PC oscilloscopes
Has anyone used Winscope for digital circuit analysis? Is it a
useful tool? If so, what voltage levels are safe to input into the
line input jack on a PC sound card? I would be measuring TTL logic
levels. Any problems doing this?
TIA for any help.
TIA for any help.
rturley@a... writes:
Take a look at the Optascope at www.parallax.com. Great little scope - has a
max input of 40 volts wothout the attenuator. Dual channel - USB connected.
Sid Weaver
W4EKQ
Port Richey, FL
levels but not much higher. You might want to check with your
soundcard manufacturer first for maximum input specs.
-Dave
--- In basicstamps@yahoogroups.com, "rustyturley" <rturley@a...>
> TIA for any help.
