Connect one BasicStamp to Serial Printer (Serial communication)
Dear Friends,
Any person know the topology and program to connect anything serial printer
to one basicstamp bs2p by serial protocol.....
I appreciate if you can help me
best regards
Atentamente.
Ing. Damian Trujillo G.
RIESE & CIA, S.A.
Caracas - Venezuela
) +58-212-7934266/4377
7 +58-212-7940791/0908
+ dtrujillo_riese@c...
best regards
Atentamente.
RIESE & CIA, S.A.
Caracas - Venezuela
to the serial input pin on the printer. Use the debug command like this:
debug" this is a test to print a line on the printer"
if you have the command codes from the printer use them to give instructions to
the printer like return line might be $0A, or magnification ON might be
$1D,$21,1 these are found in the users manual of most printers, you can find
them on the net. you can use them in combination format such as
debug " this is a test",$0A
that would print that line followed by a return line. Hope it helps.
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
