If then statment checking pin state
Hi All
Been some cool and helpful topics on the board thanks!
I have what is possibly a simple question but not sure of the command for it.
I would like to write a IF THEN statement that relies on if a output pin or
group of output pins are high.
IE not in correct code but idea
CHECK:
IF PIN 3 IS HIGH AND X>5 AND X<8 THEN PROGRAMCONTINUE
GOTO PROGRAM
PROGRAMCONTINE:
XXXXXX
I have no more variables to use in this code as they are all taken up.
I don't want to wait for the pin to go high just check its state and then if it
is high and the other variables are correct go to PROGRAMCONTINUE or other name.
Also I don't want to change the state of the output pin either just check its
state.
Rob
CHECK:
GOTO PROGRAM
PROGRAMCONTINE:
XXXXXX
state.
Rob
The BS2 2.0c PDF has a table on page 49
of the default names of groups of pins.
For your example:
MyPin3 VAR IN3 ' Declare an ALIAS to 'IN3'
' Alias entries take NO internal ram.
DIR3 = 0 ' Insure pin 3 is an Input (0)
MAIN
IF (MyPin3 = 1) AND (X > 5) AND (X < 8) THEN ProgramContinue
GOTO Program
' Note PBasic uses 'left to right' evaluation,
' unless you use the parentheses to force
' the order.
Note also that PBasic 2.5 allows you:
MyPin3 VAR PIN
Then you get more flexibility when using
'MyPin3'. In 2.0, you must declare the
alias as Input only, or Output only.
--- In basicstamps@yahoogroups.com, "Rob Farrand ... FTech
Connection" <ftech@n...> wrote:
> Hi All
command for it.
output pin or group of output pins are high.
> CHECK:
> GOTO PROGRAM
> PROGRAMCONTINE:
> XXXXXX
up.
and then if it is high and the other variables are correct go to
check its state.
> Thanks
> Rob
' {$PBASIC 2.5}
MyPin3 PIN 3
Using this syntax the compiler is able to intelligently determine how to
use the pin, as there are times when we want to use a constant value
(i.e., 3), monitor the input bit (i.e., IN3), or set the output bit
(i.e., OUT3) for a given pin.
Happy New Year!
-- Jon Williams
-- Dallas Office
<snip>
MyPin3 VAR PIN
</snip>
