Stapm
Hi group!
Does anyone have info to make a 40Khz crystal oscillator with NE555 or
with
any other simple IC, the application should still frequency stable even
under low
temperature (-20 C)
with
under low
temperature (-20 C)
components. That said, you'll find a schematic for an IR modulator in
our original BS1 app notes.
-- Jon Williams
-- Parallax
From: Rene Genest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AUcHULIQ3tbOFgosThw1LIsitT5eVsAh1kdaEIGeJDw4C0_FcWyQrkVKNPKgwBWsvANox5__dg0UASKrBAXFPQ]rene.genest@q...[/url
Sent: Monday, December 29, 2003 5:05 AM
To: stamp
Subject: [noparse][[/noparse]basicstamps] Stapm
Hi group!
with any other simple IC, the application should still frequency stable
even under low temperature (-20 C)
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
datasheet say Vcc is 5 volt, you must power it with 7 volt, if you
want it to perform correctly.
I wonder how many young and smart kids quitting this fibulas hobby,
starting with dope, just because this NE555 circuit does not have
the correct info on the datasheet?
I had a little Dos program that I used in the old days, when I
needed to calculate the frequency and resistor. I could not find it
at this moment, but I mail the program to you if I find it later
tonight.
Stein.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> NE555 and "stable" are rarely used in the same sentence due to the
RC
modulator in
> -- Jon Williams
> -- Parallax
> From: Rene Genest [noparse][[/noparse]mailto:rene.genest@q...]
> To: stamp
> Hi group!
NE555 or
stable
> Thanks
Subject
> Yahoo! Groups Links
> abuse@p...
temperature" don't go together too well.
Also, "Stable down to -20 C" and "Simple"
don't go together.
If you must have the temperature range,
the easiest approach would be to purchase
an oscillator module from Digikey.
These are 8, 14, or 16 pin IC cans,
with a built-in accurate oscillator.
And how stable do you want it?
+- 100 Pulses Per Million (PPM) is typical,
+- 10 PPM is available
+- 5 PPM is more pricey.
0 to 70C is typical.
-40C to +85C is the 'extended' temp range
for these beasties. They're a little power
hungry -- 10 to 50 mA I think.
Note if you're using this for IR remote use,
the IR circuits tend to be forgiving in the
range of 35 KHZ to 42 KHZ or so. You may not
need all this accuracy.
--- In basicstamps@yahoogroups.com, Rene Genest <rene.genest@q...>
wrote:
> Hi group!
> with
even
> under low
> temperature (-20 C)
> Thanks
little ovens that were set something above the maximum ambient with their
own thermostat. After a few minutes to warm up, single digit PPM stability
was obtainable.
Mike Sokol
www.modernrecording.com
mikes@m...
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Tuesday, December 30, 2003 10:32 AM
Subject: [noparse][[/noparse]basicstamps] Re: Stapm
> As has been said "555" and "Stable over
> don't go together.
> wrote:
> > Hi group!
> or
> > with
> even
> > under low
> > temperature (-20 C)
> > Thanks
> Yahoo! Groups Links
Finally, I'm using the CD4060 with 40Khz crystal and it work very well even in
sub zero temperature. The application was to supply IR signal to IR detector
PNA4613M which is tuned at 40 Khz. But, the circuitry did not work all the
time with every quartz crystalls, I've found two differents types of quartz
crystalls with same frequency (32.768 Khz) but only one of them , the smallest
size, were working fine with the CD4060 and I have no clue why! By the way,
are they anyone have codes line or example how to use DAQ to retrive
datas from BS2 and transfert it to EXCEL?
Thank you very much!
Jim Forkin a
crystal oscillator. Check any data sheet for applications.
jim
http://www.geocities.com/jimforkin2003/
From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_ZHLcjxxe2ubN_ZkjThZWKJtPglnG18f2R5j1nYR8VGU2DxYooVNP9JMj0iuBErMU0Zv_4CA1PfPJfHA-eWN]jwilliams@p...[/url
Sent: Tuesday, December 30, 2003 12:09 AM
Subject: RE: [noparse][[/noparse]basicstamps] Stapm
NE555 and "stable" are rarely used in the same sentence due to the RC
-- Jon Williams
-- Parallax
From: Rene Genest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FW4YzXHWQ762Axf1LMqhVI6I8r_v9Dry5TB26HXfZW94lQXc12KKqjXxhlh2vI26mM33pDduy621TDIC_g]rene.genest@q...[/url
To: stamp
Hi group!
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
a fairly high drive to get it vibrating so you probably want to start with a
higher frequency oscillator and divide down to 40 khz. This will divide
jitter and drift as well and give you a more stable oscillator. This can
all be done with standard logic chips. Maybe use a 4 mhz crystal to start
and then divide by 100 for your required 40 khz. However, many applications
do not require the stability and expense of a crystal oscillator and a
simple 40khz 555 circuit is sufficient. Don't expect temperature stability
with either approach without compensating circuits or an oven or both.
jim
From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iSZgvJ74baUIKrH5aYCe1p_HGMyiHKrPde1ZvN2HkvjhLym6yFI5BhFY6aXyTg_dy6MKDZ6v6SsG8cWE0q-76w]jwilliams@p...[/url
-- Jon Williams
-- Parallax
From: Rene Genest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=C9ZHQDClomSPiK0VRrjxAKxX1gR7NhXXeZ4pZL_mzVhBDnsb4forRR-WoWVeHbziwzQO9zijfDudVkBRA-Qf]rene.genest@q...[/url
To: stamp
Hi group!
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
