Question on measuring execution speed — Parallax Forums
edited 2003-12-22 01:38 in General Discussion
I was trying to find information in the archives on code that would
measure the time a routine took to execute. An internal stop watch if
you will. Haven't been sucessful. Can anyone point me in the right
direction?
    edited 2003-12-21 17:18
    In a message dated 12/21/2003 9:11:34 AM Pacific Standard Time,
    khufumen@y... writes:
    direction?
    There may be code that measures the time of a loop, but I am unaware of such.
    If there are not many IF statements, a method that will get you close is to
    bracket your section of code by making a pin go high just before the section
    you want to measure, then go low imeadiately after. Then with an oscope meausure
    that time.
    Also, this link has execution times of individual
    [url=instructions...http://www.emesystems.com/BS2speed.htm]instructions...http://www.emesystems.com/BS2speed.htm[/url]
    edited 2003-12-21 17:26
    If you have an extra pin on your project and a second Stamp you do it
    very simply: On entering the code (routine) you want to time, set your
    spare pin high; when the code is done take the spare pin back low. On
    your second Stamp, use PULSIN to measure the spare pin pulse duration.
    I've done this many times, converted the PULSIN value to milliseconds
    and displayed on a Scott Edwards serial LCD.
    I recently used this to time subroutines in a small robot so that I
    could update the servos when needed, and not kill time unnecessarily
    with PAUSE. At the end of each subroutine I had this kind of line:
    tix = tix + measured_routine_time_in_ms
    The top of my control code looked like this:
    Main:
    IF (tix >= 20) THEN GOSUB Update_Servos
    ON state GOSUB Task_0, Task_1, ...
    -- Jon Williams
    -- Dallas Office
    From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IJXmoHvvolRlTBAjHTmhNX417tIY3raC71lS8_P5iNv4bq2l1-oCuB4UK7-qADJR--6qK-lO7q9G6A]khufumen@y...[/url
    Sent: Sunday, December 21, 2003 11:10 AM
    Subject: [noparse][[/noparse]basicstamps] Question on measuring execution speed
    direction?
    Yahoo! Groups Links
    To visit your group on the web, go to:
    http://groups.yahoo.com/group/basicstamps/
    To unsubscribe from this group, send an email to:
    Your use of Yahoo! Groups is subject to:
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-12-21 18:36
    In a message dated 12/21/2003 9:28:02 AM Pacific Standard Time,
    jwilliams@p... writes:
    What about doing the same with a scope?
    edited 2003-12-21 19:48
    Yep, that works too.
    -- Jon Williams
    -- Parallax
    From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zOe1-_bqLPajR3cZeJLBTdUhSDN796zL-vvpD1KWmj-OGm2T4l6yGXsZNSa7eUaXJ8sQHuqmvWRQSPw]smartdim@a...[/url
    Sent: Sunday, December 21, 2003 12:36 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Question on measuring execution speed
    Yahoo! Groups Links
    abuse@p....
    Thanks for two good ideas. I am actually using two stamps in my
    project. One is an industrial strength BS2 which basically manages
    the power as well as a heater(a couple of low ohm resistors. Once the
    temperature in the box is above freezing, power is given to a BS2sx
    and the datalogging begins. The stamp will be outdoors in occasional
    extreme cold weather conditions. I'll try the PULSIN method and the
    oscilloscope method and see which one is easier. Thanks again for
    your help.
    Kind Regards,
    Eric
    --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
    > -- Jon Williams
    > -- Parallax
    > From: smartdim@a... [noparse][[/noparse]mailto:smartdim@a...]
    it
    your
    On
    duration.
    milliseconds
    Subject
    > Yahoo! Groups Links
    > abuse@p...
