Serial Data from stamp(rev 1)
Archiver
In the debug mode I have to toggle the dtr Line to get my led to flash,,
When I run it just by turning on the power I get one blink and that's
it
'{$STAMP BS2}
'{$PORT COM1}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
field3 = field3 // 10 + 90
DEBUG DEC4 idx, ",+032,12.1,-", DEC3 field3, ",-095,04.3,1,014,015",
CR
PULSOUT 0,5000 'My Led blinking
idx = idx + 1
PAUSE 200
LOOP
END
From: Brian E Boothe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nKWZXqWMGtlBq851XIojqi2PKvRCS-6Nz_jIDSEtTBUdZFgZmqkvwqOuGHkvow_Zac3Y-sCDoR5kCJ8]subrian@m...[/url
Sent: Thursday, December 18, 2003 2:15 PM
Subject: RE: [noparse][[/noparse]basicstamps] Serial Data from stamp
I NEED TO HOOK AN LED TO PORT0 TO SEE THE Polls im still not getting
anything from my stamp in my vb program it is setup For COM1 in my
program
In VB. I wanna blink an LED every poll
From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h3aUM2bcP0JaCILQXpIB8HCkDOSvkNeqhEwv009o384s6p-h3BIQNZzhWNQbbMjduCNWiMv8L3STi0R0cD1Htw]jwilliams@p...[/url
Sent: Thursday, December 18, 2003 2:08 PM
If you run the program in your BASIC Stamp editor it will open a DEBUG
window and you'll see the data -- yes, ASCII strings. Now, close the
BASIC Stamp editor (which will free the programming comm port) and run
your VB program selecting the comm port you use for programming. The
baud rate will be 9600.
It will be up to your VB program to parse and process the data.
The example below was not intended to be THE answer, just something to
get you started. Now that you can see how the "simulator" is done, you
can adjust any way you choose.
-- Jon Williams
-- Dallas Office
Sent: Thursday, December 18, 2003 1:35 PM
I need it to change the 0001 field also
Sent: Thursday, December 18, 2003 8:55 AM
Do you care about baud rate? If your PC program will work with the
Stamp's DEBUG output (9600 baud) then you can use this as-is, otherwise
change it to SEROUT (on pin 16 if you want to use the programming port)
for the baud you need.
In your example the only fields that changed were the index and the
third so this little demo does that (using RANDOM to change field 3).
' {$STAMP BS2}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 2000
LOOP
END
Sent: Thursday, December 18, 2003 8:27 AM
Subject: [noparse][[/noparse]basicstamps] Serial Data from stamp
I Need the basic stamp the Input into my Serial port on my PC the
following String, 0001,+032,12.1,-093,-095,04.3,1,014,015
{Then a Pause For 2 Seconds}
0003,+032,12.1,-092,-091,04.3,1,014,015
0004,+032,12.1,-098,-097,04.3,1,014,015
0005,+032,12.1,-095,-099,04.3,1,014,015
0006,+032,12.1,-091,-092,04.3,1,014,015
0007,+032,12.1,-099,-090,04.3,1,014,015
. ect ect
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
it
'{$STAMP BS2}
'{$PORT COM1}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 200
LOOP
END
program
-- Jon Williams
-- Dallas Office
' {$STAMP BS2}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 2000
LOOP
END
. ect ect
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
every 3 seconds in VB to Toggle data Coming into VB
From: Brian E Boothe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j_SupX07FCxLYEM0WEkR9EI5BRAy6Yxam36PLhecNvNGH9tydQUeD53AJ4jFnaMbV469rIiH3W-oiRsR]subrian@m...[/url
Sent: Thursday, December 18, 2003 2:42 PM
Subject: [noparse][[/noparse]basicstamps] Serial Data from stamp(rev 1)
it
'{$STAMP BS2}
'{$PORT COM1}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 200
LOOP
END
program
From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Kda0u32RiGhRhVaOQkvpSkWf4vfHGoNwcq_kRV9oR-kRb06GZQzy0tsYO9kgo9qudAdUMzrknOn1s6GFpIe7t5o]jwilliams@p...[/url
-- Jon Williams
-- Dallas Office
' {$STAMP BS2}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 2000
LOOP
END
. ect ect
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
DTR transistion Can u help ?? Code has (1) form (1) timer and (1)Label
Private Sub Form_Load()
'Set the port number
MSComm1.CommPort = 1
' Other settings
MSComm1.Settings = "9600,n,8,1"
MSComm1.InBufferSize = 1024
MSComm1.OutBufferSize = 1024
MSComm1.RThreshold = 40
MSComm1.SThreshold = 5
MSComm1.InputLen = 40
'MSComm1.ParityReplace = "?"
MSComm1.RTSEnable = True
MSComm1.DTREnable = True
MSComm1.NullDiscard = False
MSComm1.Handshaking = comNone
' Open the port
MSComm1.PortOpen = True
End Sub
Private Sub MSComm1_OnComm()
' variable to store fetched data
Static strData As String
With MSComm1
Select Case .CommEvent
Case comEventBreak
MsgBox "Error", "1comEventBreak"
Case comEventFrame
MsgBox "Error", "1comEventFrame"
Case comEventOverrun
MsgBox "Error", "1comEventOverrun"
Case comEventRxOver
MsgBox "Error", "1comEventRxOver"
Case comEventRxParity
MsgBox "Error", "1comEventRxParity"
Case comEventTxFull
MsgBox "Error", "1comEventTxFull"
Case comEventDCB
MsgBox "Error", "1comEventDCB"
Case comEvReceive
' store fetched data in the variable
strData = strData & MSComm1.Input + vbCrLf
Label1.Caption = strData
testStr = strData
MSComm1.Output = vbCrLf
' reinitialze strData for next fetch
' Node1 = Left(strData, 4)
' Label2.Caption = Node1
' Split serial Data into an array
'testarray = SplitMod(testStr, ",", "'")
' If testarray(0) = "0001" Then N = N + 1
' Label3.Caption = testarray(0)
' Label4.Caption = testarray(1)
' Label5.Caption = testarray(2)
'Label6.Caption = testarray(3)
'Label7.Caption = testarray(4)
' Label8.Caption = testarray(5)
' Label9.Caption = testarray(6)
' Label10.Caption = testarray(7)
'--- write array to a text File
' Open "C:/Data.txt" For Append As #1
' Write #1, testarray(1) & " " & testarray(2) & " " &
testarray(3) & " " & " " & testarray(4)
' Close #1
' Label11.Caption = N
strData = ""
End Select
End With
End Sub
Private Sub Timer1_Timer()
If MSComm1.DTREnable = True Then
MSComm1.DTREnable = False
Else
End If
End Sub
From: Brian E Boothe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=o6fy_CHi4qg8zLgHkvqplKoqCZ81Y67pt27n8mc5mhtiDGjeuQPZh5Z2lc7BQXZ4pFvwkz7L5iO4lw]subrian@m...[/url
Sent: Thursday, December 18, 2003 2:51 PM
Subject: RE: [noparse][[/noparse]basicstamps] Serial Data from stamp(rev 1)
o.k I got the DTR problem Fixed all I need to do is Drop the DTR Line
it
'{$STAMP BS2}
'{$PORT COM1}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 200
LOOP
END
program
From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tSHUqIQ2lS7RA3hCOEGJFT1HD9qjkzOVn8pyoTvj6WVY9uYX8bx16shU9R36TyTIvNkrawDXSvLDOWpReEZ49-M]jwilliams@p...[/url
-- Jon Williams
-- Dallas Office
' {$STAMP BS2}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 2000
LOOP
END
. ect ect
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
said, you may find the following Nuts & Volts article useful:
http://www.parallax.com/dl/docs/cols/nv/vol3/col/89.pdf
You can download VB code for the article from the Parallax web site.
-- Jon Williams
-- Dallas Office
From: Brian E Boothe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pg05R_TrBnfTUdTQpBl6GopQOh2yPbEFtqTxHm0F1NiTxnGciKuTrB1d7RmLkoMIkM3taOMrzfdi]subrian@m...[/url
Sent: Thursday, December 18, 2003 3:17 PM
Here is my VBcode but my Label1.caption is moving Down the form on every
' Other settings
' Open the port
End Sub
With MSComm1
Case comEventBreak
Case comEventFrame
Case comEventRxOver
Case comEventTxFull
Case comEventDCB
Case comEvReceive
testStr = strData
' Close #1
strData = ""
End Select
End With
End Sub
Else
End If
End Sub
it
'{$STAMP BS2}
'{$PORT COM1}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 200
LOOP
END
program
From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=b94NJ3auTE1YtOggiiXslO4Vhp--3kS2tKv6VPPtR1fYARtwak-wjqokP-H6EhNboEHHZyT2-_UdV6cnX0SaN6o]jwilliams@p...[/url
-- Jon Williams
-- Dallas Office
' {$STAMP BS2}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 2000
LOOP
END
. ect ect
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
1. The BOE uses the DTR line as a 'RESET' for the BS2.
When you set DTREnable 'TRUE', you are resetting the
BS2. If you don't want to reset the BS2, set DTREnable
to 'false'.
2. I always use SEROUT 16, BaudRate, [noparse][[/noparse]"MyData"]
to send debug data to the serial port. I don't want
to depend on the 'DEBUG' keyword to do anything
other than DEBUG messages.
3. When you send "vbCRLF" out to the BS2, it is
immediately being echoed back to you by the BS2.
That's how the BS2 232 receive circuit works.
So you need to toss the first 'CR' 'LF' chars that
come back to your VB program.
--- In basicstamps@yahoogroups.com, "Brian E Boothe" <subrian@m...>
every
Label
> ' Other settings
> ' Open the port
> End Sub
> With MSComm1
> Case comEventBreak
> Case comEventFrame
> Case comEventRxOver
> Case comEventTxFull
> Case comEventDCB
> Case comEvReceive
> testStr = strData
> ' Close #1
> strData = ""
> End Select
> End With
> End Sub
> Else
> End If
> End Sub
> From: Brian E Boothe [noparse][[/noparse]mailto:subrian@m...]
Line
flash,,
that's
> it
> '{$STAMP BS2}
> '{$PORT COM1}
> ' $PBASIC 2.5}
> idx VAR Word
> field3 VAR Word
> Setup:
> idx = 1
> Main:
> DO
> RANDOM field3
> CR
> idx = idx + 1
> PAUSE 200
> LOOP
> END
> program
> From: Jon Williams [noparse][[/noparse]mailto:jwilliams@p...]
DEBUG
the
run
The
to
you
> -- Jon Williams
> -- Dallas Office
otherwise
port)
3).
> ' {$STAMP BS2}
> ' $PBASIC 2.5}
> idx VAR Word
> field3 VAR Word
> Setup:
> idx = 1
> Main:
> DO
> RANDOM field3
> CR
> idx = idx + 1
> PAUSE 2000
> LOOP
> END
> . ect ect
Subject
> Yahoo! Groups Links
> abuse@p...
Subject
> Yahoo! Groups Links
Subject
> Yahoo! Groups Links
> abuse@p...
Subject
> Yahoo! Groups Links
Subject
> Yahoo! Groups Links
Subject
> Yahoo! Groups Links
Subject
> Yahoo! Groups Links
