fustrated beginer, easy loop question-SOLVED
This is "Electrajim"
I finally found the solution to this problem.
I havn't had much time to experiment due to the holidays,
but today, I found why this didn't work, and now it does.
....your gonna laugh.....
I unplugged the serial cable so I could try programming
the Homework Board on another PC. A tower instead of a laptop PC
Useing the same BASIC stamp editor v2.1.
Since the last program I ran was below, once I unplugged the
serial cable, IT BLINKS, AND IN A LOOP! perfect, no problems.
NOW. Am I an idiot or what? The first excercises use DEBUG
statements, and NEED to have this Homework Board plugged in!!
Was I to assume that the wired projects needed to be unplugged
BEFORE they work and run the code?
Why is this, and what did I miss?
Another power saving feature?
Thanks to all for your input.
Jim
--- In basicstamps@yahoogroups.com, Electragn@h... wrote:
> Please help a frustrated beginer.
> I just got a Parallax BASIC Stamp HomeWork Board, and
> I can't even get thru Chapter #2!!
> Why in the heck won't this thing LOOP! All it does is
> 14 goes "high" for just a second or two, then it quits!!
> ' Turn LED on and off. Repeat 1 time per second indefinitely.
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOOP
> I know this seems real simple, but whats wrong?!?!?!?!
> Thanks to all
> Electrajim
Jim
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOOP
> Thanks to all
> Electrajim
serial port on your laptop. We've seen this before, but the issue is
usually fixed by reducing the port FIFO buffers to minimum settings, or
if that doesn't work, putting an extra DEBUG statement into the program
so that the compiler DEBUG window keeps the port open (and from powering
down which usually is the source of the problem). What you didn't say
is if you could download and run non-DEBUG programs on your tower PC.
That would be the final confirmation.
As far as staying connected, you only need to be connected for
downloading (of course), to use DEBUG, DEBUGIN (new to $PBASIC 2.5),
SEROUT on pin 16, or SERIN on pin 16.
Hopefully now you'll be able to continue working through your WAM text
and start having some real fun.
Happy New Year!
-- Jon Williams
-- Dallas Office
From: Electragn@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FQLfM08zlIEVvU6muo0Q4qfWCRBfsRuTUKXmJVQmTeg4EWVZYwMQ0WuyBfT-iQj8IZqU_1xbrLGGkrQTlEMgMA]Electragn@h...[/url
Sent: Sunday, December 28, 2003 5:16 PM
Subject: [noparse][[/noparse]basicstamps] Re: fustrated beginer, easy loop question-SOLVED
the Homework Board on another PC. A tower instead of a laptop PC Useing
Since the last program I ran was below, once I unplugged the serial
NOW. Am I an idiot or what? The first excercises use DEBUG statements,
and NEED to have this Homework Board plugged in!! Was I to assume that
the wired projects needed to be unplugged BEFORE they work and run the
code? Why is this, and what did I miss? Another power saving feature?
Jim
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOOP
> Thanks to all
> Electrajim
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
the identical problem, however reducing or turning off FIFO to COM 1
doesn't solve the problem. Disconnecting the HomeWork Board from
the serial port after downloading the DO/LOOP program also doesn't
work.
The Board does however execute the FOR counter correctly.
Hmmmmm????
Fred
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> You seem to have proved what a few of us suspected: you have a
funky
is
settings, or
program
powering
say
PC.
2.5),
text
> Happy New Year!
> -- Jon Williams
> -- Dallas Office
> From: Electragn@h... [noparse][[/noparse]mailto:Electragn@h...]
SOLVED
Useing
statements,
that
the
feature?
> Jim
> > ' {$STAMP BS2}
> > ' {$PBASIC 2.5}
> > DO
> > HIGH 14
> > PAUSE 500
> > LOW 14
> > PAUSE 500
> > LOOP
> > Thanks to all
> > Electrajim
Subject
> Yahoo! Groups Links
> abuse@p...
compiler. You need to have a newer compiler (at least Version 2.0, the
latest avaiable is Version 2.1, Beta 1) to support the {$PBASIC 2.5}
directive required for DO-LOOP.
http://www.parallax.com/html_pages/downloads/software/software_basic_sta
mp.asp
-- Jon Williams
-- Dallas Office
From: vegaebh [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AjddqCFVnT46Mi-_8htZgLOeOJ0nFEKpUJIoSpO2Masi9OuDkjFr7I8pMaL0zl9RtWc5E1ddqQ]vegaebh@y...[/url
Sent: Tuesday, December 30, 2003 12:18 PM
I just recently purchased my HomeWork Board from RadioShack and have
work.
Hmmmmm????
Fred
funky
is
settings, or
program
powering
say
PC.
2.5),
text
> Happy New Year!
> -- Jon Williams
> -- Dallas Office
SOLVED
Useing
statements,
that
the
feature?
> Jim
> > ' {$STAMP BS2}
> > ' {$PBASIC 2.5}
> > DO
> > HIGH 14
> > PAUSE 500
> > LOW 14
> > PAUSE 500
> > LOOP
> > Thanks to all
> > Electrajim
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
select Downloads\Basic Stamp Software from the menu bar.
-- Jon Williams
-- Parallax
Sent: Tuesday, December 30, 2003 1:14 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: fustrated beginer, easy loop
question-SOLVED
If you haven't already, please download the latest version of our
mp.asp
-- Jon Williams
-- Dallas Office
From: vegaebh [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MqJm7Wk6Rcb3BGNY5uH6QEWErv8F3FoXcLCIOD43exFoMbWzSmTYa2EjUEisxQY-F39Tm47Dtrw]vegaebh@y...[/url
work.
Hmmmmm????
Fred
funky
is
settings, or
program
powering
say
PC.
2.5),
text
> Happy New Year!
> -- Jon Williams
> -- Dallas Office
SOLVED
Useing
statements,
that
the
feature?
> Jim
> > ' {$STAMP BS2}
> > ' {$PBASIC 2.5}
> > DO
> > HIGH 14
> > PAUSE 500
> > LOW 14
> > PAUSE 500
> > LOOP
> > Thanks to all
> > Electrajim
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
abuse@p....
have the correct directive.. The {$PBASIC 2.5} directive fixed the
problem..
Fred
2.0, the
2.5}
sta
> mp.asp
> -- Jon Williams
> -- Dallas Office
> From: vegaebh [noparse][[/noparse]mailto:vegaebh@y...]
SOLVED
have
1
> work.
> Hmmmmm????
> Fred
<jwilliams@p...>
> funky
issue
> is
> settings, or
> program
> powering
didn't
> say
> PC.
> 2.5),
> text
> > Happy New Year!
> > -- Jon Williams
> > -- Dallas Office
> SOLVED
> Useing
serial
> statements,
> that
run
> the
> feature?
> > Jim
> > > ' {$STAMP BS2}
> > > ' {$PBASIC 2.5}
> > > DO
> > > HIGH 14
> > > PAUSE 500
> > > LOW 14
> > > PAUSE 500
> > > LOOP
> > > Thanks to all
> > > Electrajim
> Subject
> > Yahoo! Groups Links
to
> > abuse@p...
Subject
> Yahoo! Groups Links
> abuse@p...
fixed the problem.. I accidently used parenthesis () instead of
brackets {} around the "$PBASIC 2.5" directive.. After looking at
the manual with my handy magnifying glass I saw the mistake.. Just
goes to show that you always have to watch the small print!
Fred
--- In basicstamps@yahoogroups.com, "vegaebh" <vegaebh@y...> wrote:
> Thanks... I had the latest verstion of the editor.. Just didn't
the
> problem..
> Fred
<jwilliams@p...>
> 2.0, the
> 2.5}
> sta
> > mp.asp
> > -- Jon Williams
> > -- Dallas Office
> SOLVED
> have
COM
> 1
from
doesn't
> > work.
> > Hmmmmm????
> > Fred
> <jwilliams@p...>
> > funky
> issue
> > is
> > settings, or
> > program
> > powering
> didn't
> > say
tower
> > PC.
> > 2.5),
WAM
> > text
> > > Happy New Year!
> > > -- Jon Williams
> > > -- Dallas Office
question-
> > SOLVED
PC
> > Useing
> serial
> > statements,
assume
> > that
> run
> > the
> > feature?
> > > Jim
> > > > ' {$STAMP BS2}
> > > > ' {$PBASIC 2.5}
> > > > DO
> > > > HIGH 14
> > > > PAUSE 500
> > > > LOW 14
> > > > PAUSE 500
> > > > LOOP
> > > > Thanks to all
> > > > Electrajim
> > Subject
> > > Yahoo! Groups Links
> to
> > > abuse@p...
> Subject
> > Yahoo! Groups Links
> > abuse@p...
is no such thing as a software error since the computer didn't write the
program itself!
Keep in mind that there are buttons for Stamp type and PBASIC directives
on the toolbar. This will prevent typos.
-- Jon Williams
-- Dallas Office
From: vegaebh [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rU9LihldCBZlAKlfW2I2QcIZkyBIIg6CHQk3f50hZLV06hDDFHIT-uOF6_3TtvlxQejqdgoFiQVf]vegaebh@y...[/url
Sent: Wednesday, December 31, 2003 11:01 AM
I need to be a bit more specific when I say the correct directive
Fred
the
> problem..
> Fred
<jwilliams@p...>
> 2.0, the
> 2.5}
> sta
> > mp.asp
> > -- Jon Williams
> > -- Dallas Office
> SOLVED
> have
COM
> 1
from
doesn't
> > work.
> > Hmmmmm????
> > Fred
> <jwilliams@p...>
> > funky
> issue
> > is
> > settings, or
> > program
> > powering
> didn't
> > say
tower
> > PC.
> > 2.5),
WAM
> > text
> > > Happy New Year!
> > > -- Jon Williams
> > > -- Dallas Office
question-
> > SOLVED
> > > I havn't had much time to experiment due to the holidays, but
> > > I unplugged the serial cable so I could try programming the
PC
> > Useing
> serial
> > statements,
assume
> > that
> run
> > the
> > feature?
> > > Jim
> > > > Why in the heck won't this thing LOOP! All it does is 14 goes
> > > > ' {$STAMP BS2}
> > > > ' {$PBASIC 2.5}
> > > > DO
> > > > HIGH 14
> > > > PAUSE 500
> > > > LOW 14
> > > > PAUSE 500
> > > > LOOP
> > > > Thanks to all
> > > > Electrajim
> > Subject
> > > Yahoo! Groups Links
> to
> > > abuse@p...
> Subject
> > Yahoo! Groups Links
> > abuse@p...
Yahoo! Groups Links
abuse@p....
