Pause duration
I just checked the PAUSE duration with the oscilloscope. Is shows
that the 'Duration' actually increments in 3msec intervals (not 1 ms
as suggested in Help). So 'Pause 1' gives 3ms, 'Pause 2' - gives 6
ms etc. 'Pause 0' command gives approx. 0.7 ms delay.
Other approach I tried is:
FOR i=0 to Duration: NEXT
-gives approx. 2,2ms delay increments. Unforunately the minimum
delay obtainable is 2,2ms as FOR:NEXT loop is executed at least once.
Q. is there any way to get a shorter pause, say <=1ms?
Sincerely,
Boris
Env. BS2 (BASIC Stamp Homework Board), WinXP
PBASIC 2.5
Editor 2.0 beta2
Sincerely,
Boris
PBASIC 2.5
Editor 2.0 beta2
incorrectly. I just ran this little program:
Main:
DO
HIGH 0
PAUSE 2
LOW 0
PAUSE 5
LOOP
END
And found that the actual high pulse output is about 400 uS (0.4 ms)
longer than the PAUSE duration -- this is due to EEPROM access and setup
for both the PAUSE and LOW instructions. I tried with several values
with consistant results.
Dr. Tracy Allen has done extensive testing on instruction timing and has
documented in nicely on his web site. Have a look:
http://www.emesystems.com/BS2speed.htm
-- Jon Williams
-- Dallas Office
From: odissey2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WfMddCSHUKfLZhGHj2I-hTYD6h-2OSf66GbKTC9Huuq6TsM9ZraIM90V1AobbGn9VcYr2oksGOBa]botadjik@n...[/url
Sent: Sunday, December 21, 2003 3:25 PM
Subject: [noparse][[/noparse]basicstamps] Pause duration
Sincerely,
Boris
PBASIC 2.5
Editor 2.0 beta2
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
