fustrated beginer, easy loop question
Please help a frustrated beginer.
I just got a Parallax BASIC Stamp HomeWork Board, and
I can't even get thru Chapter #2!!
Why in the heck won't this thing LOOP! All it does is
14 goes "high" for just a second or two, then it quits!!
' Turn LED on and off. Repeat 1 time per second indefinitely.
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
LOOP
I know this seems real simple, but whats wrong?!?!?!?!
Thanks to all
Electrajim
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
LOOP
Thanks to all
Electrajim
Based on the description you provided, I'm sure there is some problem in
your PBASIC 2.5 compiler directive.
At this point your instructions should be in black, because they're not
recognized by the editor.
Please try clicking in the PBASIC 2.5 button (just by ID button) or going to
Directive>PBASIC>Version 2.5
The instructions now will be highlighted in blue (including DO and LOOP) and
the program will start blinking the LED as soon as you download it again.
Saludos,
Aristides Alvarez
International Education Program Developer
aalvarez@p...
Parallax, Inc. www.parallax.com
California, USA
Sent: Sunday, December 21, 2003 9:31 PM
Subject: [noparse][[/noparse]basicstamps] fustrated beginer, easy loop question
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOOP
> Thanks to all
> Electrajim
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
the compiler complain? If so, you may need to upgrade to our latest
release (Version 2.1, Beta 1). Does the LED not blink? Check your
connections -- you may have the LED in backwards (common error). The
negative (cathode) lead is identified with a flat edge on the body of
the LED. The positive (anode) side connects to P14 through a resistor
(typically 470 ohms).
Happy Holidays.
-- Jon Williams
-- Dallas Office
From: Electragn@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=N1Ii-wAzd5G9avqJITJuA2-UfbPaPGMBCdBSuMCifmQWWOq_bAXs3rHpEPc2Gg_DANNWtjpMberkM5E]Electragn@h...[/url
Sent: Sunday, December 21, 2003 11:32 PM
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
LOOP
Thanks to all
Electrajim
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
your description of what's happening. Do you have the proper resistor
installed between the pin and the Stamp? If yes, the problem is a weird
one that has to do with your serial port (I saw this while giving a
class last year in Europe).
For a reason that I can't explain, some serial ports seem to let a
program run once then stop; this is especially true of laptops. One
thing to try is to change your serial port FIFO settings to minimum
values, this usually does the trick.
-- Jon Williams
-- Parallax
Sent: Monday, December 22, 2003 10:18 AM
Subject: RE: [noparse][[/noparse]basicstamps] fustrated beginer, easy loop question
There is nothing wrong with your code. What are you experiencing? Does
Happy Holidays.
-- Jon Williams
-- Dallas Office
From: Electragn@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7FlsJpnVAIwN_-Q9Jb90DKN6sQXhRpAlzlkvJkfnr4so1qahDRi5YnIlRDwdzut48HRRxNNJSTkiUFGBKdE]Electragn@h...[/url
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
LOOP
Thanks to all
Electrajim
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
abuse@p....
wrote:
> Sorry ... I have too many things on my desk this morning, and I
missed
resistor
Absolutely! No doubt, I've been able to wire up LED's since
the 80's! [noparse]:)[/noparse] I really feel that there is no wiring problem,
or LED polarity issue, correct resistor. The breadboarded LED does
blink, usually only once when the program is run, and it blinks along
with the surface mounted power LED every time.
............but just once, no loop! ever!!
Isn't that totally strange or what?!?
The laptop I have is a Dell Inspirion 7600 w W98.
Where do I change serial port FIFO settings to minimum values
anyway?
BTW, thank you very much for the prompt reply.
This is especially nice for a fustrated beginner.
> -- Jon Williams
> -- Parallax
> From: Jon Williams
Does
The
of
resistor
> Happy Holidays.
> -- Jon Williams
> -- Dallas Office
> From: Electragn@h... [noparse][[/noparse]mailto:Electragn@h...]
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOOP
> Thanks to all
> Electrajim
Does
LED blinks once. That's it! no loop or continous blinking.
Nope. Not at all.
I did, first thing.
Yes, only once.
Check your
The
of
resistor
That's the EASY part for me. It's all wired 100% correct!
> Happy Holidays.
..and the same to you and everyone!
Electrajim
> -- Jon Williams
> -- Dallas Office
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOOP
> Thanks to all
> Electrajim
If the power LED is blinking as the other LED comes on, you might have a
weak battery that is unable to provide sufficient voltage when the Stamp
turns on the LED. Do you have a voltmeter that you can use to monitor the
battery voltage *while* the program is running and the LED is on? If not,
how about a new/fresh battery?
Randy
www.glitchbuster.com
>Randy
Electrajim,
In addition to Randys suggestion as a sanity check, try modifying your
code slightly to produce 2 blinks before the loop. That way if there
is a power requirement problem with driving the LED, your program
should still only blink once.
DO
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
LOOP
Make DO a label with a colon after it ie... DO:
make your LOOP a GOTO DO and see what happens.
looks like your program is not looping and stopping at LOOP
Sent: Monday, December 22, 2003 1:34 PM
Subject: [noparse][[/noparse]basicstamps] Re: fustrated beginer, easy loop question
> --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
> missed
> resistor
> anyway?
> > -- Jon Williams
> > -- Parallax
> > From: Jon Williams
> Does
> The
> of
> resistor
> > Happy Holidays.
> > -- Jon Williams
> > -- Dallas Office
> > ' {$STAMP BS2}
> > ' {$PBASIC 2.5}
> > DO
> > HIGH 14
> > PAUSE 500
> > LOW 14
> > PAUSE 500
> > LOOP
> > Thanks to all
> > Electrajim
> Yahoo! Groups Links
along
have a
Stamp
monitor the
If not,
I'm pretty sure the battery is fresh. I opened the new pkg
myself. Tested 9.38V I think. Under "load" I tested too. I don't
remember what the voltage was, but if it was anything under 9V,
I would have swapped it out. I _wish_ the snafu was that easy to
fix. I'll test it and report the result.
Jim
keyword and cannot be used as a label in PBASIC 2.5.
-- Jon Williams
-- Dallas Office
From: Eric Adams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TW8p7p2GWuNyLMmyo3p1mzePucu_39rDWtpeNe8-0wpfCJc-59isCyH6iNwpTG9BE-UEeCWZVy26emfEBtRvxA]hugs102@b...[/url
Sent: Monday, December 22, 2003 1:10 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: fustrated beginer, easy loop question
You might try changing your program around a little.
> missed
> resistor
> Absolutely! No doubt, I've been able to wire up LED's since the 80's!
> [noparse]:)[/noparse] I really feel that there is no wiring problem, or LED polarity
> issue, correct resistor. The breadboarded LED does blink, usually only
> once when the program is run, and it blinks along with the surface
> Where do I change serial port FIFO settings to minimum values anyway?
> > -- Jon Williams
> > -- Parallax
> > From: Jon Williams
> Does
> The
> of
> resistor
> > Happy Holidays.
> > -- Jon Williams
> > -- Dallas Office
> > ' {$STAMP BS2}
> > ' {$PBASIC 2.5}
> > DO
> > HIGH 14
> > PAUSE 500
> > LOW 14
> > PAUSE 500
> > LOOP
> > Thanks to all
> > Electrajim
> and
> Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
The connection of the LED in the HomeWork Board is a little different than
in the Board of Education.
In the BOE the power LED is on all the time the power is connected to the
board.
In the HWB, the LED is on only meanwhile the BASIC Stamp is executing a
program.
When the execution is done, the BASIC Stamp goes to sleep mode and the power
LED turns off.
This was implemented as a power saver feature, because the board is intended
to be powered with a 9V battery.
In this example, the problem is that the Editor is not recognizing the
DO...LOOP command.
So, this snippet is executed only once:
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
Then, the BASIC Stamp goes to sleep mode and the power LED goes off.
As Eric suggested, Electrajim can solve the problem with this code:
Repeat:
HIGH 14
PAUSE 500
LOW 14
PAUSE 500
GOTO Repeat
Or simply inserting the PBASIC 2.5 directive using the PBASIC 2.5 button or
going to Directive>PBASIC>Version 2.5.
I'm assuming that Electrajim is using the latest Editor, as recommended in
the book (What's a Microcontroller? V2.0 or 2.1).
Saludos,
Aristides Alvarez
aalvarez@p...
California, USA
in Win98:
1) Go to your desktop.
2) Right-click the "My Computer" icon
3) Left-click "Properties"
4) Left-click the "Device Manager" tab
5) Find "Ports (COM & LPT)" in the hardware list; expand by
left-clicking "[noparse][[/noparse]+]"
6) Select (left-click) your programming port (i.e., Com1)
7) Left-click the "Properties" button (bottom of dialog)
8) Left-click to "Port Settings" tab
9) Left-click the "Advanced..." button
10) Move the Receive and Transmit sliders left to the Low (1) position
11) Left-click (Advanced) "OK" button
12) Left-click (Properties) "OK" button
13) Left-click (System Properties) "OK" button
You may want to restart the Stamp editor and try your code again. This
is a very peculiar thing that has to do with the port not resetting
itself correctly after the your program is downloaded, so the program
runs once and stops. Like I said earlier, I've seen this first-hand.
Happy Holidays -- and have fun with your BASIC Stamp!
-- Jon Williams
-- Dallas Office
From: Electragn@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=axOjqXhnR-n6K0v5b0jR-znqdKJTl972g2In0OlNOwCBfAz7Gv-noP9Q9ZraWArBiDvBMTJ1K55TMYhu_-8]Electragn@h...[/url
Sent: Monday, December 22, 2003 12:34 PM
missed
resistor
> -- Jon Williams
> -- Parallax
> From: Jon Williams
Does
The
of
resistor
> Happy Holidays.
> -- Jon Williams
> -- Dallas Office
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> DO
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
> LOOP
> Thanks to all
> Electrajim
Yahoo! Groups Links
abuse@p....
--- Original Message ---
morning, and I
>missed
the proper
>resistor
since
problem,
it blinks along
minimum values
>anyway?
this while giving a
ports seem to let a
of laptops. One
settings to minimum
question
quits!!
indefinitely.
>' {$STAMP BS2}
>' {$PBASIC 2.5}
>DO
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
>LOOP
>Thanks to all
>Electrajim
Text in the Subject and Body of the message will be
ignored.
>Yahoo! Groups Links
Sent: Tuesday, December 23, 2003 12:23 PM
Subject: Re: [noparse][[/noparse]basicstamps] fustrated beginer, easy loop question
> Did you add the debug statement?
> question
> quits!!
> indefinitely.
> >' {$STAMP BS2}
> >' {$PBASIC 2.5}
> >DO
> > HIGH 14
> > PAUSE 500
> > LOW 14
> > PAUSE 500
> >LOOP
> >Thanks to all
> >Electrajim
> ignored.
> >Yahoo! Groups Links
> Yahoo! Groups Links
DEBUG activates the port and keeps the DTR from putting the Stamp in
reset. Yes, putting a DEBUG statement into a program with a finicky
port will often solve the problem.
Happy Holidays.
-- Jon Williams
-- Parallax
From: daweasel@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ORotS7bvHKKbPI5FMdWtkzg4LSYVWX2WLjkixJTF9oMICJLgn5bZBZX21Y2tOO9al-XEAszftgNQ]daweasel@s...[/url
Sent: Monday, December 22, 2003 5:24 PM
question
quits!!
indefinitely.
>' {$STAMP BS2}
>' {$PBASIC 2.5}
>DO
> HIGH 14
> PAUSE 500
> LOW 14
> PAUSE 500
>LOOP
>Thanks to all
>Electrajim
ignored.
>Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
