SV: [basicstamps] )ne Wire Hub
Greetings!
I haven't used it, but it should be possible, as long as you take into
account the 3 DS2409 1-Wire Lan switches inside.
This means you will have to enable those ports you want to use manually,
and that some ports are not available at the same time. (Each 2409 have
two ports Main and Aux, and only one can be accessed at any given time)
Unless you need to hook up A LOT of 1-wire devices, I suggest you just
hook all of them to the same connector.
(I've had 6 devices connected, but 20 or 30 shouldn't be a problem)
Opprinnelig melding
Fra: billcramer2003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DsKqyw4BjTuVaJLYQXYkePpMA-rDQjfxd0X78UXVPl--2WXrALQ-ctWi0C-AdGS-gi2wdlQ3Lqynma4tQA]billcramer@c...[/url
Sendt: 1. desember 2003 12:05
Til: basicstamps@yahoogroups.com
Emne: [noparse][[/noparse]basicstamps] )ne Wire Hub
Anyone tried using the 1-wire hub from http://www.aagelectronica.com/
to hook up multiple 1-wire devices to a BS2p?
Happy Holidays,
Bill Cramer
Your use of Yahoo! Groups is subject to
Opprinnelig melding
Happy Holidays,
Bill Cramer
