Can''t see output from stamp to PC
I must be missing something.
I'm new to stamps and am having a problem reading the input into WIN
I have a BS2 that is running the famous "HELLO" progrm using SEROUT
16, 16468, [noparse][[/noparse]"HELLO!"]
I can see the output using the Parallax debug but can't in Hyperterminal
(set to 9600, no handshaking) or VB
FIFO has been turned off.
When I try this using MSComm - nothing as well (appear to get no comm
event)
I've tried this at different baud rate and different PC's with no luck
According to all the sources I can find the serial connection from the
stamp to PC is setup correctly.
HELP!!
Thanks in advance
event)
HELP!!
Thanks in advance
