Beginner - Baud Rate Question
I am seeing garbage when using SERIN.
The Basic Stamp Manual v2.0c doesn't have a table on or about p. 277
for baud rates for BSP2e.
I need 1200-8-N-1. I have tried 2063 and many others. No success.
Where are the numbers coming from on page 277 for calculating the bit
period? Specifically, the number around 1,000,000?
Am trying to communicate with a measuring tape. DigiTape Plus by
Starrett. It is trivial using the Debug window with the editor. I
do have to check the DTR control before it works though.
How to wire DTR? RS232 Pin 4 to, say, P11? Is the DTR pin
the "\Fpin""?
Frank
the "\Fpin""?
Frank
The BS-2pe uses the same BAUDMODES as the original Stamp BS-2 although that's
not
evident in my manual either. You may find this web page a handy reference:
http://www.emesystems.com/BS2rs232.htm#Baudmode
Hidden away on the L S Starrett web site I found the following baud rate
information: 4800-7-E-1 and based on that a BAUDMODE of (decimal) 8380 or
(hex) $20BC would be appropriate. It additionally states that the output is 16
ASCII characters followed by a CR/LF (carriage return/line feed).
Those are conversion factors for changing BAUD RATE to BAUDMODE. As you can see
there is a mathematical relationship between the two with addition bit settings
as noted in the manual.
>the "\Fpin""?
I would be tempted to try something like this:
measure VAR BYTE(15) ' reserve 16 bytes (numbered 0-15)
dump VAR BYTE(1) ' clear CR/LF (may not be absolutely necessary)
bmode CON 8380 ' 4800-7-E-1
td CON 1000 ' arbitrary time-out value
dpin CON 3 ' data pin port (arbitrary)
fpin CON 4 ' flow control pin port (per your example)
SERIN dpin\fpin,bmode,td,nodata,[noparse][[/noparse]STR measure\16,dump\2]
GOTO data_okay
nodata DEBUG "Data line timed out"
>Thanks,
>Frank
Hope that gives you some more intelligent output.
Bruce Bates
I will give it a try tonight.
Take care,
Frank
277
although that's not
reference:
rate information: 4800-7-E-1 and based on that a BAUDMODE of
(decimal) 8380 or
output is 16 ASCII characters followed by a CR/LF (carriage
return/line feed).
bit
you can see there is a mathematical relationship between the two with
addition bit settings as noted in the manual.
I
> >the "\Fpin""?
necessary)
> GOTO data_okay
> >Thanks,
> >Frank
> Regards,
> Bruce Bates
tests. I don't get any data unless I use it.
Starrett must have changed the protocol for the measuring tape.
Starrett Tech Support says its 1200-N-8-1 which does work perfect
with the debug window.
Parallax tech support says I may be facing one of two problems:
1) The Starrett DigiTape may be parcitic in that it acquires voltage
from the host. This works fine for a PC connection, but the INix
1000 24/40 board is also paricitic.
Soln 1: Use a MAX232 chip
2) The signal from the Starrett tape may not be >= 8.5 volts.
Soln 2: Use a MAX232 chip
While waiting on the MAX232 chip to arrive, I am going to try to
eavesdrop on the serial cable from the DigiTape to the PC.
All info is appreciated!
Frank
