Infrared help
I picked up a pack of infrared emitters and detectors (radio
shack). I have no experience with IR yet. I could not find any help
with this topic in the BS manual. On the web site I found DLs of
sample programs, yet they offered no help since I do not know the
wiring for IR components.
Any help using IR will be appreciated.
CJS
CJS
the FREQOUT command. Even though the FREQOUT has a ceiling of 32,767
Hz, enough harmonics are generated to modulate the LED. You can
download any of our robotics oriented code to see this in action.
Here's a bit of code from our Sumo robot:
Read_IR_Sensors:
FREQOUT LfIrOut, 1, 38500 ' modulate left IR LED
irLeft = ~LfIrIn ' read input (1 =
target)
FREQOUT RtIrOut, 1, 38500 ' modulate right IR LED
irRight = ~RtIrIn ' read input (1 =
target)
RETURN
The trick is to receiver. We use Panasonic receivers that stay active
for a bit of time after the removal of the IR signal. This is important
as it allows the Stamp time to move to the next instruction (looking at
the receiver output).
-- Jon Williams
-- Dallas Office
From: Christopher [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xBRXh1xvHJg_-6kusFbfXwzDVe2mk8PUS9KdP_YwLj9cGWVdFQxWjJbswbWRHo1qRsPqVjGkuys]cj193@y...[/url
Sent: Monday, December 22, 2003 12:57 PM
Subject: [noparse][[/noparse]basicstamps] Infrared help
CJS
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
output high. Can I create a delay with a cap. in parallel?
Also for the emitter, it needs to use the freqout command. This
means I cannot just hard wire the emitter high?
Thanks for you help
Chris
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> IR LEDs need to be modulated (usually 38.5 kHz). You can do this
with
32,767
> Read_IR_Sensors:
LED
> target)
IR LED
> target)
> RETURN
active
important
(looking at
> -- Jon Williams
> -- Dallas Office
i also need to know how to wire each component.
Thanks for you help
Chris
<jwilliams@p...>
this
> with
> 32,767
> > Read_IR_Sensors:
IR
> LED
> > target)
> IR LED
> > target)
> > RETURN
> active
> important
> (looking at
> > -- Jon Williams
> > -- Dallas Office
receivers (the modulation is used to prevent other IR sources from
causing a false trigger). So no, you can't simply wire the LED high --
you could, however, drive it full-time with a 555 timer circuit. If you
do, then the delay receiver delay that we use in our robots won't
matter, since you'll not be using FREQOUT to do the modulation, you'll
just be looking at the output of your receiver.
Our BS1 App Notes have the schematic for a 555 circuit you can use to
modulate your IR LEDs.
-- Jon Williams
-- Dallas Office
From: Christopher [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ftH1YJE_OZNuooHxZQmN-c0X2hnxTU7YJoqe_6OaDCR9CE7IjS39h48L9RY81k2HoumKbuhZoEU]cj193@y...[/url
Sent: Monday, December 22, 2003 2:08 PM
Subject: [noparse][[/noparse]basicstamps] Re: Infrared help
You mentioned that the receiver that you use has a delay to keep the
Thanks for you help
Chris
with
32,767
> Read_IR_Sensors:
LED
> target)
IR LED
> target)
> RETURN
active
important
(looking at
> -- Jon Williams
> -- Dallas Office
Yahoo! Groups Links
abuse@p....
i have an invoca LCD touch screen remote for my TV and stuff. the remote
has a learn feature so i can learn different IR codes from different IR
sources. do you think i can send a Serout command from the stamp to store
in the remote and when i press the button on the remote i will send to the
stamp the same IR code. would i use a photo transistor or the 40 KHz
receiver to read the code from the remote.
Here is the plan.
1) send code to the remote from the stamp using a IR LED (Send via Serout)
2) Store that code into the remote.
3) transmit that code back to the stamp receiving it via photo transistor
or 40 KHz receiver
4) based on the code received activate relays.
Thanks to all that can help,
Rgards,
Gary Denison II
Qualcomm Inc.
to achieve this.
From most primitive to most sophisticated, they are:
1. Install an IR-LED and 40 KHz IR-Detector
on your BOE. The IR-Detector will detect IR
pulses at 40 KHz or so, and drive a signal low
when it sees them. Program your Stamp to use the
Sony protocol to transmit with the IR-LED PULSOUT()
and decode the Sony protocol (See Parallax docs)
using PULSIN() from the IR-Detector. $10.00
2. Buy the Parallax IR card, which has the IR-LED
and IR-Detector on-card. Program for the Sony
protocol as above. $15.00.
3. Buy the Parallax IR-Buddy ($30.00(?)). This
has the Phillips RC-5 protocol built in to a
co-processor. Uses 232, MUCH easier to program,
and the IR-Buddy will recieve and hold up to
4 keypresses until your Stamp can get around
to them. Tell your remote to use the Phillips,
or RC-5 code, and go for it.
As a first try, I'd use the IR-Buddy.
'Roll your own' only makes sense if you can't
use the Phillips RC-5 protocol.
--- In basicstamps@yahoogroups.com, Gary Denison <gdii@c...> wrote:
> Hey guys, im in a jam and i need assistance.
remote
different IR
store
to the
KHz
> Here is the plan.
Serout)
transistor
> or 40 KHz receiver
> Rgards,
> Gary Denison II
> Qualcomm Inc.
Gary Denison II
Qualcomm Inc.
At 06:32 AM 2/25/2004, you wrote:
>There are a couple of routes you can take
>to achieve this.
>remote
>different IR
>store
>to the
>KHz
> > Here is the plan.
>Serout)
>transistor
> > or 40 KHz receiver
> > Rgards,
> > Gary Denison II
> > Qualcomm Inc.
>from the same email address that you subscribed. Text in the Subject and
>Yahoo! Groups Links
I am trying to write a program for a sound project, and having a bit of trouble.
I want
to write a program that, when a button is pushed, sends an infrared signal from
an IR
led to an IR detector. When the IR detector receives the signal, it should make
a
speaker emit a tone.
The circuit that I built has a speaker output from pin 7, an IR detector input
at pin 6,
an IR led at pin 9, and a button input at pin 15.
Any help would be much appreciated.
-L
Most IR systems, such as TV remote controls, are modulated. This meas that
the IR beam is pulsed, in the case of a TV remote, usually at 38kHz. This
helps prevent ambient light triggering the reciver, as they are tuned to
38kHz. It is very easy to use a 38kHz reciver with a Stamp. A little harder
is to transmit with the Stamp, as it does not have independent PWM to drive
the 38kHz carrier. You can use a 555 timer or similar to create the carrier
signal and a Schmitt trigger NAND like the 74HC132.
Bruce at Rentron has a good explanation of IR communications here:
http://www.rentron.com/Infrared_Communication.htm
While the page is about using PICs to accomplish the task, it has a lot of
general information about IR communications. I also have information about
an IR reciever module on my website at: http://madlabs.info/ir_remote.shtml
. It would be simple to convert the code for this module for a Stamp.
Hope this helps,
Jonathan
www.madlabs.info
Sent: Sunday, April 18, 2004 10:42 AM
Subject: [noparse][[/noparse]basicstamps] infrared help
> hello,
trouble. I want
from an IR
make a
input at pin 6,
> -L
> Yahoo! Groups Links
