Comment out a block of code? Yes, there is ...
No questions are stupid.
There is a trivial way to do what you want.
Read PBasic Compiler 2.0 Beta 2.pdf pages 1 and 8.
Page 2 tells you how to turn on PBasic 2.5, i.e.,
' {PBASIC 2.5}
It is a compiler directive.
Page 8 explains how to use the #define and #if compiler directives.
I haven't used this with the PBasic compiler, but many others.
It should look something like:
' {PBASIC 2.5}
#DEFINE IncludeLines = 1
#IF IncludeLines = 1 #THEN
blah, blah blah this stuff is included and will cause
compile errors
#ENDIF
Take care,
Frank
--- In basicstamps@yahoogroups.com, laurasdog@w... wrote:
> Sorry in advance for the stupid question...
> Is it possible to "comment out" a whole block of
> code at once for testing, or do I have to do it
> 'one
> 'damned
> 'line
> 'at
> 'a
> 'time?
> Is kind of a pain to disable several dozen lines
> at once sometimes.
> Is there an easy way out?
> Thanks much!
> Steve D. - official newbie stamper
' {PBASIC 2.5}
' {PBASIC 2.5}
compile errors
#ENDIF
Take care,
Frank
> 'one
> 'damned
> 'line
> 'at
> 'a
> 'time?
> at once sometimes.
> Thanks much!
That said, the result is the same (with a tad more work) and it's a
clever use of the process that I should have thought of myself since I
often use it to selectively enable/diable DEBUG output.
You can simplify a bit:
#DEFINE _DebugOn = 1
#IF _DebugOn #THEN
' block of code
#ENDIF
Conditional compilation symbols are either defined or are not, so you
don't need to check for a value in the #IF-#THEN block. My personal
preference is to prefix conditional compilation symbols with an
underscore so I know they are different from standard constants.
Happy Holidays.
-- Jon Williams
-- Dallas Office
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Rtpx582ycDB3j15duqnmjatOYr-FdLziZodOV30zflE9PVkVClXF8gD0BxlVpEyK1SFzTR-yNekCp7rGB_oiat4]franksmith512@y...[/url
Sent: Thursday, December 11, 2003 7:14 PM
Subject: [noparse][[/noparse]basicstamps] Re: Comment out a block of code? Yes, there is
' {PBASIC 2.5}
' {PBASIC 2.5}
compile errors
#ENDIF
Take care,
Frank
> 'one
> 'damned
> 'line
> 'at
> 'a
> 'time?
> at once sometimes.
> Thanks much!
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
