Trouble getting reliable serial input
Archiver
I am using a BS2SX to communicate with a motion controller via RS-
232. The controller does not use flow control, but I am only
grabbing one byte from it at a time, so that shouldn't be too much of
a problem. So it works like this: I send a SEROUT command to the
controller from the Stamp asking for status. Then I execute a SERIN
command on the Stamp to grab the one byte result coming back from the
controller. This works most of the time, but occasionally, I beleive
the byte is coming back into the Stamp before the SERIN is ready, and
thus being ignored. Is there some way to make this more reliable, or
speed up the SERIN setup time?
/John
/John
remove them and deal with the data yourself -- but I'm surprise that
your program works sometimes and not others. Perhaps your issue is a
signaling thing between the devices. Is the output from your motion
controller driven or and "open" type output that can be bussed to
multiple receivers? If the latter, perhaps a stiff pull-up on that
serial line will cure your ills.
Happy Holidays.
-- Jon Williams
-- Parallax
From: John Schwab [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Q7zz39BN9i8UgTE2ZCkV_3l4isicxKJpJcjY-n3kTf_ITfPqriUvBkVUo0pEZGiLwMb-2xfZmjHPa9iV4VE]johnschwab5678@y...[/url
Sent: Tuesday, December 23, 2003 10:23 AM
Subject: [noparse][[/noparse]basicstamps] Trouble getting reliable serial input
I am using a BS2SX to communicate with a motion controller via RS- 232.
/John
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
degrees at different times, so it may sometimes respond faster than
other times. The serial output is just a plain vanilla RS-232.
Anyway, when I hook the controller up to a PC serial port, I can read
from it 100% of the time, and I beleive it is because the serial port
on the PC is buffered, and can already be listening when I send the
command out to the controller. Do you know how long it takes for a
SERIN command to become active/
/John
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> If you are using formatters in your SERIN statement you may want to
a
> Happy Holidays.
> -- Jon Williams
> -- Parallax
> From: John Schwab [noparse][[/noparse]mailto:johnschwab5678@y...]
> Hi,
232.
of
SERIN
the
beleive
and
> Thanks,
> /John
Subject
> Yahoo! Groups Links
> abuse@p...
and it's tough to measure emperically since it's asynchonous and
affected by an outside device. That said, I would guess anywhere
between 250 and 1500 microseconds based on Tracy Allen's measurements of
Stamp execution speeds.
FWIW, our Javelin Stamp allows you to create buffers for serial data
streams. If you're comfortable with C or already know Java it may be
something to consider.
-- Jon Williams
-- Dallas Office
From: John Schwab [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rUmue4UB4veEuqki_HCo_DvaBC1wMjavgWKnZ_gRo0nXOEplGYYoFfgP5s9VnzIQ5vodkRliqmMzHKMItUDIeQ]johnschwab5678@y...[/url
Sent: Tuesday, December 23, 2003 11:00 AM
Subject: [noparse][[/noparse]basicstamps] Re: Trouble getting reliable serial input
The motion controller has its own processes that are busy to varying
/John
a
> Happy Holidays.
> -- Jon Williams
> -- Parallax
> Hi,
232.
of
SERIN
the
beleive
and
> Thanks,
> /John
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
Some of the serial timings that Jon mentioned are posted at this URL:
http://www.emesystems.com/BS2rs232.htm#sertime
http://www.emesystems.com/BS2speed.htm
The BS2sx is faster than the BS2, and I had noted 190 microseconds as
the wait before ready on the following command:
x var byte
serin 15,$54,2,comNotReady,[noparse][[/noparse]x] ' (without flow)
' 480 microseconds for BS2
' 190 microseconds for BS2SX
It would be somewhat faster without the timeout parameters.
-- Tracy
>The setup time will depend on the complexity of your SERIN statement,
>-- Jon Williams
>-- Dallas Office
>From: John Schwab [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wGZaTuaXLSZz2y1PZRpI1_ia9ECWV-eJ8wGzUXAXiQ_BJrtkRFyIW70NuSd17HtcwZs9e6-ohk7jFgT1sseOpfwINQ]johnschwab5678@y...[/url
>/John
>a
>> Happy Holidays.
>> -- Jon Williams
>> -- Parallax
>> Hi,
>232.
>of
>SERIN
>the
>beleive
>and
>or
>> Thanks,
>> /John
>Subject
>> Yahoo! Groups Links
>> abuse@p...
>Yahoo! Groups Links
>abuse@p....
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
