max 7219 code
Does anyone have any simple working code for a Max7219 with BS2?
Mine doesn't work (it's listed at the bottom of this message). It
just doesn't seem to sync properly.
It acts like their's no common ground connection between the 7219
board and the Stamp board, but there IS a ground wire connecting
them.
'{$STAMP BS2}
'{$PBASIC 2.5}
SCK CON 6 'Clock pin
LOAD CON 7 'Load pin
DIN CON 8 'Data pin
x VAR Byte
OUTPUT 6:OUTPUT 7:OUTPUT 8
LOW LOAD:LOW SCK:LOW DIN
PAUSE 100
SHIFTOUT DIN,SCK,MSBFIRST,[noparse][[/noparse]$0a] 'intensity = full
SHIFTOUT DIN,SCK,MSBFIRST,[noparse][[/noparse]$0f]
PULSOUT LOAD,1
SHIFTOUT DIN,SCK,MSBFIRST,[noparse][[/noparse]$0b] 'scan limit 4 digits
SHIFTOUT DIN,SCK,MSBFIRST,[noparse][[/noparse]$03]
PULSOUT LOAD,1
SHIFTOUT DIN,SCK,MSBFIRST,[noparse][[/noparse]$09] 'decode mode for 4 digits
PULSOUT LOAD,1
SHIFTOUT DIN,SCK,MSBFIRST,[noparse][[/noparse]$0c] 'normal operation
SHIFTOUT DIN,SCK,MSBFIRST,[noparse][[/noparse]$01]
PULSOUT LOAD,1
PULSOUT LOAD,1
END
them.
'{$STAMP BS2}
'{$PBASIC 2.5}
DIN CON 8 'Data pin
x VAR Byte
PAUSE 100
PULSOUT LOAD,1
PULSOUT LOAD,1
PULSOUT LOAD,1
PULSOUT LOAD,1
PULSOUT LOAD,1
END
