Suggestions Wanted: Stamp Control of aDrill
Tim,
I'm not sure SSRs like PWM. I know some don't, but it may be fine on others.
Someone who knows more will probably chime in. You could consider an
H-bridge for variable speed and reverse.
Jonathan
www.madlabs.info
Sent: Friday, December 12, 2003 10:28 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Suggestions Wanted: Stamp Control of aDrill
> Could you take the SSR idea a step further and do PWM on it? Make that
boring drill variable speed?
> >>> jjf@p... 12/12/03 12:02PM >>>
> check out my web site for schematics that specify parts numbers and
values.
> jim
> http://www.geocities.com/jimforkin2003/
> From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=twGaWn6FPi3Aav34zpqVpAbb8gfqHS2ocqx2jEqGveR9b4l9Ydhsrn76wksNAQY-hTyN3-9rYqsg6CaDkdogLg]franksmith512@y...[/url
> Sent: Friday, December 12, 2003 12:19 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Suggestions Wanted: Stamp Control of a Drill
> Jim,
> Could you, or anyone else out there, give a part number for the
> transistor. Am just a software guy. There is a really common NPN I
> believe, but can't think of the part #.
> Thanks,
> Frank
> --- In basicstamps@yahoogroups.com, "Jim Forkin" <jjf@p...> wrote:
> > I would just use a transistor on the output of a stamp and control
> a solid
> > state relay such as a crydon D1210 and just lock the trigger on the
> drill to
> > the on position. This would switch the AC on and off as necessary.
> > jim
> Body of the message will be ignored.
Jonathan
www.madlabs.info
values.
> jim
> Jim,
> Thanks,
> Frank
> a solid
> drill to
> > jim
motor wouldn't work if you happened to output PWM in such a way that you
clipped the upper half of the AC wave, leaving only the lower half, which
might be a reality, even if the SSR latency was instantaneous.
On Fri, 12 Dec 2003, Jonathan Peakall wrote:
> Tim,
> Jonathan
> www.madlabs.info
> From: "Tim Hart" <tim.hart@h...>
> values.
> > jim
> > From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eLIFDk8Wc-CHgN0izSFHBLatQSUHlUO_uknzGgj-iiS1XQ8-M6NECwsev6ldnnvGPxoRM7TRP4kUlq4sZrnFLag]franksmith512@y...[/url
> > Jim,
> > Thanks,
> > Frank
> > a solid
> > drill to
> > > jim
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
Anyone have code examples for using DS1302N as timekeeping with my BS2
Rene
http://www.parallax.com/dl/docs/prod/appkit/ds1302%20rtc.pdf (app
Kit)
http://www.parallax.com/dl/docs/prod/datast/ds1302.pdf (data sheet
if you wanted it also)
Arridh
--- In basicstamps@yahoogroups.com, rene genest <rene.genest@q...>
wrote:
> Hi!
BS2
> Thanks
> Rene
document, experment #30.
Geoffrey
wrote:
> Hi!
BS2
> Thanks
> Rene
Thank you very much, I took a look and it sound good to me. I have a project
with need time keeping, I used a pocketwatch but it pull to much current for
my application .
Rene
geoffreypaullewis a
