FOR KF4HAZ RE: Long range communication
hio KF4HAZ
i am impressed at those numbers. I am in the process
of entering the HAM world.
1)Were these transcievers self made. or commercial off
the shelf. Expescially the one u used to tlak to
australia and the northpole
2)could u pls share schematics/designs for these
trascievers
3)would i be right in assuming that u used sky wave
propogation for such large distances?
thanks for your time
--- FalconWireless Tech Support - KF4HAZ
<techsupport@f...> wrote:
> As for range, I have talked 90miles on 1 watt on
> VHF, made a contact with the south-pole-expedition
> using 40watts on 80meters,
> Australia using 10w on 40 meters, and have made
> digital 9600 baud connections on 6 meters with
> 150watts over a 250 mile distance.
> for more info on getting started see
> http://www.remote.arrl.org/hamradio.html
> or simply start at www.arrl.org and browse around
> - KF4HAZ -
> > Fantastic, but two more questions since I have
> little knowledge of
> > ham radios. 1, what is the range? 2, where can I
> get more
> > information on getting a license?
> > Thanks,
> > Chris
> > --- In basicstamps@yahoogroups.com,
> "FalconWireless Tech Support -
> > KF4HAZ" <techsupport@f...> wrote:
> > > Yes a Technician class license gives you remote
> control and radio
> > telemetry privileges in some parts of the bands.
> As to cheap
> > > radios, after you get your license visit a
> hamfest, you can pick
> > up bricks like the good ol htx-202 with a busted
> lcd cheap, and who
> > > cares if the display is shot if you want to play
> packet or monitor
> > a remote weather station or control some new
> experimental gizmo.
> > > Experimentation is encouraged in the ham bands
> (within the
> > frequency ranges designated for
> experimental/digital/remote/et.al.)
> > > provided you have the license.
> > > > Can you use ham radios to send signals? I was
> thinking more
> > along
> > > > the lines of morse code. I know that it's
> easier to interpret
> > > > pulses instead of voice communication and
> that's why I was
> > thinking
> > > > of cheap radios. Thanks for the info.
> > > > Chris
> > Support -
> > > > > GMRS requires a $75.00 License for the
> operator at each end,
> > FRS
> > > > does not.
> > > > > However I am uncertain as to the use of
> digital communication
> > on
> > > > those bands.
> > > > > Ham radio allows for digital modes and
> licensing is a mere
> > $6.00
> > > > to take the exam.
> > > > > That being said, you would need a "COR"
> signal coming from the
> > > > receiver to recognize the presence of an
> unmodulated carrier to
> > > > > implement the method you described.
> > > > > I have had some success in using "Direct
> FSK" but the range
> > tends
> > > > to be less than that of a voice signal, DTMF
> provides a bit more
> > > > > range, but slows the throughput.
> > > > > If speed vs. bandwidth dictates there a
> devices known
> > as "TNC's"
> > > > which are radio modems that allow digital
> serial data to be sent
> > > > > over distances equal to or greater than that
> of voice using the
> > > > same radio equipment.
> > > > > - KF4HAZ -
> > > > > > Has anyone ever tried using two of those
> 5-mile radios (I
> > think
> > > > they
> > > > > > are GRMS) to communicate between two
> stamps. Could it be as
> > > > simple
> > > > > > as putting a relay to transmit across the
> push-to-talk
> > button to
> > > > > > transmit. Maybe have the transmitting
> stamp put out X
> > amount of
> > > > > > pulses and the receiving stamp can decode
> those pulses. Does
> > > > anyone
> > > > > > have any experience with this or know
> where I can get more
> > > > > > information?
> > > > > > Thanks,
> > > > > > Chris
> > > > To UNSUBSCRIBE, just send mail to:
> > > > basicstamps-unsubscribe@yahoogroups.com
> > > > from the same email address that you
> subscribed. Text in the
> > Subject and Body of the message will be ignored.
> > > > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
> > from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> ignored.
__________________________________
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
trascievers
> - KF4HAZ -
> little knowledge of
> get more
> > Thanks,
> > Chris
> control and radio
> As to cheap
> lcd cheap, and who
> packet or monitor
> experimental gizmo.
> (within the
> thinking more
> > along
> easier to interpret
> that's why I was
> > thinking
> > > > Chris
> > Support -
> > FRS
> > > > does not.
> > on
> > > > those bands.
> licensing is a mere
> > $6.00
> > > > to take the exam.
> FSK" but the range
> > tends
> provides a bit more
> devices known
> > as "TNC's"
> of voice using the
> > > > > - KF4HAZ -
> 5-mile radios (I
> > think
> > > > they
> > > > simple
> push-to-talk
> > button to
> stamp put out X
> > amount of
> those pulses. Does
> > > > anyone
> > > > > > information?
> > > > > > Thanks,
> > > > > > Chris
> ignored.
> ignored.
Do you Yahoo!?
The 40 and 80 meter contacts (South-pole by the way) were with an Icom-725 and a
wire dipole about 50ft up horizontally polarized.
80Meter was running E-W which gave more signal N-S.
40 and 80 meter signals were bouncing off the ionosphere.
6 meter was a folded unipole groundplane 100ft. up a tower 739'AMSL using a TNC
and a GE 50MHz transceiver.
Lonnie Underwood - KF4HAZ -
> hio KF4HAZ
> trascievers
> > - KF4HAZ -
> > little knowledge of
> > get more
> > > Thanks,
> > > Chris
> > control and radio
> > As to cheap
> > lcd cheap, and who
> > packet or monitor
> > experimental gizmo.
> > (within the
> > thinking more
> > > along
> > easier to interpret
> > that's why I was
> > > thinking
> > > > > Chris
> > > Support -
> > > FRS
> > > > > does not.
> > > on
> > > > > those bands.
> > licensing is a mere
> > > $6.00
> > > > > to take the exam.
> > FSK" but the range
> > > tends
> > provides a bit more
> > devices known
> > > as "TNC's"
> > of voice using the
> > > > > > - KF4HAZ -
> > 5-mile radios (I
> > > think
> > > > > they
> > > > > simple
> > push-to-talk
> > > button to
> > stamp put out X
> > > amount of
> > those pulses. Does
> > > > > anyone
> > > > > > > information?
> > > > > > > Thanks,
> > > > > > > Chris
radio!
jim
http://www.geocities.com/jimforkin2003/
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6uMoZB6xpSl003S0TkjJrrubCnMwvtYnZegFJMysX7cyrRt40StowdzHTb4MHdalchEVJtxjWCVM5s0o7OdirtCtB7-aPWI9Ew]techsupport@f...[/url
Sent: Wednesday, December 03, 2003 10:06 AM
Subject: Re: [noparse][[/noparse]basicstamps] re: FOR KF4HAZ RE: Long range communication
VHF 90 mile was on an HTX-202 connected to a 1/4wl groundplane on a 20ft
pole.
and a wire dipole about 50ft up horizontally polarized.
TNC and a GE 50MHz transceiver.
> hio KF4HAZ
> trascievers
> > - KF4HAZ -
> > little knowledge of
> > get more
> > > Thanks,
> > > Chris
> > control and radio
> > As to cheap
> > lcd cheap, and who
> > packet or monitor
> > experimental gizmo.
> > (within the
> > thinking more
> > > along
> > easier to interpret
> > that's why I was
> > > thinking
> > > > > Chris
> > > Support -
> > > FRS
> > > > > does not.
> > > on
> > > > > those bands.
> > licensing is a mere
> > > $6.00
> > > > > to take the exam.
> > FSK" but the range
> > > tends
> > provides a bit more
> > devices known
> > > as "TNC's"
> > of voice using the
> > > > > > - KF4HAZ -
> > 5-mile radios (I
> > > think
> > > > > they
> > > > > simple
> > push-to-talk
> > > button to
> > stamp put out X
> > > amount of
> > those pulses. Does
> > > > > anyone
> > > > > > > information?
> > > > > > > Thanks,
> > > > > > > Chris
