2N2222 and Other Transistors Info -- No Reply Needed
For those of us who are neophites with electronics, here is some info
on 2N2222 and other transistors...
See Nuts and Volts, Article 6, Silicon Steriods for Stamps ...
See the Nuts and Volts Section of Parallax.com downloads. The
article is in Volume 1.
Also, you can find it on the Parallax Inc CD if you have it. I
happen to have May 2003. See the Documentation section.
I found these pin numbers using PCB123 schematic software
Pin 1 Collector
Pin 2 Base
Pin 3 Emmitter
Good luck on your project!
Best wishes,
Frank
Pin 1 Collector
Pin 2 Base
Pin 3 Emmitter
Best wishes,
Frank
