One Line Breaks Code?
Frank-
The LCDIN instruction leaves the four data bus pins in input mode.
Your LCD_Command and LCD_Write routines assume those pins are in
output mode (they were placed in output mode wey are in output mode
once by the DIRL statement). As a result, after executing the LCDIN
your Stamp program is no longer controlling the output states of the
data bus pins, and further attempted writes to the LCD are
ineffective.
It's one outcome of mixing the BS2 & BS2p* approaches as Jon
remarked.
You might also check the LCD's R/W* pin. It doesn't seem to be
manipulated by your program, so the program may assume it's always in
the Write state. The circuit may be hardwired to accomplish that,
which would mean you can't read from the LCD unless you run the
wire from the R/W* pin to I/O 2 instead. Then manipulate it in your
own software (BS2 approach) or let the LCDIN/LCDOUT instructions work
for you (BS2p*).
Steve
ineffective.
remarked.
for you (BS2p*).
Steve
I have added:
' Two new lines of code
PAUSE 250
LCDIN 0, $C0 + 0, [noparse][[/noparse]char]
The stamp directive was modified to read:
' {$STAMP BS2pe}
I am using a iNex 1000 24/40 board with a BS2pe.
The unmodified code runs perfect. The modified code I think hangs
the stamp. Anyway, all mods to the LCD stop.
I have a larger program for a project of mine. The LCD wouldn't
update. After deleting all the non-LCD code, I noticed what remained
was a modified version of Ex. 12.
Changed two lines of Ex. 12 and bam. LCD quit updating.
What do you think?
Below is the offending code.
Frank
' File...... Ex12 - LCD Characters.BS2
' Purpose... Custom LCD Characters
' Author.... Parallax
' E-mail.... stamptech@p...
' Started...
' Updated... 01 MAY 2002
' {$STAMP BS2pe}
' Program Description
' This program demonstrates custom character creation and animation
on a
' character LCD.
' The connections for this program conform to the BS2p LCDIN and
LCDOUT
' commands. Use this program for the BS2, BS2e or BS2sx. There is a
separate
' program for the BS2p.
' I/O Definitions
E CON 0 ' LCD Enable pin (1
= enabled)
RS CON 3 ' Register Select (1
= char)
LCDbus VAR OUTB ' 4-bit LCD data bus
' Constants
ClrLCD CON $01 ' clear the LCD
CrsrHm CON $02 ' move cursor to home
position
CRSRLF CON $10 ' move cursor left
CRSRRT CON $14 ' move cursor right
DispLf CON $18 ' shift displayed
chars left
DispRt CON $1C ' shift displayed
chars right
DDRam CON $80 ' Display Data RAM
control
CGRam CON $40 ' Custom character RAM
Line1 CON $80 ' DDRAM address of
line 1
Line2 CON $C0 ' DDRAM address of
line 2
' Variables
char VAR Byte ' character sent to
LCD
newChar VAR Byte ' new character for
animation
index1 VAR Byte ' loop counter
index2 VAR Byte ' loop counter
' EEPROM Data
Msg1 DATA "THE BASIC STAMP " ' preload EEPROM with
messages
Msg2 DATA " IS VERY COOL! ", 3
CC0 DATA $0E, $1F, $1C, $18, $1C, $1F, $0E, $00 '
character 0
CC1 DATA $0E, $1F, $1F, $18, $1F, $1F, $0E, $00 '
character 1
CC2 DATA $0E, $1F, $1F, $1F, $1F, $1F, $0E, $00 '
character 2
Smiley DATA $00, $0A, $0A, $00, $11, $0E, $06, $00 '
smiley face
' Initialization
Initialize:
DIRL = %11111101 ' setup pins for LCD
LCD_Init:
PAUSE 500 ' let the LCD settle
LCDbus = %0011 ' 8-bit mode
PULSOUT E, 1
PAUSE 5
PULSOUT E, 1
PULSOUT E, 1
LCDbus = %0010 ' 4-bit mode
PULSOUT E, 1
char = %00101000 ' multi-line mode
GOSUB LCD_Command
char = %00001100 ' disp on, crsr off,
blink off
GOSUB LCD_Command
char = %00000110 ' inc crsr, no disp
shift
GOSUB LCD_Command
Download_Chars: ' download custom
chars to LCD
char = CGRam ' point to CG RAM
GOSUB LCD_Command ' prepare to write CG
data
FOR index1 = CC0 TO (Smiley + 7) ' build 4 custom chars
READ index1, char ' get byte from EEPROM
GOSUB LCD_Write ' put into LCD CG RAM
NEXT
' Program Code
Main:
char = ClrLCD ' clear the LCD
GOSUB LCD_Command
PAUSE 250
FOR index1 = 0 TO 15 ' get message from
EEPROM
READ (Msg1 + index1),char ' read a character
GOSUB LCD_Write ' write it
NEXT
PAUSE 2000 ' wait 2 seconds
Animation:
FOR index1 = 0 TO 15 ' cover 16 characters
READ (Msg2 + index1), newChar ' get new char from
2nd message
FOR index2 = 0 TO 4 ' 5 characters in
animation cycle
char = Line2 + index1 ' set new DDRAM
address
GOSUB LCD_Command
LOOKUP index2, [noparse][[/noparse]0, 1, 2, 1, newChar], char
GOSUB LCD_Write ' write animation
character
PAUSE 50 ' delay between
animation chars
NEXT
NEXT
PAUSE 250
PAUSE 1000
GOTO Main
' do it all over
END
' Subroutines
LCD_Command:
LOW RS ' enter command mode
LCD_Write:
LCDbus = char.HIGHNIB ' output high nibble
PULSOUT E, 1 ' strobe the Enable
line
LCDbus = char.LOWNIB ' output low nibble
PULSOUT E, 1
HIGH RS ' return to character
mode
RETURN
http://www.parallax.com/detail.asp?product_id=27297
you will find a link to a ZIP file with the experiment files. Inside
there is a BS2p version of all the experiments. Start with that since
the BS2pe supports the same LCD commands as the BS2p. This would be a
better place to start than using BS2 code (that doesn't have native
support for LCD).
-- Jon Williams
-- Dallas Office
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ii9UnaUkPhGYVcFiIigevuG_w4WN6enmJpCSOjSNeEtPXaGUxM230Y53kMoFGMXCmwSyl8E5b2drrxksEw]franksmith512@y...[/url
Sent: Saturday, December 13, 2003 10:14 AM
Subject: [noparse][[/noparse]basicstamps] One Line Breaks Code?
Below is a copy of Exercise 12 from Stamp Works. These are the lines
I have added:
PAUSE 250
' {$STAMP BS2pe}
What do you think?
Frank
' Started...
' {$STAMP BS2pe}
on a
' character LCD.
LCDOUT
separate
' I/O Definitions
= enabled)
= char)
' Constants
position
chars left
chars right
control
line 1
line 2
' Variables
LCD
animation
' EEPROM Data
messages
character 0
character 1
character 2
smiley face
' Initialization
Initialize:
LCD_Init:
PULSOUT E, 1
PAUSE 5
PULSOUT E, 1
PULSOUT E, 1
PULSOUT E, 1
GOSUB LCD_Command
blink off
GOSUB LCD_Command
shift
GOSUB LCD_Command
chars to LCD
data
NEXT
' Program Code
Main:
GOSUB LCD_Command
PAUSE 250
EEPROM
NEXT
Animation:
2nd message
animation cycle
address
GOSUB LCD_Command
character
animation chars
NEXT
NEXT
PAUSE 250
PAUSE 1000
GOTO Main
' do it all over
END
' Subroutines
LCD_Command:
LCD_Write:
line
PULSOUT E, 1
mode
RETURN
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
That is just sooo much better. I have already updated my project and
it now works great!
Frank
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> At the bottom of the StampWorks product page:
Inside
since
be a
> support for LCD).
> -- Jon Williams
> -- Dallas Office
> From: franksmith512 [noparse][[/noparse]mailto:franksmith512@y...]
lines
> I have added:
> PAUSE 250
> ' {$STAMP BS2pe}
remained
> What do you think?
> Thanks,
> Frank
> ' Started...
> ' {$STAMP BS2pe}
> on a
> ' character LCD.
> LCDOUT
a
> separate
> ' I/O Definitions
(1
> = enabled)
(1
> = char)
> ' Constants
home
> position
> chars left
> chars right
> control
RAM
> line 1
> line 2
> ' Variables
> LCD
> animation
> ' EEPROM Data
with
> messages
> character 0
> character 1
> character 2
> smiley face
> ' Initialization
> Initialize:
> LCD_Init:
> PULSOUT E, 1
> PAUSE 5
> PULSOUT E, 1
> PULSOUT E, 1
> PULSOUT E, 1
> GOSUB LCD_Command
off,
> blink off
> GOSUB LCD_Command
> shift
> GOSUB LCD_Command
> chars to LCD
CG
> data
chars
EEPROM
RAM
> NEXT
> ' Program Code
> Main:
> GOSUB LCD_Command
> PAUSE 250
> EEPROM
> NEXT
> Animation:
characters
> 2nd message
> animation cycle
> address
> GOSUB LCD_Command
> character
> animation chars
> NEXT
> NEXT
> PAUSE 250
> PAUSE 1000
> GOTO Main
> ' do it all over
> END
> ' Subroutines
> LCD_Command:
> LCD_Write:
> line
> PULSOUT E, 1
> HIGH RS ' return to
character
> mode
> RETURN
Subject
> abuse@p...
BS2pe. I had tied it to ground after Jon's message, but quickly
reconnected to P2. For clarity, Jon didn't tell me to make that
change. It was my own thought to ground R/W.
I have made the switch in code as suggested by Jon.
Frank
--- In basicstamps@yahoogroups.com, "S Parkis" <parkiss@e...> wrote:
> Frank-
> ineffective.
> remarked.
in
your
work
> for you (BS2p*).
> Regards,
> Steve
-- Jon Williams
-- Parallax
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mt7YxsCBT6wXGdI7zZ9oqYPqb42QrvUdqkrwTYjGDH4I_nSq39iJB_XI_LRqofqyWjuB7HmviICnHcvtUg]franksmith512@y...[/url
Sent: Saturday, December 13, 2003 5:15 PM
Subject: [noparse][[/noparse]basicstamps] Re: One Line Breaks Code?
Jon,
it now works great!
Frank
Inside
since
be a
> support for LCD).
> -- Jon Williams
> -- Dallas Office
lines
> I have added:
> PAUSE 250
> ' {$STAMP BS2pe}
remained
> What do you think?
> Thanks,
> Frank
> ' Started...
> ' {$STAMP BS2pe}
> on a
> ' character LCD.
> LCDOUT
a
> separate
> ' I/O Definitions
(1
> = enabled)
(1
> = char)
> ' Constants
home
> position
> chars left
> chars right
> control
RAM
> line 1
> line 2
> ' Variables
> LCD
> animation
> ' EEPROM Data
with
> messages
> character 0
> character 1
> character 2
> smiley face
> ' Initialization
> Initialize:
> LCD_Init:
> PULSOUT E, 1
> PAUSE 5
> PULSOUT E, 1
> PULSOUT E, 1
> PULSOUT E, 1
> GOSUB LCD_Command
off,
> blink off
> GOSUB LCD_Command
> shift
> GOSUB LCD_Command
> chars to LCD
CG
> data
chars
EEPROM
RAM
> NEXT
> ' Program Code
> Main:
> GOSUB LCD_Command
> PAUSE 250
> EEPROM
> NEXT
> Animation:
characters
> 2nd message
> animation cycle
> address
> GOSUB LCD_Command
> character
> animation chars
> NEXT
> NEXT
> PAUSE 250
> PAUSE 1000
> GOTO Main
> ' do it all over
> END
> ' Subroutines
> LCD_Command:
> LCD_Write:
> line
> PULSOUT E, 1
> HIGH RS ' return to
character
> mode
> RETURN
Subject
> abuse@p...
abuse@p....
wasn't paying attention to connections; I thought it best to start at
the bottom and work upward.
-- Jon Williams
-- Parallax
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=82KCyxrIt9SGdDMosSPFjnoLA9hOv-ZJYudpOmf2w_XrXW-H3DKPLyArS7KY4EYPN-iBwNNk9HfejPuBW1aLpQ]franksmith512@y...[/url
Sent: Saturday, December 13, 2003 5:21 PM
Steve, The R/W pin is apparrently still being manipulated by the
Frank
> Frank-
> ineffective.
> It's one outcome of mixing the BS2 & BS2p* approaches as Jon remarked.
in
> which would mean you can't read from the LCD unless you run the wire
your
work
> for you (BS2p*).
> Regards,
> Steve
abuse@p....
