floppy drive emulator
Archiver
I am trying to find a way to emulate (in software or hardware, using
BS2 or PC or both) an old 8 inch floppy drive.
My reason is this, I have an old machine tool with an old
control ,that is not a PC, that has a floppy disk controller (I can
get more details) and this 8 inch drive attached to it, but the drive
is failing and I don't want to replace the drive unit.
What I want to do is remove the drive, keeping the controller card in
the machine) and connect "something" to the card that fakes out the
controller card into thinking it is reading and writing from the
dirve when it is really "interfacing" with a BS2 and/or PC.
I need to be able to read in the data that the old control is
writing, once I get the file, I don't have to be able to "give it
back" via the controller card, I can actually give it back via a
paper tape reader that is also on it (although writing back to teh
controller would be a plus).
I havn't yet been sucessful in finding any way to emulate this drive,
no one that I have spoken or typed to has given me any hope, they all
say it can't be done, but I think it is possible.
Any suggestions?
Any suggestions?
A very long time ago I actually built an interface board for an 8" floppy
drive (for an Ohio Scientific Computer), so I remember some of the internal
workings of the beast...
You not only need to emulate the data stream for the operating system and
driver, but the mechanicals of the drive as well. For instance, on
initialization, the floppy drive seeks back its stepper motor until the zero
track switch is made good. This tell the driver its ready to go. Then it
seeks forward one pulse at a time, reading each track once the little hole
in the media goes past another optical sensor. Then the floppy drive streams
out one block/track worth of information to the interface. The controller
steps forward one track, the drive waits for the hole to go past the sensor,
and the next track streams out. Besides the initialization/track-0 feedback,
you should be able to increment blocks of memory and feed them out to the
controller. As I remember, this was basically TTL level logic. Figuring out
your block sizes and such is the trick though, since in the early days every
manufacturer did his own thing.
What sort of Operating System is this thing using????
Mike Sokol
www.modernrecording.com
mikes@m...
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Wednesday, December 03, 2003 11:21 AM
Subject: [noparse][[/noparse]basicstamps] floppy drive emulator
> Any suggestions?
http://pluto.njcc.com/~hjohnson/s_drives.html
He may even have an 8" floppy drive to sell
you -- certainly, he has LOTS of manuals.
Also check: http://www.classiccmp.org/pipermail/cctech/2003-
August/017711.html
(reassemble link in notepad)
--- In basicstamps@yahoogroups.com, "Mike Sokol" <mike.sokol@m...>
wrote:
> Hmmmmm.....
floppy
internal
system and
the zero
Then it
little hole
drive streams
controller
the sensor,
feedback,
to the
Figuring out
days every
> Mike Sokol
> mikes@m...
> -William of Occam-
> From: "xutsim" <xutsim@y...>
using
can
drive
card in
the
drive,
all
> > Any suggestions?
Subject and
