Magnetic Coil — Parallax Forums
Magnetic Coil
edited 2003-12-10 04:34 in General Discussion
I am working on a project that involves turning on a magnetic coil
for brief periods (about 1 second, every 1 minute). The coil should
draw 2-4A at 6V. Can anyone recommend a common transistor that
would enable me to control this device with the BS2? It would also
help to know what other components need to be built into the circuit
to prevent damage to the stamp. I am a beginner as BS users go.
Any help would be appreciated.
Jack Miller
    edited 2003-12-09 19:31
    Treat the coil as if it were a relay - there are several posts in this
    newsgroup about driving relays.
    Is the 2-4A a varying load?, or are you not sure what the actual demand
    from the coil is? If so, use Ohms law (I = V/R) where R is the coil
    resistance and V = 6V to determine the current.
    Select your transistor based on your current requirement X2 as a good
    rule of thumb. Don't forget a diode in reverse bias across your coil
    or transistor (E-C junction) to protect against back EMF from the coil.
    >Thanks,
    >Jack Miller
    edited 2003-12-09 19:58
    First of all what is the inductance? If it has a air core (air core
    coils normally have a low inductance), you can not treated as a relay.
    You can not turn a coil with DC, you have to drive the coil with a
    very short duty cycle or some sort of alternating voltage not
    necessarily a sinewave but a square wave.
    edited 2003-12-09 20:03
    Darlington driver ULN2803, with built in suppression diodes, driving a
    relay.
    Dennis
    From: jlmillerncsu [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RNkJusTe0Ix43axdEdpZ0AwgK1vQNkPtCbKNTUFaGylmQbYV_6VQgrDdCvmkU9Ch1CNjSGRnAg]jmiller@n...[/url
    Sent: Tuesday, December 09, 2003 10:33 AM
    Subject: [noparse][[/noparse]basicstamps] Magnetic Coil
    Jack Miller
    Your use of Yahoo! Groups is subject to
    edited 2003-12-09 20:57
    check out this web site for schematics to do this kind of switching with a
    stamp.
    http://www.geocities.com/jimforkin2003/
    jim
    From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RP-Hd-0jnAy0H8i9m3B4blO3809xkJuR3q5hTjY5geqrCM_uBSD6X15fghUjFm49otFk-lpyYOcHfl61BhYgQre6]bschwabe@a...[/url
    Sent: Tuesday, December 09, 2003 2:32 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Magnetic Coil
    >Thanks,
    >Jack Miller
    edited 2003-12-09 23:32
    Beau,
    Thanks for the reply. The load does not vary; I just have not
    finalized the design of the coil. For the application, I need a
    holding force of about 2 oz. My initial crude experiment used 24 ga
    mag wire around a nail and had about the right degree of grab. The
    problem was that this configuration had a resistance of about .4
    ohm. I am planning to rework device using more turns and 30 ga
    wire. I had estimated that I could get the current draw down to the
    2 - 4A range and still maintain the holding force. I am also
    looking for a source for a standard core of about 1/16 inch if
    anyone knows of such a beast (so that I can abandon the nail
    approach).
    Jack
    --- In basicstamps@yahoogroups.com, "Beau Schwabe" <bschwabe@a...>
    this
    demand
    coil
    good
    coil
    coil.
    should
    also
    circuit
    > >Thanks,
    > >Jack Miller
    edited 2003-12-09 23:36
    Planning on using an iron core. Does this still require a non-DC
    supply?
    --- In basicstamps@yahoogroups.com, "Albert Catano"
    core
    relay.
    Jack, well Radio shack sells some small reed relays that can be
    turned on with a TTL level, but wont support 4 amps. Id use a IRF511
    Vmos FET. It has the back emf diode inside for keeping your bs2 from
    blowing.
    Chris Schur
    --- In basicstamps@yahoogroups.com, "jlmillerncsu" <jmiller@n...>
    should
    circuit
    > Thanks,
    > Jack Miller
