Non-contact voltage detection?
Archiver
Greetings all. I have a standby generator at work with an attitude
problem. Occasionally the transfer switch will start the generator,
but due to either the field or main breaker on the generator popping,
no power is supplied. The transfer switch is smart enough to
recognize that no power is being supplied by the generator and
prevent the switch from transferring.
The transfer switch has a set of dry contacts that I can use to tell
if it is in its exercise cycle, so I'm just looking for something
that will tell me if there is any power flowing through the lines
from the generator.
Is this something I can do with a Hall Effect sensor? I know that
there are all manner of current transformers available, and I'm
looking at that down the road to actually gather information on the
generator, but at this time I'm only looking to see if there is
current flowing down the wire.
Thanks in advance,
Brian
from the generator.
Thanks in advance,
Brian
from the generator.
Thanks in advance,
Brian
phase, 125 KW. Inside the building it steps down to 120/208. I've
got reasonably easy access to the lines on either side of the
transformer.
generator,
popping,
tell
> from the generator.
> Thanks in advance,
> Brian
bet. Safe, small, easy to use.
Note, when these units start up, they can draw tremendous amounts of
current. Usually they start out as a squirrel cage motor, then change over
to a synchronous motor. It could be the change over relay not sensing very
close to synchronous, or a transient at the synchronous transfer that is
causing it to pop.
From: Brian [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xmPvzu53bpF7Fyw6jMC1r44Cm_QXeVRja9ceJkNRl-HII3XycBEK2FyPugn4ELpQzFzEy-lTiw]n7qjb@m...[/url
Sent: Friday, December 12, 2003 2:41 PM
Subject: [noparse][[/noparse]basicstamps] Re: Non-contact voltage detection?
Whoops. I'm not sure that it matters, but the generator is 480V 3
transformer.
generator,
popping,
tell
> from the generator.
> Thanks in advance,
> Brian
How about a simple relay across one of the circuits that "should" get
emergency power? If the relay drops out, you've got problems and should go
fix them.
Sent: Friday, December 12, 2003 11:40 AM
> transformer.
> generator,
> popping,
> tell
> > from the generator.
> > Thanks in advance,
> > Brian
Knowing this will help determine if the inexpensive hall effects available
ken
