Serial Data from stamp(cont 2)
iS that going to Come thru the serial Port as a ASCII String ? also
From: Brian E Boothe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JOhIcTAlGxSHfkImaWxCIubiqKGep9H0yzrplLy6VysNgGUJoHvw48fYRJzSxTLmlPCIi6Pt-YLNUmM]subrian@m...[/url
Sent: Thursday, December 18, 2003 11:14 AM
Subject: RE: [noparse][[/noparse]basicstamps] Serial Data from stamp(2)
Do I use the same Serial Cable I program with, > to get the data with VB
from my PC ? ? with the program below. ?
Do you care about baud rate? If your PC program will work with the
Stamp's DEBUG output (9600 baud) then you can use this as-is, otherwise
change it to SEROUT (on pin 16 if you want to use the programming port)
for the baud you need.
In your example the only fields that changed were the index and the
third so this little demo does that (using RANDOM to change field 3).
' {$STAMP BS2}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
field3 = field3 // 10 + 90
DEBUG DEC4 idx, ",+032,12.1,-", DEC3 field3, ",-095,04.3,1,014,015",
CR
idx = idx + 1
PAUSE 2000
LOOP
END
Sent: Thursday, December 18, 2003 8:27 AM
Subject: [noparse][[/noparse]basicstamps] Serial Data from stamp
I Need the basic stamp the Input into my Serial port on my PC the
following String, 0001,+032,12.1,-093,-095,04.3,1,014,015
{Then a Pause For 2 Seconds}
0003,+032,12.1,-092,-091,04.3,1,014,015
0004,+032,12.1,-098,-097,04.3,1,014,015
0005,+032,12.1,-095,-099,04.3,1,014,015
0006,+032,12.1,-091,-092,04.3,1,014,015
0007,+032,12.1,-099,-090,04.3,1,014,015
. ect ect
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
' {$STAMP BS2}
' $PBASIC 2.5}
idx VAR Word
field3 VAR Word
Setup:
idx = 1
Main:
DO
RANDOM field3
CR
idx = idx + 1
PAUSE 2000
LOOP
END
. ect ect
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Yahoo! Groups Links
