Are buffers ( CMOS 4050 etc) any use to protect the stamp''s outputs???
Arrhid,
You can simply use resistors to control the current output from the Stamp.
If you need to pull more current then the Stamp can handle, a resistor and a
transistor work well. Another option is to use a chip like the ULN2003.
These chips have a built in current limiting resistor and spike protection
diodes. Further, outputs can be tied in parallel for greater current.
I don't know the chip you mentioned, but I don't think it's intended use is
as a current limiter, but it might work.
Jonathan
www.madlabs.info
Sent: Sunday, December 28, 2003 11:36 PM
Subject: [noparse][[/noparse]basicstamps] Are buffers ( CMOS 4050 etc) any use to protect the
stamp's outputs???
> Hey
> I'm not sure my self if this will work or not so I thought I'd ask
> you guys [noparse]:D[/noparse]. I wanted to protect my stamp outputs from gettin
> damaged by sourcing and sinking too much current so I looked around
> and found the cmos 4050 chip non inverting hex buffer. I was
> wondering if it will protect my stamp from sourcing and sinking a
> lot of current. What I plan to do is to use it as a intermediate
> between my stamp and my output device so as to protect the stamp.
> Would this be a benifitial setup to have and is this the use the
> chip was developed for? Furthermore will it protect my stamp from
> damage in the instance that a large base current was drawn by a
> transistor or similar instance? Any light you guys can shed on the
> subject would be helpful.
> Many thanks
> Arridh
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
Jonathan
www.madlabs.info
stamp's outputs???
> Hey
> Many thanks
> Arridh
> Yahoo! Groups Links
