Shiftout
Hello guys!
First a little background. I just found this group today and it looks
awesome. I look forward to learning from all of you!
I have had a little experience with the 68HC11 in the past, however I
have just got my BS2-SX and trying to learn the code.
In particular, one line (I'm sure is trivial to you guys!) I am
having trouble understanding.
SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%10\2,Value]
It is used to write info to a RTC....
I understand most of it but eh "%0\1" and "%10\2"
I understand the \1 and \2 pertain to the amount of bits being
shifted in, but what do the other numbers reference? Is the %0 a
binary 0 for the LSB and the %10 a binary 2 in the MSB? Then what
about Value, how does the variable fit in?
Thanks for you help.
specified with %, hex are specified with $. So, you got it right. With
SHIFTOUT and SHIFTIN, if the bits parameter is not specified then eight
bits is assumed, so value will be clocked out in eight bits.
-- Jon Williams
-- Dallas Office
From: adamsabados2000@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MEgBjkzzVbiEswF-b-pix7AgKN7TjVrRbHfMQCNe2m9Ae5RyRzrTb7ld9kftudBdGk7hWvjzRFbAVmqvAu0]adamsabados2000@y...[/url
Sent: Tuesday, December 16, 2003 7:15 PM
Subject: [noparse][[/noparse]basicstamps] SHIFTOUT
Hello guys!
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Suppose
RTCCmd=%11010 ' the command to the device
and
Value=%11001100 ' the value that needs to be transmitted for the
command to act on
Then reading from left to right as time progression, this is what the
SHIFTOUT will send:
0 01011 01 00110011
The spaces are for clarity in connection with the example syntax.
Each group of 1, then 5, then 2, then 8 is sent in succession, and
each one is sent least significant bit first. Those need to be put
together with some fillers, so a total of 16 bits is transmitted.
Another way to accomplish this would be to assemble it all into one
word, and then send that:
x VAR Word
x = Value<<8 + %10 << 5 + RTCCmd << 1 ' operations left to
right, makes x= %1100110010110100
SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]x\16] ' send all 16 bits.
-- Tracy
I think I've got the hang of it now!
