Programming and Serial Interfacing
I have a BS2 carrier board. I have just realised, it is only really
meant for programming and not serial interfacing with the PC. I
ideally want to use the Sout and Sin pins to communicate with my
program, is there anyway of adapting the board/cable to enable this?
for serial communications on the programming port. The only caveat is
on the other side; the Stamp echoes every character sent to it, so your
other device will need to filter the echo. It's not tough to do, and
many of use have created PC-to-Stamp projects using the normal
programming port.
You can experiment by using the DEBUG terminal in the compiler. You'll
just have to open it manually and set the baud parameter to what your
Stamp is using. The latest compiler lets you disable the on-screen echo
as well.
-- Jon Williams
-- Dallas Office
From: hughgoodbody [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2ni8D-ZSRqogQp6bum6zGApQWL13vQW_wb_oCiIxAKV_w0idMn4_W_7d_irDou2dHg7PY7Y0AX16e_N6DKPHjA]hughgoodbody@y...[/url
Sent: Tuesday, December 30, 2003 2:18 PM
Subject: [noparse][[/noparse]basicstamps] Programming and Serial Interfacing
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Regards
Dave Evartt
American Hovercraft
forever go to the stamp web site and look under rs232 they have some excellent
examples for you if that doest not help email me I remember what it was like
getting started dont give up when your first rs 232 works you will fell like you
have conquered the world.
hughgoodbody <hughgoodbody@y...> wrote:I have a BS2 carrier board. I have
from the same email address that you subscribed. Text in the Subject and Body of
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway - Enter today
specify pin 16 in your SERIN and SEROUT instructions.
-- Jon Williams
-- Dallas Office
From: frog28043 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DS4WXEyvywtnuQ02EMhQDlbqDtTlwsWRVOJapwuiOTborh58Vm9-gUjZwxveDhJtUVMyL-xjDyaKk4JCQTw]frog28043@y...[/url
Sent: Wednesday, April 07, 2004 6:16 PM
Subject: Re: [noparse][[/noparse]basicstamps] Programming and Serial Interfacing
From: Frog28043@y... This is a cakewalk after some research it took
me forever go to the stamp web site and look under rs232 they have some
excellent examples for you if that doest not help email me I remember
what it was like getting started dont give up when your first rs 232
works you will fell like you have conquered the world.
