Controller Problem
I have developed a a couple of boards that I am using for industrial
control. The problem I am having is my stamp wants to reset after an
AC motor starter is energized. The way the boards are made I have
12VDC coil relay that are PCB mount and are driven by a transistor
that is driven by the stamp. Through a set of NO contact on the PCB
mount relay I am turning on a bigger motor starter. I have
disconnected all leads from the motor starter and have supplied the
stamp power by an external source. After pressing the starter in by
hand I still get the reset.
I normally use the boards as timers counter etc in a control cabinet
not to directly control an AC motor contactor. I have had this
problem 1 time before and used a isolation contactor(solid state)to
remedy the problem. I know I am picking up noise from the contacts
when they switch but remeding the problem is above my head. I have
all inputs on the boards opticaly isolated but not the outputs. I
don't think this will help in this situation? Also for information
the motor contactor is supplying power to a 480V 2HP motor.
Any help is much appreciated.
Mark Waddell
Mark Waddell
mwaddell@s... writes:
I would suggest you get the motor controller off the PCB, if that is where it
is.
The inductive kick of that thing is enough to reset the Stamp.
Alternatively, get the Stamp away from the controller. Do you have a clamp
diode on the
transistor cthat closes the 12VDC relay?
Sid
> In a message dated 12/6/2003 12:59:39 PM Eastern Standard Time,
cabinet
to
contacts
have
I
information
is where it
> is.
a clamp diode on the
> Sid
The controller and contactor are already seperate they are mounted in
a control cabinet. They do have a common back plane they are mounted
to. I did move the stamp away from the contactor and this helps. I
also moved the power supply and this seems to help even more. I
don't have a clamp diode on the transistor but when I disconnect the
board with the transistor it helps none.
I have a transformer that is dropping the 480 to 120 for a small
switching power supply. I can get the machine to run if I use a 110
outlet instead of the transformer. I still have to move the power
suply away from the contactor though.
Mark
Good. You need a clamp diode on the transistor. The inductive kickback from
the relay could burn it out. Connect across relay, cathode to plus side of
relay, anode to ground. Next thing - is the 12 volts for the relay an isolated
supply, or is it part of the power supply that is powering the Stamp?
Sid
Have you increased the size of the capacitor on your 5 volt supply
to >100uF in parallel with smaller values tantalum or ceramic, and
also either connect the ATN input to ground, or pull it down with a
resistor ~1kohm?
-- Tracy
> to reset after an
> are made I have
> by a transistor
<trimmed>
Mark, do you have a resistor between the stamp and the
transistor used to pwoer the relay?
> from the contacts
> my head. I have
<trimmed>
You could try placing a diode in reverse of the coil
leads on the relay.
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing.
http://photos.yahoo.com/
> > to reset after an
> > are made I have
> > by a transistor
> <trimmed>
> > from the contacts
> > my head. I have
> <trimmed>
> leads on the relay.
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
Yes I do have a resistor between the transister and the stamp. The
problem is from the arcing of the contacts of the 3 phase 480 volt
line. I have disconnected the board that interfaces to the motor
starter thew only thing the 2 circuits have in common is a common
ground. I have the problem even when I push in the contactor by
hand. The coil is not being used when I do this.
> In a message dated 12/6/2003 1:56:31 PM Eastern Standard Time,
mounted in
mounted
helps. I
the
kickback from
plus side of
relay an isolated
Stamp?
> Sid
The supply is not isolated. I have a transformer dropping 480V to
120V and then it goes to a switching power supply 24VDC. The power
supply for the stamp is a LM7805 that is being fed by the 24VDC
supply.
PCB
the
by
a
> resistor ~1kohm?
> -- Tracy
The capacitor look close to what I have. Pulling the ATN line to
ground I haven't done. I won't be back at work till monday
hopefully! I will try this then.
> the stamp. The
> phase 480 volt
> to the motor
> common is a common
> contactor by
I apologize, I thought you were disconnecting the
power (AC) circuitry altogether and the relay was the
only thing still connected. I see Tracy had a couple
of good suggestions.
Knight Designs
(607) 535-6777
Do you Yahoo!?
I do not know what the original question was, I must have missed it earlier.
I routinely control 480 3PH circuitry with Stamps.
You most likely need more filtering on the Stamp Power and I/O lines.
I optically isolate everything and use Digital Noise Filters on all I/O lines.
I use Murata-Erie DSS306-55Y5547. It looks like a 3 legged Capacitor. Ground
the middle leg and feet the signal through the other 2 legs.
This adds some costs to the design, but it is loads cheaper then the damage
possible from a runaway machine, due to a locked up controller. (Or a slick
Boston Lawyer.)
Let me know if you need anymore help.
Alan Bradford
Plasma Technologies
www.plasmatechnologies.com
> the stamp. The
> phase 480 volt
> to the motor
> common is a common
> contactor by
Knight Designs
(607) 535-6777
