Speech using GI SP0256-AL2
I recently got a 'What's a Microcontroller' kit for Christmas and I'm
going to try interfaceing the GI SP0256-AL2 allaphone speech processor
(which I bought a LONG time ago).
I was searching the Nuts and Volts archives and found Column #40
titled 'Talk is Cheap' which interfaces this speech processor with the
BASIC Stamp.
My question - the column uses a 74HC164 serial shift register to
reduce the number of data lines needed to connect the BASIC Stamp from
8 to 4. Since there aren't any local stores to that sell the 74HC164 -
I was wondering if the 74HCT259 (8-bit addressable latch available at
Radio Shack) would be a good substitute. While the 74HCT259 is not a
drop in replacement - it appears that it would work. Unlike a shift
register, the 74HCT259 uses 3 bits to address bits 0 thru 7. Does this
sound workable? Has anyone used the 74HCT259 in their project as a
serial to parallel converter?
BASIC Stamp.
eight IO pins and I wanted to keep some free for other things. Since
you've got a BS2, you can use IO pins directly from the Stamp without
needing a latch. The thing is that you'll need six Stamp pins to deal
with the 74HCT259 -- use these for SP0256 pins A0 - A5 instead (A6 and
A7 should be grounded). And the code will be much simpler.
Writing on the fly...
OUTL = %010000000 | phoneme
PULSOUT ALD, 10
In this (pulling from the seat of my pants example...), P0-P5 connects
to A0-A5, P6 is the ALD (normally high) line, and P7 is the LRQ input.
Have fun.
-- Jon Williams
-- Parallax
From: fab4442003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Vht_Knd-iOpkea1URGKG7OxOPhMEwlhElkJUcmn-hLVjaFLgUuVyH15ti7uI1XiHqYUC43lTsTXHBOw]fab4442003@y...[/url
Sent: Friday, January 02, 2004 12:02 PM
Subject: [noparse][[/noparse]basicstamps] Speech using GI SP0256-AL2
I was searching the Nuts and Volts archives and found Column #40 titled
'Talk is Cheap' which interfaces this speech processor with the BASIC
Stamp.
My question - the column uses a 74HC164 serial shift register to reduce
the number of data lines needed to connect the BASIC Stamp from 8 to 4.
Since there aren't any local stores to that sell the 74HC164 - I was
wondering if the 74HCT259 (8-bit addressable latch available at Radio
Shack) would be a good substitute. While the 74HCT259 is not a drop in
replacement - it appears that it would work. Unlike a shift register,
the 74HCT259 uses 3 bits to address bits 0 thru 7. Does this sound
workable? Has anyone used the 74HCT259 in their project as a serial to
parallel converter?
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
>BASIC Stamp.
Look near the bottom of the following web page, and you can request samples from
Fairchild Semiconductor:
http://www.fairchildsemi.com/pf/MM%2FMM74HC164.html
Many semiconductor manufacturers will gladly send samples, even to hobbiests.
Bruce Bates
- it looks like a simpler circuit which is good for newbies like me.
If that works out OK, I'll add the 8-bit latch and the companion Text
to Allophone processor to the circuit. Do you think the 9-volt battery
attached to the BS2 Homework board will supply enough current at 5V
to drive the Text to Allophone processor, the Allaphone Speech
processor, 74HCT259 chip and a small audio amp based on a LM386? If
not, could you suggest a circuit (possibly from one of your Nuts and
Volts columns) to create another 5 Volt DC source from another 9V battery.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...> wrote:
> I wrote that column (a long time ago...) using a BS1 which only has
> PULSOUT ALD, 10
> Have fun.
> -- Jon Williams
> -- Parallax
> From: fab4442003 [noparse][[/noparse]mailto:fab4442003@y...]
> Stamp.
> parallel converter?
> Yahoo! Groups Links
> abuse@p...
if that's available. www.parallax.com sells the
'HCT164, as does www.digikey.com.
The '259 would not work very well. It only
lets you select one of 8 outputs at a time.
--- In basicstamps@yahoogroups.com, "fab4442003" <fab4442003@y...>
I'm
processor
the
> BASIC Stamp.
from
74HC164 -
at
this
all. Again, I wouldn't bother with the 74HCT259 because it's not saving
you any pins and only complicating your code.
-- Jon Williams
-- Parallax
From: fab4442003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=blJoCrHgjBxfhVFEo53Yd9ezYXiSHpGCJLQibYfvqcCQyLG-RZEAOkWNoPxUniDVJS9JrYTycoQnMg]fab4442003@y...[/url
Sent: Friday, January 02, 2004 4:42 PM
Subject: [noparse][[/noparse]basicstamps] Re: Speech using GI SP0256-AL2
OK, thanks for the info. I'll try the project first without the latch
- it looks like a simpler circuit which is good for newbies like me. If
that works out OK, I'll add the 8-bit latch and the companion Text to
attached to the BS2 Homework board will supply enough current at 5V to
drive the Text to Allophone processor, the Allaphone Speech processor,
74HCT259 chip and a small audio amp based on a LM386? If not, could you
suggest a circuit (possibly from one of your Nuts and Volts columns) to
> PULSOUT ALD, 10
> Have fun.
> -- Jon Williams
> -- Parallax
> BASIC Stamp.
> Radio
> parallel converter?
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
I'm guessing this will output the phoneme on pins0-6. Also, it looks
like there's an extra 0 in there. Wouldn't the command to output the
phoneme be:
OUTL = %01000000 , phoneme
or maybe not. If not, what commands is used to output the data on
pins0-6? These commands are all pretty new to me - the last time I
programmed with BASIC all this stuff was handled with POKE and PEEK.
wrote:
> Your battery won't last very long if you run the LM386 very loudly
at
saving
> -- Jon Williams
> -- Parallax
latch
me. If
to
to
processor,
you
columns) to
has
Since
without
deal
(A6 and
> > PULSOUT ALD, 10
connects
input.
> > Have fun.
> > -- Jon Williams
> > -- Parallax
I'm
processor
with the
> > BASIC Stamp.
from
74HC164 -
available at
> > Radio
drop in
register,
serial to
> > parallel converter?
Subject
> > Yahoo! Groups Links
> > abuse@p...
Subject
> Yahoo! Groups Links
> abuse@p...
OUTL = %01000000 | phoneme
This puts the phoneme on pins 0 - 5 while keeping pin 6 high -- you will
strobe pin 6 low to load the phoneme into the device. Pin 7 is used to
monitor the LRQ line so you know when you can load the next phoneme.
OUTL is direct access to pins 0 - 7 as a byte. You must first set pins
0 - 6 to outputs with:
DIRL = %0111111
We make loads of free information available so there are plenty
resources to learn from -- and don't feel handcuffed by other dialects
of BASIC; microcontrollers are generally less complicated in terms of
architecture, so programming follows suit. You might want to download
our "What's A Microcontroller" text and skim it. Since you have some
programming experience, it will take you less than a day to get the hang
of PBASIC.
The other thing you can do is skim the online help file. It
demonstrates the syntax of all PBASIC instructions with example code.
-- Jon Williams
-- Parallax
From: fab4442003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xzJtlr6n-xzj5gNU4rOLI6g-wvj38r6vo0daNhkcBdgLH2gJSK31nZ29-3vCk0HsdsDgnuSJkNeQnkjf]fab4442003@y...[/url
Sent: Sunday, January 04, 2004 8:56 PM
I don't understand this command:
phoneme be:
at
saving
> -- Jon Williams
> -- Parallax
latch
me. If
to
to
processor,
you
columns) to
has
Since
without
deal
(A6 and
> > PULSOUT ALD, 10
connects
input.
> > Have fun.
> > -- Jon Williams
> > -- Parallax
I'm
processor
with the
> > BASIC Stamp.
from
74HC164 -
available at
> > Radio
drop in
register,
serial to
> > parallel converter?
Subject
> > Yahoo! Groups Links
> > abuse@p...
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
the original BS1/PBasic 2.0(?) program to a BS2/PBasic 2.5 program -
but I finally got it to compile without any syntax errors.
On last question - since the original program was for a BS1 and you
used PULSOUT ALD,10 in the original program. Should the duration for
PULSOUT change since I'm using a BS2? If I'm reading the PBASIC
manual correctly, on a BS1 this will create a 100 microsecond pulse
so I'll need to change the command to PULSOUT ALD,50 to get a 100
microsecond pulse on the BS2. Correct?
wrote:
> Sorry, there is an extra zero. What I meant was:
will
used to
pins
> DIRL = %0111111
dialects
of
download
some
hang
> of PBASIC.
code.
> -- Jon Williams
> -- Parallax
looks
the
> phoneme be:
> at
> saving
> > -- Jon Williams
> > -- Parallax
> latch
> me. If
> to
battery
5V
> to
> processor,
could
> you
> columns) to
<jwilliams@p...>
> has
> Since
> without
to
> deal
> (A6 and
> > > PULSOUT ALD, 10
> connects
> input.
> > > Have fun.
> > > -- Jon Williams
> > > -- Parallax
and
> I'm
> processor
> with the
> > > BASIC Stamp.
Stamp
> from
> 74HC164 -
> available at
> > > Radio
> drop in
> register,
sound
> serial to
> > > parallel converter?
It never hurts to reevaluate technical details. I'm not sure why I
wrote the code the way I did, and being human, I would change it if
rewriting the program today. I found an old spec sheet that says the
ALD pulse can be as short as 200 ns (0.2 microseconds) -- so a PULSOUT
value of 1 on the BS2 is plenty.
-- Jon Williams
-- Dallas Office
From: fab4442003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TrKMPC63r3vQ2yPX8jlmkIid8cyQq8MvLg_Irv7c2Z9JwZE-TIrmyLy0j7z5Gwy8rOeaRbkLsap9UWnzCQ]fab4442003@y...[/url
Sent: Monday, January 05, 2004 12:01 AM
OK, thanks - it makes sense now. It also took me awhile to convert
will
used to
pins
> DIRL = %0111111
dialects
of
download
some
hang
> of PBASIC.
code.
> -- Jon Williams
> -- Parallax
looks
the
> phoneme be:
> at
> saving
> > -- Jon Williams
> > -- Parallax
> latch
> me. If
> to
battery
5V
> to
> processor,
could
> you
> columns) to
<jwilliams@p...>
> has
> Since
> without
to
> deal
> (A6 and
> > > PULSOUT ALD, 10
> connects
> input.
> > > Have fun.
> > > -- Jon Williams
> > > -- Parallax
and
> I'm
> processor
> with the
> > > BASIC Stamp.
Stamp
> from
> 74HC164 -
> available at
> > > Radio
> drop in
> register,
sound
> serial to
> > > parallel converter?
Yahoo! Groups Links
abuse@p....
support the BS2 and the direct speech interface. I'm happy to report my speech
synthesizer is talking just fine!
> That would be correct, but you probably don't need a pulse that long.
> -- Jon Williams
> -- Dallas Office
> will
> used to
> pins
> > DIRL = %0111111
> dialects
> of
> download
> some
> hang
> > of PBASIC.
> code.
> > -- Jon Williams
> > -- Parallax
> looks
> the
> > phoneme be:
> > at
> > saving
> > > -- Jon Williams
> > > -- Parallax
> > latch
> > me. If
> > to
> battery
> 5V
> > to
> > processor,
> could
> > you
> > columns) to
> <jwilliams@p...>
> > has
> > Since
> > without
> to
> > deal
> > (A6 and
> > > > PULSOUT ALD, 10
> > connects
> > input.
> > > > Have fun.
> > > > -- Jon Williams
> > > > -- Parallax
> and
> > I'm
> > processor
> > with the
> > > > BASIC Stamp.
> Stamp
> > from
> > 74HC164 -
> > available at
> > > > Radio
> > drop in
> > register,
> sound
> > serial to
> > > > parallel converter?
-- Jon Williams
-- Parallax
From: fab4442003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fYAfXargzXjAAgJTrKx90U5BL53EFfZo_ShViGLktVbvSq86JcbyzWFBtPJ6RRhepAgsAsPHCOeoZA]fab4442003@y...[/url
Sent: Monday, January 12, 2004 10:30 PM
Just wanted to say thanks for your guidance and updating the Talker
program to
speech
> -- Jon Williams
> -- Dallas Office
> will
> used to
> pins
> > DIRL = %0111111
> dialects
> of
> download
> some
> hang
> > of PBASIC.
> code.
> > -- Jon Williams
> > -- Parallax
> looks
> the
> > phoneme be:
> > at
> > saving
> > > -- Jon Williams
> > > -- Parallax
> > latch
> > me. If
> > to
> battery
> 5V
> > to
> > processor,
> could
> > you
> > columns) to
> <jwilliams@p...>
> > has
> > Since
> > without
> to
> > deal
> > (A6 and
> > > > PULSOUT ALD, 10
> > connects
> > input.
> > > > Have fun.
> > > > -- Jon Williams
> > > > -- Parallax
> and
> > I'm
> > processor
> > with the
> > > > BASIC Stamp.
> Stamp
> > from
> > 74HC164 -
> > available at
> > > > Radio
> > drop in
> > register,
> sound
> > serial to
> > > > parallel converter?
Yahoo! Groups Links
abuse@p....
