Multi-tasking problem?: need to turn on the lights for 10 seconds while ... — Parallax Forums
edited 2003-12-13 21:22 in General Discussion
hi,
I have 5 human detectors and
I need to turn on 5 110volts lights for differents
amounts of time (i.e. 10 seconds)
But if I place a 10 seconds of pause
(i.e. pause 10000) for the first relay
to close the circuit for 10 seconds,
it will be impossible to detect human
using the other 4 sensors.
Is it a multi-tasking problem ?.
Any help is welcome thanks: Joe
__________________________________
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing.
http://photos.yahoo.com/
    edited 2003-12-12 16:10
    At 08:05 AM 12/12/03 -0800, Joe Terk wrote:
    >hi,
    Not really, just don't pause. Poll the other detectors in lieu of pausing.
    Use a counter to determine when to exit. The "count" will probably have to be
    determined by trial and error. If you're using the BS-2p series there may be
    other avenues as well.
    Bruce Bates
    edited 2003-12-12 16:11
    You can turn on a relay and then go on to look at other sensors then go back
    and turn it off. Just one big loop, or better, write a program that looks
    at sensors and jumps to subroutines to turn on and off the relays. Circuits
    to switch relays can be found at this web site.
    jim
    http://www.geocities.com/jimforkin2003/
    From: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ri2u0fFRVy5_R-GyVetosWbvl04pvIElQhDpiWm6t6FgwJ-LZvznDmvAfXxGOr8GPH-irrf9L1p_meo]joeterk@y...[/url
    Sent: Friday, December 12, 2003 11:06 AM
    Subject: [noparse][[/noparse]basicstamps] Multi-tasking problem?: need to turn on the
    hi,
    Do you Yahoo!?
    edited 2003-12-12 16:18
    Hi Joe,
    You could use a shorter PAUSE together with a subroutine for checking your
    detectors within a FOR loop like this:
    FOR n = 0 TO 99
    PAUSE 100
    GOSUB CheckDetectors
    NEXT
    I hope this helps.
    Best regards,
    Russell Warburton
    email: russell@w...
    website: http://www.warburtech.com
    telephone: +44 (0)7814 044 754
    Sent: Friday, December 12, 2003 4:05 PM
    Subject: [noparse][[/noparse]basicstamps] Multi-tasking problem?: need to turn on the lights
    > hi,
    > Do you Yahoo!?
    edited 2003-12-12 16:24
    This is off the top of my head...
    Main:
    DO
    FOR idx = 0 TO 4
    IF (timer(idx) = 0) THEN
    IF (sensor(idx) = IsOn) THEN
    timer(idx) = TimeDelay
    light(idx) = IsOn
    ELSE
    light(idx) = IsOff
    ENDIF
    ELSE
    timer(idx) = 0
    ENDIF
    NEXT
    PAUSE LoopDelay
    LOOP
    END
    The ideas is to use a small loop delay value (say 100 ms) and run it
    multiple times (the value of TimeDelay) to create your long pauses.
    -- Jon Williams
    -- Dallas Office
    From: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ObG7e656uHQF4ztAdbRd3di96O6V21rBZIhI3oSqGKtKLZZXUHRYPYe6XXlD0oDjLZOnyg1C4gFqdQ]joeterk@y...[/url
    Sent: Friday, December 12, 2003 10:06 AM
    hi,
    Do you Yahoo!?
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-12-12 16:27
    Oops... made a mistake. This is better, and I added comments.
    Main:
    DO
    FOR idx = 0 TO 4 ' loop through channels
    IF (timer(idx) = 0) THEN ' if timer expired, check sensor
    IF (sensor(idx) = IsOn) THEN ' sensor active?
    timer(idx) = TimeDelay ' -- yes, load timer
    light(idx) = IsOn ' -- yes, turn on light
    ELSE
    light(idx) = IsOff ' timer expired, kill
    light output
    ENDIF
    ELSE
    timer(idx) - timer(idx) - 1 ' update this timer
    ENDIF
    NEXT
    PAUSE LoopDelay
    LOOP
    END
    Sent: Friday, December 12, 2003 10:24 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Multi-tasking problem?: need to turn on the
    Main:
    DO
    FOR idx = 0 TO 4
    light(idx) = IsOn
    ELSE
    light(idx) = IsOff
    ENDIF
    ELSE
    timer(idx) = 0
    ENDIF
    NEXT
    PAUSE LoopDelay
    LOOP
    END
    -- Jon Williams
    -- Dallas Office
    From: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Aeug9OdTD3hl0ZRn6uUv5q0d3amtca0qSTCnS7YtTTobWf2XH3DaA06-UJ38FvfvCqTyyUFqzrAimjk]joeterk@y...[/url
    hi,
    Do you Yahoo!?
    abuse@p....
    abuse@p....
    edited 2003-12-12 18:46
    Thanks Jon and thanks to the
    people than answer. Joe
    > comments.
    > Main:
    > DO
    > check sensor
    > active?
    > timer
    > light
    > ELSE
    > light output
    > ENDIF
    > ELSE
    > timer
    > ENDIF
    > NEXT
    > PAUSE LoopDelay
    > LOOP
    > END
    > From: Jon Williams
    > need to turn on the
    > Main:
    > DO
    > FOR idx = 0 TO 4
    > light(idx) = IsOn
    > ELSE
    > light(idx) = IsOff
    > ENDIF
    > ELSE
    > timer(idx) = 0
    > ENDIF
    > NEXT
    > PAUSE LoopDelay
    > LOOP
    > END
    > 100 ms) and run it
    > your long pauses.
    > -- Jon Williams
    > -- Dallas Office
    > From: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h3e6SUGVL29a04sYcGSczOIjPgeeyM2kbImHPuNWowDJrbJWlmJeB39Q6hodp1rqmf1uEFmPAzcXlg]joeterk@y...[/url
    > to turn on the
    > hi,
    > Do you Yahoo!?
    > Text in the Subject
    > report SPAM to
    > abuse@p....
    > Text in the Subject
    > report SPAM to
    > abuse@p....
    > Text in the Subject and Body of the message will be
    > ignored.
    Do you Yahoo!?
    edited 2003-12-12 20:47
    This technique works great as long as
    1. The actual PAUSE doesn't take too long since it blocks looking at
    the sensors during the PAUSEs.
    2. The variable timing of the code part of the loop causes an
    acceptable error in the time required for the lights being on.
    For lighting lights after a person is detected, the above conditions
    are probably met.
    If the conditions are not met for your application, you can use
    external timers in a Co-Processor (or other circuit) to get more
    accurate timing.
    I have a lot of information about timers and how to use them on my
    website www.bluebelldesign.com. You can just learn about timers there
    or you can buy our products which feature our Co-Processor which
    includes timers (and ramping servo controllers, A/D, ...).
    By the way, yes, it is multi-tasking but don't let that scare you. [noparse];)[/noparse]
    As you can see from Jon's example, it isn't always as complicated as
    it sounds.
    Harry
    Stamp Robotics to the next level
    --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
    > Main:
    > DO
    channels
    check sensor
    light
    > ELSE
    > light output
    > ENDIF
    > ELSE
    > ENDIF
    > NEXT
    > PAUSE LoopDelay
    > LOOP
    > END
    <snip>
    > From: Joe Terk [noparse][[/noparse]mailto:joeterk@y...]
    > hi,
    edited 2003-12-13 02:06
    Hi Jon!
    On thoses codes you wrote " ELSE", what is it for? I do not have that command
    word in any of my books
    Thank you!
    Jon Williams a
    edited 2003-12-13 18:37
    Yes, PBasic 2.5 now has a true 'ELSE' keyword, yay.
    Note MOST 'old' examples (and the 1.33 version of
    the compiler) are the 'original' PBasic, which only
    has an 'IF.. THEN <Goto Destination>' form.
    --- In basicstamps@yahoogroups.com, rene genest <rene.genest@q...>
    wrote:
    > Hi Jon!
    that command
    > Thank you!
    > Jon Williams a
    IF-THEN-ELSE is a standard programming structure in modern versions of BASIC.
    It is now available in PBASIC 2.5. PBASIC 1.0 (BS1) and PBASIC 2.0 use only the
    IF-THEN {GOTO Address} structure which is very close the the machine language it
    calls.
    With IF-THEN-ELSE think of it this way: IF some condition is true, THEN do this
    block of code, ELSE do this block of code:
    IF (condition) THEN
    ' code for condition is True
    ELSE
    ' code for condition if not True
    ENDIF
    -- Jon Williams
    -- Dallas Office
    From: rene genest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=m2FAaPu800ry_efPt7dsVZ8gmX2jaV7uL55AEANn8-5uEonev3SXo1VqkLwUh3i02WRbX2ax48iMEVAKwA]rene.genest@q...[/url
    Sent: Friday, December 12, 2003 8:07 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Multi-tasking problem?: need to turn on the lights
    Hi Jon!
    Thank you!
    Jon Williams a
