I2C bus shared with uart?
I like some thoughts on the following scenario:
I have an I2C bus with several slaves (eg. eeproms) and a SX28 with VP uart.
The I2C start condition is SDA high to low with SCL high.
The I2C stop condition is SDA low to high with SCL high.
I want to use the SCL as the TX towards the SX28. The SDA serves as RX.
Assume I2C bus is idle, so SCL=H (output or input) and SDA=H (input).
I lower SCL for a specified time. This signals the SX28 that uart mode is
entered.
The stamp sends a command string to the SX28 using SCL. No I2C start/stop
conditions occur because SDA remains high. After sending the string, I keep
SCL low and SDA an input. Then the SX28 responds sending data using the
SDA line. Again, no start/stop occurs because now SCL remains low.
The uart mode stays active until the stamp sends a specific terminate command.
This signals the SX28 that I2C mode will be entered and so the SX28 will not
respond
and waits until the SCL stays low again for the specified time.
Could this work? For safety I will put a resistor between the SX28 TX output and
stamp's SDA.
Has anyone ever tried this?
regards peter
entered.
respond
stamp's SDA.
regards peter
>Hi,
entered.
respond
and stamp's SDA.
>regards peter
Peter -
Your description is almost too detailed in explaining what you want to do.
Are you trying to use the same set of physical wires to run synchronous and
asynchronous serial data (SERIN/SEROUT and SHIFTIN/SHIFTOUT) ? If so, why bother
when SHIFTIN and SHIFTOUT (or bit banging on some Stamp models) and/or I2CIN and
I2COUT are available to you ?
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
stamp. There is
however an existing I2C bus. So I have two options:
1. Program the SX28 as an I2C slave. I have done that before but never got
the SX28 to recognize an I2C start condition
when using the stamp's built-in I2C commands. The SX28 always detected a 11
to 00 transution for SCL and SDA,
sampling at 4.3 uS. The I2C specs specify a 4.7 uS hold time for the start
condition, so it should have been detected.
I guess the stamp lowers SCL faster than 4.3 uS after SDA drops. If I use
software programmed I2C there is no
problem but this gives too much overhead and loss of speed.
2. Program the SX28 with a uart and use the I2C pins when the I2C bus is
idle.
I don't need the SX28 to access the eeproms on the I2C bus. I just need to
communicate
with the basic stamp. I know I2C can be shared with SPI, but how about a
uart?
The uart would follow a strict protocol, something like I described, with
the stamp always in control.
regards peter
Sent: Monday, December 22, 2003 5:55 PM
Subject: Re: [noparse][[/noparse]basicstamps] I2C bus shared with uart?
> At 05:42 PM 12/22/03 +0100, Peter Verkaik wrote:
> >Hi,
uart.
entered.
keep
command.
not respond
output and stamp's SDA.
> >regards peter
> Peter -
and asynchronous serial data (SERIN/SEROUT and SHIFTIN/SHIFTOUT) ? If so,
why bother
I2CIN and
> Regards,
> Bruce Bates
> >Yahoo! Groups Links
> Yahoo! Groups Links
>stamp. There is
Hi Peter. Look at a 'scope in more detail at what is going on. The
Stamp does the following when it hits an I2C command, either IN or
OUT: It pulls both SDA and SCL low simultaneously, as you observed.
Then about 15 microseconds later, SCL goes back high, then SDA goes
high (stop condition) then SDA goes low (start condition), then SCL
goes back low. That whole stop/start transaction takes about 30
microseconds, so your SX28 should be able to pick it up. The
shortest edge-edge transition is about 5 microseconds. After the
start condition, the clocking continues, with acknowledges etc etc..
What that means for the Stamp programmer is that we don't have to
worry to much about the condition of the I2C device when the program
hits the I2C commands, because the command internally assures that
the device is in a STOP state before it issues the START. We don't
have to manipulate the pins externally at power up for example, to
guarantee a STOP condition.
>idle.
>communicate
>uart?
I see no reason why your multiplexing scheme would not work. I have
done something like that in a system that shared the SCL line for an
I2C buss with the SCK line for an SPI buss. It was always a
headache, as the SPI buss expects the clock to be low to start and
the I2C buss expects the clock to be high to start. (Realizing that
the Stamp I2C commands always generate an STOP internally prior to
START took away some of the problem).
In general IMHO it is a lot less confusing to keep the busses
separate, and the same thing would apply to the RS232 scheme, as you
will _always_ have to take care for the proper sequence of pins. But
if you are short of pins, what else can you do?
-- regards,
Tracy
>regards peter
>From: "Bruce Bates" <bvbates@u...>
>> >Hi,
>uart.
>entered.
>keep
>command.
>not respond
>> >regards peter
>> Peter -
>why bother
>I2CIN and
>> Regards,
>> Bruce Bates
>> >Yahoo! Groups Links
>> Yahoo! Groups Links
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
> [noparse][[/noparse]...]
> busses separate, and the same thing would apply to
> the RS232 scheme, as you will _always_ have to take
> care for the proper sequence of pins. But if you are
Use an analog multiplexer so you don't have to worry about the signal states
conflicting?
Gary
I will try to anticipate the stop/start sequence in my
I2C slave code.
regards peter
Sent: Monday, December 22, 2003 11:55 PM
> >I don't have two free pins for communication between an SX28 and a basic
> >stamp. There is
got
11
start
> >idle.
to
> >communicate
> >uart?
> -- regards,
> Tracy
> >regards peter
> >> >Hi,
> >uart.
RX.
is
> >entered.
start/stop
> >keep
the
> >command.
will
> >not respond
> >> >regards peter
> >> Peter -
do.
> >why bother
> >I2CIN and
> >> Regards,
> >> Bruce Bates
and
> >> >Yahoo! Groups Links
and
> >> Yahoo! Groups Links
> >Yahoo! Groups Links
> Yahoo! Groups Links
