Question to Tracy Allen about Atmel Data flash
Archiver
3 to 5 volt conversion.
I use the AT45D0041 (0.5 Meg) unit, using your program example. It's
working great.
But ATMEL don't produce the D-version (5Volt) any longer. I have
tried to use the newer DB (3Volt) version, but I don't get any
response when I use a Motorola HC244 level converter.
How do you connect the newer Atmel Data flash to a BS2p?
Stein.
working great.
Stein.
>working great.
>Stein.
Hi Stein,
There is no need for level converters. Simply connect SI, SCK and
CS\ on the AT45DB041 directly to stamp pins, and also connect SO to a
Stamp pin (which can be the same as SI) via a 1k ohm resistor. The
inputs to the chip are "5 volt tolerant", and the Stamp can input 0-3
volts just fine. Be very sure though that you operate the chip from
a 3 volt supply (2.7 to 3.6) on its Vdd pin 6. It is a fine geometry
silicon that will be damaged by higher Vdd levels.
-- regards,
Tracy
http://www.emesystems.com/BS2flash.htm
It's
> >working great.
> >Stein.
> Hi Stein,
to a
The
0-3
from
geometry
> -- regards,
> Tracy
Without your program example, I could not got this far. I promise.
eeeee.... so the SO (or Sout 0-3 volt output signal) from the Atmel
data flash should have a 1K resistor before connected to the Stamp.
Not like a pullup/down resistor or somthing?
The 32meg Flash is still 5 volt tolerant on the input, but the 64
and 128meg is not. How can the bigger Flash get connected to the TTL
Stamp input?
Is your program on "http://www.emesystems.com/BS2flash.htm" working
on the bigger Flash circuits, or do I have to upgrade the program?
Stein.
>Stamp input?
>Stein.
Hi Stein,
The AT45DBxxx does not need any pullup or pulldown resistors. The 1k
resistor between the SO pin and the Stamp pin is there as a
precaution, if due to programming error, both SO and the Stamp are
outputs at the same time. SO and SI can share the same Stamp pin.
The programs take minor changes in order to work with the larger
chips and the AT45DCBxxx modules. Chips 1 megabyte and less have 264
byte page size, while 2 megs and up have 528 byte pages.
Command sequence (AT45DB081 and smaller) for byte address adrs on page ATpage:
SHIFTOUT atsd,sck,MSBFIRST,[noparse][[/noparse]cmd\8,ATpage\15,adrs\9]
' + clocking bits
Command sequence (AT45DB161 and larger) for byte address:
SHIFTOUT atsd,sck,MSBFIRST,[noparse][[/noparse]cmd\8,ATpage\14,adrs\10]
' + clocking bits
The clocking bits required are the same in both cases.
-- best regards
Tracy Allen
mailto:tracy@e...
I made a pcb-board and connected a few Atmel Data flashes. The Soic-
packed AT45DB161B-RI (16megabyte) has still some difficulties. The
Ready/Busy is low all the time. I can read and write the buffers, so
the program and signal level should be correct.
.....eeee..... but I can't read or write a page, only the buffers.
The data sheet is confirming that it's possible to read and write
the buffer when the busy is low.
The AT45D041 Ready/busy, on the same board, goes high when it's done.
Have you encountered this problem by any chance?
Where could the problem be?
I'm measuring the pcb-board all day long......is it me?
Pin 1 is grounded
Pin 4 is low from 5 volt, when I operate the CS signal from a 74145
Pin 5 clock to Stamp port 8
Pin 6 Sin to stamp port 9
Pin 7 Sout to stamp port 10
Pin 28 Vcc, has 3,1 Volt input
Pin 24 WP, has 3,1 volt input
Pin 25 Reset, has 3,1 volt input
Pin 23 Ready/busy output is low, should be high.
Stein.
Stamp.
TTL
> >Stamp input?
working
> >Stein.
> Hi Stein,
1k
264
page ATpage:
> ' + clocking bits
> ' + clocking bits
> -- best regards
> Tracy Allen
> mailto:tracy@e...
I think you need a pullup resistor on the hardware ready/busy signal line.
I gather that you have the 28 pin soic. In the article of mine
on-line about the AT45DB041, I was using the 8-pin soic, which does
not have a dedicated ready/busy line. Instead, SO line doubles as
ready/busy, once a status command is issued. It does not need a
pullup. You could also use that trick with the 28-pin version, if
your Stamp pins get used up.
I don't know why you can't write to the AT45 flash page. That should
happen even if you can't read the ready/busy flag, unless there is
some other program issue.
-- Tracy
>Pin 1 is grounded
>Stein.
As you pointed out, there must be a 1K pull-up resistor on the
Ready/busy output to measure the output level.
I read the data sheet several times, but I was not expecting to
actually put this resistor in place if the Data flash should work
properly, unless I should use the gate, or have it connected to the
stamp. The extra confusion is that the smaller Atmel Data Flash, the
AT45DB0041, did not need the resistor at all to work. No, the output
went high, when he was ready, pull-up or not pull-up resistor.
So…..against all my experience, this was the first time I
encountered the need of a pull-up resistor on an output I did not
even needed to use.
Celebration to you Tracy.
I need some sleep.
Stein.
> Hi Stein,
signal line.
does
if
should
> -- Tracy
Soic-
so
done.
> >Pin 1 is grounded
74145
> >Stein.
