big Brother and big Sister pls help me.( very Long)
Hi All,
I'm a student from singapore currently doing my project on "SMS control and
Monitoring"
So far i think l'm doing quite well as i'm very new to STAMP.
i'm able to sms and receive a reply to my handphone with the temperature
reading.
I have brought : BS2p40 starter kit
siemens modem
DS1624 (temperature sensor)
Amulet LCD.
As i had use up all 26 variable, l'm now in a lost.....
i did some research and i got three methods here.
- use multi-banking ( i don't think i can use this)
- use scratchpad RAM (will this help?)
- EEPROM (24LC32) ( i dun noe how to use it)
i have attach the source code below pls advise me.
i need to reduce the variable for other use.
'{$STAMP BS2p}
'pin0 and pin 3
Siemens modem
'pin 8 and pin 9
DS 1624
'pin 16
Amulet LCD
'============Setting for Siemens modem=================
SEROUT 0, 18447, [noparse][[/noparse]"AT+CMGF=1", CR] 'set text mode
SERIN 3, 18447, [noparse][[/noparse]WAIT("OK")] 'wait for text mode ok reply
'===========Declaring Variable=======================
Number_Str VAR Byte(3) 'for temperature reading
SerString VAR Byte(5) 'for password
MessageAddress VAR Byte(9) 'address to reply SMS
Value1 VAR Byte 'convert to Decimal1
Value2 VAR Byte 'convert to Decimal2
'============temperature variable==============
ADR VAR Byte
DAT VAR Byte
OUT CON 1
IN CON 0
SDA_OUT VAR OUT8
SCL_OUT VAR OUT9
SDA_IN VAR IN8
SDA_DIR VAR DIR8
SCL_DIR VAR DIR9
T VAR Word
O_BYTE VAR Byte
I_BYTE VAR Byte
N VAR Byte
Main:
SEROUT 0, 18447, [noparse][[/noparse]"AT+CMGL=", 34,"rec unread", 34, CR] 'read unread msg,stored
it to be forever UNREAD
SERIN 3,18447,1000, Main,[noparse][[/noparse]WAIT ("+CMGL:"), WAIT(","), WAIT(","), SKIP 4, STR
MessageAddress\8\0, WAIT(13, 10)]
'======password
SERIN 3, 18447,1000, Main, [noparse][[/noparse]WAIT("z"),STR SerString\4] 'if "z" no appear,
program goes back to function start
IF SerString(0) = "t" OR "T" THEN loop2
IF SerString(0) <> "t" OR "T" THEN LCDerror
loop2:
IF SerString(1) = "e" OR "E" THEN loop3
IF SerString(1) <> "e" OR "E" THEN LCDerror
'IF SerString(1) <> "E" THEN LCDerror
loop3:
IF SerString(2) = "m" OR "M" THEN loop4
IF SerString(2) <> "m" OR "M" THEN LCDerror
loop4:
IF SerString(3) = "p" OR "P" THEN Temperature 'loop5
IF SerString(3) <> "p" OR "P" THEN LCDerror
GOTO Main
LCDdisplay:
SEROUT 16,1,[noparse][[/noparse]215,48,48, STR Number_Str\2," Degree Celsius",0] 'using
RS232; Baud rate=115200
SEROUT 16,1,[noparse][[/noparse]215,48,50, STR Number_Str\2," Degree Celsius",0]
GOTO send_sms
RETURN
send_sms:
PAUSE 300
SEROUT 0, 18447, [noparse][[/noparse]"AT+CMGS=", 34,"+65", STR MessageAddress\8, 34,CR] 'send msg
command
PAUSE 1000
SEROUT 0, 18447, [noparse][[/noparse]"Temp=", STR Number_Str," Degree Celsius", 26]
RETURN
LCDerror:
SEROUT 16,1,[noparse][[/noparse]215,48,48,"Invalid Password",0]
SEROUT 16,1,[noparse][[/noparse]215,48,50,"Invalid Password",0]
GOSUB Invalid_password_smsSend
RETURN
Invalid_password_smsSend:
PAUSE 300
msg command
PAUSE 1000
SEROUT 0, 18447, [noparse][[/noparse]"Invalid password",26]
RETURN
Temperature:
DIRS=$0000 ' start with DIR8 and DIR9 as inputs
GOSUB CONFIG ' configure DS1624 for 1SHOT operation
'FOR ADR=0 TO 9 ' make ten measurements
GOSUB INIT ' initiate a conversion
GOSUB MEAS ' fetch the result
'DEBUG ?T.BYTE1
'DEBUG ?T.BYTE0
DAT = T.BYTE1
GOSUB EE_WRITE ' save high byte to the DS1624 EEPROM
PAUSE 1000
'NEXT
'FOR ADR=0 TO 9 ' now fetch each from EEPROM and display
GOSUB EE_READ
DAT=I_BYTE
Value1 = DAT DIG 1 ' Tens
Value2 = DAT DIG 0 ' Ones
Number_Str(0)= Value1 + 48
Number_Str(1)= Value2 + 48
'DEBUG STR Number_Str
'NEXT
GOTO LCDdisplay
CONFIG: ' configures DS1624 in 1SHOT temperature conversion mode
GOSUB START
O_BYTE=$90
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=$AC 'Access Config
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=$01 '1 SHOT mode
GOSUB OUT_BYTE
GOSUB NACK
GOSUB SSTOP
PAUSE 30 ' wait for EEPROM to program
RETURN
INIT: ' causes DS1624 to initiate a conversion
GOSUB START
O_BYTE=$90 ' write
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=$EE ' Start Conversion
GOSUB OUT_BYTE
GOSUB NACK
GOSUB SSTOP
PAUSE 1000 ' wait 1000 ms for conversion to complete
RETURN
MEAS: ' fetches temperature result. Value returned in T_HI and T_LO
GOSUB START
O_BYTE=$90 ' write
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=$AA ' Fetch Temperature
GOSUB OUT_BYTE
GOSUB NACK
GOSUB START ' read
O_BYTE= $91 '!@#$%^
GOSUB OUT_BYTE
GOSUB NACK
GOSUB IN_BYTE ' fetch the two byte reading
GOSUB ACK ' acknowledge each byte
T.BYTE1 = I_BYTE ' high byte
GOSUB IN_BYTE
GOSUB ACK
T.BYTE0 = I_BYTE
GOSUB SSTOP
RETURN
EE_READ: ' fetches content location ADR in DS1624 EEPROM
' result returned in DAT
GOSUB START
O_BYTE=$90 ' write
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=$17 ' access EEPROM
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=ADR ' specify address to read
' DEBUG ?ADR
GOSUB OUT_BYTE
GOSUB NACK
GOSUB START ' now read
O_BYTE=$91 '!@#$%^
GOSUB OUT_BYTE
GOSUB NACK
GOSUB IN_BYTE
DAT = I_BYTE
GOSUB SSTOP
RETURN
EE_WRITE: ' writes content of DAT to specified address ADR
GOSUB START
O_BYTE=$90 ' write
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=$17 ' Access Memory
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=ADR ' address
'DEBUG ?ADR
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=DAT ' data to write
'DEBUG HEX2 ?DAT
GOSUB OUT_BYTE
GOSUB NACK
GOSUB SSTOP
PAUSE 15 ' wait for EEPROM to program
RETURN
OUT_BYTE: ' sends content of O_BYTE, most sig byte first
FOR N=7 TO 0
BRANCH (O_BYTE>>N)&$01, [noparse][[/noparse]OUT_0, OUT_1]
OUT_0:
GOSUB LO_SDA
'DEBUG "0"
GOTO OUT_BYTE_1
OUT_1:
GOSUB HI_SDA
'DEBUG "1"
GOTO OUT_BYTE_1
OUT_BYTE_1:
GOSUB CLK
GOSUB HI_SDA
NEXT
'DEBUG CR
RETURN
IN_BYTE: ' receives a byte, most sig byte first.
' result returned in I_BYTE
GOSUB HI_SDA
I_BYTE=0
FOR N=0 TO 7
GOSUB HI_SCL
I_BYTE= (I_BYTE<<1) | SDA_IN
'DEBUG DEC SDA_IN
GOSUB LO_SCL
NEXT
'DEBUG CR
RETURN
NACK: ' clock pulse while SDA in high impdeance to allow
' slave to acknowledge by bringing SDA low
GOSUB HI_SDA
GOSUB CLK
RETURN
ACK: ' clock pulse while SDA low to acknowledge receipt of
' a byte from the slave
GOSUB LO_SDA
GOSUB CLK
GOSUB HI_SDA
RETURN
CLK: ' momentarily bring SCL high
GOSUB HI_SCL
GOSUB LO_SCL
RETURN
START: ' bring SDA from high to low while SCL is high
GOSUB LO_SCL
GOSUB HI_SDA
GOSUB HI_SCL
GOSUB LO_SDA 'SDA transition to low when SCL high
GOSUB LO_SCL
RETURN
SSTOP: ' bring SDA from low to high while SCL is high
GOSUB LO_SCL
GOSUB LO_SDA 'be sure SDA is in low state
GOSUB HI_SCL
GOSUB HI_SDA 'SDA transition to high when SCL is high
RETURN 'both SDA and SCL left in high-Z
LO_SDA:
SDA_OUT=0
SDA_DIR=OUT
RETURN
LO_SCL:
SCL_OUT=0
SCL_DIR=OUT
RETURN
HI_SDA:
SDA_DIR=IN
RETURN
HI_SCL:
SCL_DIR=IN
RETURN
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing
Monitoring"
reading.
siemens modem
Amulet LCD.
'{$STAMP BS2p}
'pin0 and pin 3
Siemens modem
'pin 8 and pin 9
DS 1624
'pin 16
Amulet LCD
ADR VAR Byte
DAT VAR Byte
OUT CON 1
IN CON 0
SDA_OUT VAR OUT8
SCL_OUT VAR OUT9
SDA_IN VAR IN8
SDA_DIR VAR DIR8
SCL_DIR VAR DIR9
T VAR Word
O_BYTE VAR Byte
I_BYTE VAR Byte
N VAR Byte
Main:
'======password
loop2:
loop3:
loop4:
GOTO Main
LCDdisplay:
GOTO send_sms
RETURN
send_sms:
PAUSE 300
command
PAUSE 1000
RETURN
LCDerror:
RETURN
PAUSE 300
msg command
PAUSE 1000
RETURN
Temperature:
'DEBUG ?T.BYTE1
'DEBUG ?T.BYTE0
DAT = T.BYTE1
PAUSE 1000
'NEXT
GOSUB EE_READ
DAT=I_BYTE
'NEXT
GOTO LCDdisplay
GOSUB START
O_BYTE=$90
GOSUB OUT_BYTE
GOSUB NACK
GOSUB OUT_BYTE
GOSUB NACK
GOSUB OUT_BYTE
GOSUB NACK
GOSUB SSTOP
RETURN
GOSUB START
O_BYTE=$90 ' write
GOSUB OUT_BYTE
GOSUB NACK
GOSUB OUT_BYTE
GOSUB NACK
GOSUB SSTOP
RETURN
GOSUB START
O_BYTE=$90 ' write
GOSUB OUT_BYTE
GOSUB NACK
GOSUB OUT_BYTE
GOSUB NACK
GOSUB START ' read
O_BYTE= $91 '!@#$%^
GOSUB OUT_BYTE
GOSUB NACK
GOSUB IN_BYTE
GOSUB ACK
T.BYTE0 = I_BYTE
GOSUB SSTOP
RETURN
GOSUB START
O_BYTE=$90 ' write
GOSUB OUT_BYTE
GOSUB NACK
GOSUB OUT_BYTE
GOSUB NACK
' DEBUG ?ADR
GOSUB OUT_BYTE
GOSUB NACK
O_BYTE=$91 '!@#$%^
GOSUB OUT_BYTE
GOSUB NACK
GOSUB IN_BYTE
DAT = I_BYTE
GOSUB SSTOP
RETURN
GOSUB START
O_BYTE=$90 ' write
GOSUB OUT_BYTE
GOSUB NACK
GOSUB OUT_BYTE
GOSUB NACK
'DEBUG ?ADR
GOSUB OUT_BYTE
GOSUB NACK
'DEBUG HEX2 ?DAT
GOSUB OUT_BYTE
GOSUB NACK
GOSUB SSTOP
RETURN
FOR N=7 TO 0
OUT_0:
GOSUB LO_SDA
'DEBUG "0"
GOTO OUT_BYTE_1
OUT_1:
GOSUB HI_SDA
'DEBUG "1"
GOTO OUT_BYTE_1
OUT_BYTE_1:
GOSUB CLK
GOSUB HI_SDA
NEXT
'DEBUG CR
RETURN
GOSUB HI_SDA
I_BYTE=0
FOR N=0 TO 7
GOSUB HI_SCL
'DEBUG DEC SDA_IN
GOSUB LO_SCL
NEXT
'DEBUG CR
RETURN
GOSUB HI_SDA
GOSUB CLK
RETURN
GOSUB LO_SDA
GOSUB CLK
GOSUB HI_SDA
RETURN
GOSUB HI_SCL
GOSUB LO_SCL
RETURN
GOSUB LO_SCL
GOSUB HI_SDA
GOSUB HI_SCL
GOSUB LO_SCL
RETURN
GOSUB LO_SCL
GOSUB HI_SCL
LO_SDA:
SDA_OUT=0
SDA_DIR=OUT
RETURN
LO_SCL:
SCL_OUT=0
SCL_DIR=OUT
RETURN
HI_SDA:
SDA_DIR=IN
RETURN
HI_SCL:
SCL_DIR=IN
RETURN
Do you Yahoo!?
I looked at the code, and I don't know enough to comment much. I have never
done anything like what you are doing. However, is the password always the
same? You could store the password with a DATA command and use 3 less bytes.
What about the message address? If it is always the same, you could store
that with a DATA command too. When you need to use the DATA, make a small
loop witht he READ command.
Hope this helps,
Jonathan
www.madlabs.info
To: <basicstamps@yahoogroups.com>; <sswanson@p...>;
<tracy@e...>
Sent: Sunday, December 07, 2003 8:30 AM
Subject: [noparse][[/noparse]basicstamps] big Brother and big Sister pls help me.( very Long)
> Hi All,
and Monitoring"
reading.
> siemens modem
> Amulet LCD.
> '{$STAMP BS2p}
> 'pin0 and pin 3
Siemens modem
> 'pin 8 and pin 9
DS 1624
> 'pin 16
Amulet LCD
> ADR VAR Byte
> DAT VAR Byte
> OUT CON 1
> IN CON 0
> SDA_OUT VAR OUT8
> SCL_OUT VAR OUT9
> SDA_IN VAR IN8
> SDA_DIR VAR DIR8
> SCL_DIR VAR DIR9
> T VAR Word
> O_BYTE VAR Byte
> I_BYTE VAR Byte
> N VAR Byte
> Main:
msg,stored it to be forever UNREAD
STR MessageAddress\8\0, WAIT(13, 10)]
> '======password
appear, program goes back to function start
> loop2:
> loop3:
> loop4:
> GOTO Main
> LCDdisplay:
'using RS232; Baud rate=115200
> GOTO send_sms
> RETURN
> send_sms:
> PAUSE 300
'send msg command
> PAUSE 1000
> RETURN
> LCDerror:
> RETURN
> PAUSE 300
'send msg command
> PAUSE 1000
> RETURN
> Temperature:
> 'DEBUG ?T.BYTE1
> 'DEBUG ?T.BYTE0
> DAT = T.BYTE1
> PAUSE 1000
> 'NEXT
> GOSUB EE_READ
> DAT=I_BYTE
> 'NEXT
> GOTO LCDdisplay
> GOSUB START
> O_BYTE=$90
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB SSTOP
> RETURN
> GOSUB START
> O_BYTE=$90 ' write
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB SSTOP
> RETURN
> GOSUB START
> O_BYTE=$90 ' write
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB START ' read
> O_BYTE= $91 '!@#$%^
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB IN_BYTE
> GOSUB ACK
> T.BYTE0 = I_BYTE
> GOSUB SSTOP
> RETURN
> GOSUB START
> O_BYTE=$90 ' write
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB OUT_BYTE
> GOSUB NACK
> ' DEBUG ?ADR
> GOSUB OUT_BYTE
> GOSUB NACK
> O_BYTE=$91 '!@#$%^
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB IN_BYTE
> DAT = I_BYTE
> GOSUB SSTOP
> RETURN
> GOSUB START
> O_BYTE=$90 ' write
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB OUT_BYTE
> GOSUB NACK
> 'DEBUG ?ADR
> GOSUB OUT_BYTE
> GOSUB NACK
> 'DEBUG HEX2 ?DAT
> GOSUB OUT_BYTE
> GOSUB NACK
> GOSUB SSTOP
> RETURN
> FOR N=7 TO 0
> OUT_0:
> GOSUB LO_SDA
> 'DEBUG "0"
> GOTO OUT_BYTE_1
> OUT_1:
> GOSUB HI_SDA
> 'DEBUG "1"
> GOTO OUT_BYTE_1
> OUT_BYTE_1:
> GOSUB CLK
> GOSUB HI_SDA
> NEXT
> 'DEBUG CR
> RETURN
> GOSUB HI_SDA
> I_BYTE=0
> FOR N=0 TO 7
> GOSUB HI_SCL
> 'DEBUG DEC SDA_IN
> GOSUB LO_SCL
> NEXT
> 'DEBUG CR
> RETURN
> GOSUB HI_SDA
> GOSUB CLK
> RETURN
> GOSUB LO_SDA
> GOSUB CLK
> GOSUB HI_SDA
> RETURN
> GOSUB HI_SCL
> GOSUB LO_SCL
> RETURN
> GOSUB LO_SCL
> GOSUB HI_SDA
> GOSUB HI_SCL
> GOSUB LO_SCL
> RETURN
> GOSUB LO_SCL
> GOSUB HI_SCL
> LO_SDA:
> SDA_OUT=0
> SDA_DIR=OUT
> RETURN
> LO_SCL:
> SCL_OUT=0
> SCL_DIR=OUT
> RETURN
> HI_SDA:
> SDA_DIR=IN
> RETURN
> HI_SCL:
> SCL_DIR=IN
> RETURN
> Do you Yahoo!?
