced. Have a nice day.
Francis
Francis
have three wires to the servo (signal, ground and power). There is no
need to run the power over the stamp. You can get the power directly
from a powersource like a battery. Just don't forget to connect the
ground of the battery to the ground of the oopic.
Peter
--- In basicstamps@yahoogroups.com, "fleis1981" <fleis1981@y...>
wrote:
> hi guys,
> Francis
I don't think 4 AA batteries will not run all that at once. Do all 12 servos
operate at the same time? It will help to put a large cap, say 2200 uF or
greater across the servos. Try it and see is the easist way to find out.
Are you using a servo controller? If the Stamps running the servos need to
do much else, you should loook at the PWMPAL or similar servo controller.
Jonathan
www.madlabs.info
> Francis
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
