Can''t see output from stamp to PC
Hi Mike,
You must disconnect Pin 3 (ATN) of your BASIC Stamp. The Stamp host software
uses this line to reset the BS2 for programming, however, terminal software
uses the same line to signal "ready" for serial communication. I hope this
helps.
Best regards,
Russell Warburton
email: russell@w...
website: http://www.warburtech.com
telephone: +44 (0)7814 044 754
Sent: Wednesday, December 03, 2003 4:10 PM
Subject: [noparse][[/noparse]basicstamps] Can't see output from stamp to PC
> I must be missing something.
> I'm new to stamps and am having a problem reading the input into WIN
> I have a BS2 that is running the famous "HELLO" progrm using SEROUT
> 16, 16468, [noparse][[/noparse]"HELLO!"]
> I can see the output using the Parallax debug but can't in Hyperterminal
> (set to 9600, no handshaking) or VB
> FIFO has been turned off.
> When I try this using MSComm - nothing as well (appear to get no comm
> event)
> I've tried this at different baud rate and different PC's with no luck
> According to all the sources I can find the serial connection from the
> stamp to PC is setup correctly.
> HELP!!
> Thanks in advance
> Mike
helps.
Best regards,
Russell Warburton
email: russell@w...
> event)
> HELP!!
> Thanks in advance
> Mike
