Stache as memory stick
Archiver
Writing my previous message it occured to me that the Stache could be used
as an RS232 memory stick.
It would require new firmware though.
When connected to the stamp/javelin (acting as DTE) two commands are
to be recognized by the Stache: a STORE command that lets the stamp
controller write bytes to the Stache eeprom,
and a READ command that lets it read bytes from the eeprom. No meaning
whatsoever is placed on the bytes.
That should be handled by the stamp program.
When connected to the PC (acting as DCE) there must be a special program
that reads/writes the Stache eeprom.
This way we would have an easy to use removable storage device.
Question to the developers of Stache: is the above doable (or even
desireable)?
regards peter
desireable)?
regards peter
> Hi,
> desireable)?
I think there are a lot of us who want some from of portable memory so we can
download the data and carry it back to the PC at home.
HOBO data loggers have a BackPack unit that automatically connects to a data
logger in
the field, and then pulls the data.
You bring that back to your PC and connect it for downloading into your PC.
I'm not exactly sure how it works, if it resets the logger after it down loads
or any of
that.
But having a portable unit, with battery, memory, and a few indicators would be
really
neat.
Of course, in my thinking, the next logical thing is a display, then inputs....
Then of
course the Sunday papers have advertisements for PALM Pilots....
And that gets me to wondering if anyone is going to do a Nuts&Volts on Palm
Pilots and
the Stamp ?
But, in answer to your original question, I do believe there is some need for
some
portable device to download.
Dave
The problem with dataloggers is that they don't allow random access to
stored data, at least
I don't know any that does.
The reason I thought of the Stache is that it is SX18 based.
Question: can the Stache be reprogrammed with an SX-key (voiding warranty of
course)?
Having written a 16bit filesystem for ram/eeprom for the Javelin, and
knowing the SX18,
I am sure the SX18 has enough program space and variable space to port that
filesystem
to the SX18. It is a simple filesystem, supporting only 32KB memory (as in
the Stache),
Filenames are single character (eg. 'A', 'B' etc.) and supports the
following functions
OpenForRead,OpenForWrite,OpenForRandom,Seek,Tell,Read,Write,Close,Flush,Size
,Dir,Delete.
Each of these functions could be called from the stamp with a command byte
plus
required parameters. This would give a nice portable filesystem for the
stamp.
You could denote a file as boot file. holding parameter settings like
baudrates, timing values
etc, without the need for setup code (with readable text) programmed in the
stamp and save valuable program space.
What do you think? Would that be a useful device?
regards peter
Sent: Saturday, December 06, 2003 3:27 PM
Subject: [noparse][[/noparse]basicstamps] Re: Stache as memory stick
> --- In basicstamps@yahoogroups.com, "Peter Verkaik" <peterverkaik@b...>
wrote:
> > Hi,
used
> > desireable)?
can
data logger in
PC.
loads or any of
> that.
would be really
> neat.
inputs.... Then of
Palm Pilots and
> the Stamp ?
for some
> Dave
>course)?
Yes, it can. There is a programming header (4 holes labeled +, -,
x1, x2) on the Stache circuit board. It programs just as would any
other SX18. The schematic is included with the Stache documentation
and is also available on our web site
<http://www.emesystems.com/stache.htm>. You are welcome to try.
(And if you want to restore it as a Stache, we can help you with
that, too.)
We did consider turning it into a memory module for data. I think to
be a viable product, though, it would need to have a lot more memory,
512k at least, in an AT45 chip. On one hand, how is it going to
compete with memory media out there that offer 256 megabytes less
than $100? On the other hand, the Stache memory module would offer
the convenience of an RS232 interface compatible with Stamp and with
any terminal program on the PC, like hyper-terminal. Would that
convenience be worth $100, for 1/2 megabyte?
-- Tracy
>Hi Dave,
>course)?
>knowing the SX18,
>filesystem
>the Stache),
>following functions
>,Dir,Delete.
>plus
>stamp.
>regards peter
>From: "Dave Mucha" <davemucha@j...>
>wrote:
>> > Hi,
>used
>> > desireable)?
>can
>data logger in
>PC.
>loads or any of
>> that.
>would be really
>> neat.
>inputs.... Then of
>Palm Pilots and
>> the Stamp ?
>for some
> > Dave
http://pages.quicksilver.net.nz/sbridger/
They offer a chip called BL233 (US$ 4,=) that does RS232/USB to I2C/SPI
conversion.
The host (could be stamp,javelin or pc) talks to the chip using ascii
commands. The
chip also supports 1-wire (something for the javelin).
Adding an AT45 to this chip would make a portable memory that is easy
accessible from both stamp and pc (no API, no DLL required).
Has anyone used this chip? I believe it operates in half duplex mode so it
should
ignore echoed characters when it sends characters to the stamp.
regards peter
Sent: Saturday, December 06, 2003 9:17 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Stache as memory stick
of
> >course)?
> that, too.)
> -- Tracy
> >Hi Dave,
of
> >course)?
> >knowing the SX18,
that
> >filesystem
in
> >the Stache),
> >following functions
e
> >,Dir,Delete.
byte
> >plus
> >stamp.
the
> >regards peter
> >wrote:
> >> > Hi,
> >used
meaning
program
> >> > desireable)?
we
> >can
> >data logger in
> >PC.
down
> >loads or any of
> >> that.
> >would be really
> >> neat.
> >inputs.... Then of
> >Palm Pilots and
> >> the Stamp ?
need
> >for some
> > > Dave
There are a few people out there (FTDI being one)
who market chips which provide the 'Slave' half of
a USB conversation. This means you can hook your
Stamp-based design, through the chip or module,
to a USB 'Master'.
As far as I know, the USB 'Master' half MUST be a
PC -- so far. I think Intel is marketing a board
which provides an interface to a USB 'Master' port,
but I don't think it's 'proven' yet.
The 'Master' half is what people need when they
want to hook their Stamp to a USB camera,
Joystick, Keyboard, USB Disk, etc.
The referred to website ONLY has the 'Slave' half.
<peterverkaik@b...> wrote:
> I found this site:
I2C/SPI
> conversion.
ascii
> commands. The
easy
mode so it
> should
> regards peter
devices
using the pc usb host port. The bare BL233 has a rs232 interface which can
be connected
directly to the stamp, or via a max232 to the pc or stamp program port (I am
not sure if
echoed characters are a problem).
It would provide I2C and 1-wire to the normal BS2 using serin/serout
commands.
The manual is found here.
http://pages.quicksilver.net.nz/sbridger/bl233_a.pdf
From that it looks very promising for implementing some rs232 based portable
storage device.
regards peter
Sent: Tuesday, December 09, 2003 3:31 PM
> USB: The 'Slave' USB half-problem has been solved.
> to a USB 'Master'.
> > I found this site:
> I2C/SPI
> > conversion.
> ascii
> > commands. The
> easy
> mode so it
> > should
> > regards peter
