Analog Output from the BS2
I am currently looking into a BASIC Stamp powered school project in which I will
have
6 circuits of LEDs which I need to be able to control the voltage of
individually and
simultaneously.
I have looked into various methods of analog output like Digital Potentiometers,
Motor Controllers and PWM+Capacitors, But I am still unsure of the best option,
or if
there are possibilities I am overlooking.
I will need a voltage range of 0v to +5v
Does anyone have suggestions for the most cost effective and beginner-friendly
way
of achieving this? Any help would be very appreciated.
Andrew
have
individually and
simultaneously.
or if
way
Andrew
through an RC circuit (that what it's designed to do) but you'll have to
buffer the RC with an opamp. Easier, probably, would be Al Williams'
[noparse][[/noparse]no relation] multi-channel PWM controller (PAK5). It's a preprogrammed
SX that lets you PWM up to eight channels. You can use the PWM output
to control the brightness of your LEDs. The interface between the Stamp
and the controller is serial (SEROUT) so the programming will be pretty
straighforward, and the PWM frequency will be maintained in the external
controller freeing the Stamp for other activities.
Here's a link:
http://www.al-williams.com/pak5.htm
-- Jon Williams
-- Dallas Office
-- (972) 659-9090
From: iamthesquidthing [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HdA69HdlOm6q32SQgx87hEufb6DgbuRxxWagY3rx-f5A_ryxD1JlyTVJeuzCOxTFnN9_WxyCg3H4IgWlUfO-]squidthing@x...[/url
Sent: Saturday, December 20, 2003 6:55 AM
Subject: [noparse][[/noparse]basicstamps] Analog Output from the BS2
which I will have
individually and
simultaneously.
Potentiometers,
option, or if
beginner-friendly way
Andrew
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
I use a digital pot for this type of application. It is a nice clean signal
and easy to do in the stamp. I use Analog Devices AD 7376. It has a serial (3
Wire) interface, and as long as the rate that you are varying the voltage level
is not too fast for the pot, you will have good luck.
I use the digital pot to vary the output of a LM555 timer to run stepper
motors from the stamp. The stamp cannot directly output pulses fast enough to
microstep a stepper so I use this poor mans pulse "Turbocharger."
Samples of the software are on the Parallax site.
Alan Bradford
Plasma Technologies
will have
individually and
simultaneously.
Potentiometers,
option, or if
Andrew
in digital pots, I did a set of app notes for Catalyst about using their
digital pots with the Basic Stamp.
http://www.catsemi.com/documents/dpp_parallax_booklet.pdf
Note that some of these devices were not necessarily the best possible
Catalyst part to interface with a Stamp, but we wanted to show how to use
the different interfaces.
Al Williams
AWC
* New 3.3 and 5V Power Supply Kits
http://www.al-williams.com/ps1.htm
> From: plasmastamp@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x_I9A_X8Ko7gXDp0B8hIBssp7SC9pk-7fLv4D2M_e6urqIdLvL_Zgx0636qG67Fd0C8vvkYy_6nJaFkzVGM]plasmastamp@a...[/url
> Sent: Saturday, December 20, 2003 6:14 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Analog Output from the BS2
> Hi Andrew,
> nice clean signal
> has a serial (3
> the voltage level
> run stepper
> Thanks,
> Alan Bradford
> Plasma Technologies
> project in which I
> will have
> individually and
> simultaneously.
> Potentiometers,
> of the best
> option, or if
> Andrew
> Yahoo! Groups Links
lighting projects and they are the best cost vs. complexity setup.
They are easy to setup and easy to program. I've used them with
Pics, OOpics, Stamps, and Atom Pro's and they work pretty slick. I
recently changed out my old OOpic controller on one of my jets and
replaced it with a 2SX/AtomPro and a Pak V
(http://www.rescyou.com/motojet/) and it works awesome for
controlling fuel injectors and other gizmos.
The most cost effective route would be a 2 channel digipot but the
complexity level in programming and setup greatly increase. I use
Microchip 2 channel, 255 level, 100k pots and they run about $2.50US
at Digikey.
The Pak V is the best way to go in my opinion. Shipping is quick,
email support is great and there is a low parts count. I'm running 6
luxeon star superleds through one at the moment and it is a sight to
see.
Resc.
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> Obviously, I like the PAK-V answer from Jon. However, if you are
interested
their
possible
to use
> Al Williams
> AWC
> > From: plasmastamp@a... [noparse][[/noparse]mailto[noparse]:p[/noparse]lasmastamp@a...]
> > Hi Andrew,
> > nice clean signal
> > has a serial (3
> > the voltage level
> > run stepper
> > Thanks,
> > Alan Bradford
> > Plasma Technologies
> > project in which I
> > will have
voltage of
> > individually and
> > simultaneously.
> > Potentiometers,
> > of the best
> > option, or if
> > Andrew
> > Yahoo! Groups Links
