need help on power supply Servo Motors
--- In basicstamps@yahoogroups.com, "fleis1981" <fleis1981@y...>
wrote:
> Guys out there, Happy New Year.
> I am currently doing a project which need to use basic stamp to
> drive a few servo motors. As I am quite new in this field, I hope
> that my enquiries can be answered here.
> I am currently working on 4 basic stamp2 SX which need to be
> connected by totally 12 servo motors. Since only simply motion is
> desired, thus for starting, I will only connect 3 servo motors to
> each basic stamp, or may be I may connect 4 servo motors to one
> stamp. The question is, is this possible ?
> I would like to use 4 AAsize 1.5v battery, can I use only 4 AAsize
> 1.5v battery to power up 4 basic stamps2SX and 12 servo motors ? Or
> is there any other better way to connect it to the power source ?
> Other than that, I would like to know do I need to add any resistor
> or capacitor or fuse to my circuit to prevent short circuit ? If
> yes, what is the exact component I needed ?
> It may sound silly to ask all this, but I really need to know as I
> am really new and I need a proper guide from someone who is
> experienced. I am using FUTABA S3003 servo motor.
> Thanks for your patience to spend some time to read on this. Thanks
> in advanced. Have a nice day.
> Francis
Hi Francis,
I think I'm beating Sid to this one. : )
you can drive an 8 pin darlington ULN2803 with the the Stamp pins.
The darlington can handle up to 500mA per channel, but I think only
about 2.5 amps for the total units connected. Please check the data
sheets for verification.
I'm not sure of the battery and voltage. If you are running at 5
volts, it does not seem like you have a lot of use before you drop to
below the 5 volts.
Dave
> Francis
Hi Francis,
below the 5 volts.
Dave
