need help in converting time
hi people , i live in singapore. i am grabbing data from a gps
antenna which is showing me UTC time. i need some help to change the
time from UTC to singapore time which is faster by 8 hours. thanks
for the help.
for the help.
becomes 1000 or 10 am
jim
http://www.geocities.com/jimforkin2003/
From: SkYbOL [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rpsxLH2P2MCBr8hifT4W1PFtWhqYC1BLr5j_y3vxiCgQaREXzH1H7VCCDPYvUkD3Lk6J68zTh-N_LNTejuk]skybol1@y...[/url
Sent: Tuesday, December 02, 2003 2:58 AM
Subject: [noparse][[/noparse]basicstamps] need help in converting time
for the help.
to the UTC time an using the modulus operator to handle the wrap:
hours = utcHr + TzOfs // 24
Where hours is your local time, utcHr is the hours value from the GPS
system, and TzOfs is a constant that specifies your time zone offset
(assuming ahead of UTC). If you're behind the UTC (as I am in Dallas),
you can do the math like this:
hours = utcHr + (24 - TzOfs) // 24
I've written about GPS interfacing a couple times in my Nuts & Volts
column -- these articles may be useful to you:
http://www.parallax.com/dl/docs/cols/nv/vol3/col/83.pdf
http://www.parallax.com/dl/docs/cols/nv/vol4/col/103.pdf
-- Jon Williams
-- Dallas Office
From: SkYbOL [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wSgGJEv-knKVgeIxI1vU10jX_SshYvN_0ZG9EY6nmg6uj6E-cuM1Olx4CxdtuK_j8d97ICfzOhGeFJQbRsQ]skybol1@y...[/url
Sent: Tuesday, December 02, 2003 1:58 AM
for the help.
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
i read your 83.pdf file and tried to write out the
program but was unsucessful in getting the time right.
can u take a look at my program and advise me on where
the mistake is? attached below is my program.
'{$STAMP BS2}
'{$PORT COM2}
time var byte(6)
v var byte(1) 'NORTH,SOUTH
n var byte(1) 'east west
clock var byte(6)
hrs var byte (2)
mins var byte(2)
secs var byte(2)
oie var word
dir11=1
dir9=1
main:
serout 0,188,[noparse][[/noparse]" LOGGING IN , PlEASE HOLD
Pause 5000
serout 0,188,[noparse][[/noparse]" PLEASE PRESS THE RED BUTTON TO
CONTINUE"]
critical:
IF(IN9=1) then nono
yesyes:
goto critical
nono:
serout 0,188,[noparse][[/noparse]" ENTERING TO TEST IF IT IS WORKING TO
OUR EXPECTATIONS"]
pause 3000
goto top
top:
IF (IN11=0) THEN waiting
get_data:
serin 1,188,2000,no_data,[noparse][[/noparse]wait("GPGGA,"),str
time\6,skip 15,str v\1,skip 12,str n\1]
serin 1,188,2000,no_data,[noparse][[/noparse]wait("GPRMC,"),str clock\6]
serout 0,188, [noparse][[/noparse] " The time is ",time(0),time(1),
":",time(2),time(3), ":",time(4),time(5),",latitude","
",v(0)," ",",longtidute ",n(0)," clock
",clock(0),clock(1),"|",clock(2),clock(3),"|",clock(4),clock(5)]
pause 2000
goto top
goto get_data
no_data:
serout 0,188,[noparse][[/noparse]" NO SERIAL DATA"]
goto top
goto get_data
waiting:
serout 0,188,[noparse][[/noparse]" PRESS THE BLACK BUTTON NOW "]
top1:
IF (IN11=0) THEN waiting1
get_data1:
hrs\2,str mins\2, str secs\2,wait(","),wait(","),str
v\1,wait(","),wait(","),str n\1]
oie=hrs+8
serout 0,188, [noparse][[/noparse] " The time is ",oie(0),oie(1),
":",mins(0),mins(1), ":",secs(0),secs(1),",latitude","
pause 4000
serout 0,188,[noparse][[/noparse]" PRESS THE BLACK BUTTON TO REFRESH THE
DATA "]
goto top1
goto get_data
waiting1:
goto top1
adjust:
hrs=hrs +(24+8) //24
return
--- Jon Williams <jwilliams@p...> wrote: > If
the date is not an issue, it's simply a matter of
> adding your offset
> handle the wrap:
> value from the GPS
> time zone offset
> my Nuts & Volts
> -- Jon Williams
> -- Dallas Office
> From: SkYbOL [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=52M491A_oXTyGbjtbkwKGouODLXsR0PbEx3g8nQpbiq1idxalneG3y5Oio1VBONS0mTlyTDLN_W9k9oL]skybol1@y...[/url
> from a gps
> help to change the
> hours. thanks
> for the help.
> Text in the Subject
> report SPAM to
> abuse@p....
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Faster. Easier. Search Contest.
http://sg.yahoo.com/search
characters. The data from the GPS unit is no numeric, it is a string
representation and therefore must be converted before you can make any
adjustments. Another note, your variables for hours, minutes and
seconds are consuming two bytes and this is not necessary -- yes, there
are two digits in those fields but their numeric value is never greater
than 59 so only one byte is required.
Here's a little demo that you can run to see how string data (using your
variable names) gets converted to numeric values for modification:
' {$STAMP BS2}
' {$PBASIC 2.5}
clock VAR Byte(6)
hrs VAR Byte
mins VAR Byte
secs VAR Byte
Test:
DEBUG CLS
DEBUGIN STR clock\6
' convert text time to numbers
hrs = ((clock(0) - 48) * 10) + (clock(1) - 48)
mins = ((clock(2) - 48) * 10) + (clock(3) - 48)
secs = ((clock(4) - 48) * 10) + (clock(5) - 48)
DEBUG "UTC: ", DEC2 hrs, ":", DEC2 mins, ":", DEC2 secs, CR
hrs = hrs + 8 // 24
DEBUG "Adj: ", DEC2 hrs, ":", DEC2 mins, ":", DEC2 secs, CR
END
If you go back and review the article you find there is a subroutines I
use called String_To_Value and Mixed_To_Tenths for converting GPS text
fields to numbers.
-- Jon Williams
-- Dallas Office
From: Boon Keong [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=r5hWajxaa-V05NpyvH-a6E8aECoCPY1fbI5IxQ63Gq_nTeTbgHKUtDc2IQBeNFTx4aw7SQ6EOnG06iePCUQ]skybol1@y...[/url
Sent: Tuesday, December 02, 2003 10:11 PM
Subject: RE: [noparse][[/noparse]basicstamps] need help in converting time
hi William,
'{$STAMP BS2}
'{$PORT COM2}
time var byte(6)
clock var byte(6)
hrs var byte (2)
mins var byte(2)
secs var byte(2)
oie var word
dir11=1
dir9=1
main:
Pause 5000
CONTINUE"]
critical:
IF(IN9=1) then nono
yesyes:
goto critical
nono:
OUR EXPECTATIONS"]
pause 3000
goto top
top:
get_data:
":",time(2),time(3), ":",time(4),time(5),",latitude"," ",v(0),"
pause 2000
goto top
goto get_data
no_data:
goto top
goto get_data
waiting:
top1:
get_data1:
oie=hrs+8
":",mins(0),mins(1), ":",secs(0),secs(1),",latitude"," ",v(0),"
pause 4000
DATA "]
goto top1
goto get_data
waiting1:
goto top1
adjust:
return
> adding your offset
> handle the wrap:
> value from the GPS
> time zone offset
> my Nuts & Volts
> -- Jon Williams
> -- Dallas Office
> From: SkYbOL [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=r5hWajxaa-V05NpyvH-a6E8aECoCPY1fbI5IxQ63Gq_nTeTbgHKUtDc2IQBeNFTx4aw7SQ6EOnG06iePCUQ]skybol1@y...[/url
> from a gps
> help to change the
> hours. thanks
> for the help.
> Text in the Subject
> report SPAM to
> abuse@p....
> ignored.
Do You Yahoo!?
abuse@p....
