Connecting a speaker to BS1
I would like to know the best way to connect a 2"
8 ohm speaker to one of the pins on a BS1.
I have tried a 10mf capacitor in series with the speaker and got fair
results. Volume was a bit low.
Is there a better way or a different value cap.
I have seen pull up or pull down resistors being used, which I tried, but
didn't seem to make any difference.
Also, I could use a pizeo speaker, but I would like to get information on
what type and hook-up information.
TIA and happy hollidays.
Tom
Tom
remember that a higher-impedance speaker will give you better results.
Better than that, run the output through a simple filter and into an
amplifier (see SOUND in the help file or documentation for more
information on this).
-- Jon Williams
-- Dallas Office
From: Thomas R. Scheibl [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=io-vDITZJrRlIrZ9mTnWihyhilZukIQ7FROzKyvBRfhmTxg2Pqmok6pyT771BkmR8_qRfR2KP0XSmA]scheibl@p...[/url
Sent: Tuesday, December 02, 2003 10:02 AM
Subject: [noparse][[/noparse]basicstamps] Connecting a speaker to BS1
results. Volume was a bit low. Is there a better way or a different
value cap.
but didn't seem to make any difference.
on what type and hook-up information.
Tom
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
I have achieved good results using an 8 ohm speaker in series with a 33 ohm
resistor. Connect two 10uF capacitors in series from your Stamp pin to
ground and then connect one side of your speaker / resistor pair to the
midpoint between the two capacitors and the other side to ground. The
capacitor on the ground side is optional, but it does reduce high frequency
noise.
I hope this helps.
Best regards,
Russell Warburton
email: russell@w...
website: http://www.warburtech.com
telephone: +44 (0)7814 044 754
Sent: Tuesday, December 02, 2003 4:01 PM
> Hi,
> Tom
impedance speaker. Not always easy to find, so the amplifier trick may
be best for good volume Even a simple LM386-based amp (like on our
Audio Amp AppMod) will do.
-- Jon Williams
-- Parallax
Sent: Tuesday, December 02, 2003 10:12 AM
Subject: RE: [noparse][[/noparse]basicstamps] Connecting a speaker to BS1
It's been a while since I've connect a standard speaker, but I do
-- Jon Williams
-- Dallas Office
From: Thomas R. Scheibl [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=asV5rGHxlOvhQZNvzHMC4dc_mwIIPYpVvK8XJKXgN7jsq7MDfn-unKvAK9TzkoXMlj0DrZoSt20NOEv6nw]scheibl@p...[/url
value cap.
Tom
abuse@p....
abuse@p....
Thanks for yours and Jon's reply. I will try them out this weekend.
Best regards,
Tom
Sent: Tuesday, December 02, 2003 10:13 AM
Subject: Re: [noparse][[/noparse]basicstamps] Connecting a speaker to BS1
> Hi Tom,
ohm
frequency
> noise.
> I hope this helps.
> Best regards,
> Russell Warburton
> email: russell@w...
> From: "Thomas R. Scheibl" <scheibl@p...>
> > Hi,
but
on
> > Tom
and
