out of variable space
                    At 06:42 AM 11/29/03 -0800, Jonathan Peakall wrote:
>Ben,
<snip>
>Also, you can use a different slot. As you probably know, the BS2s all have
>8 program slots. You can drop the DS1624 code in one slot and your main
>program in another. Then, call the slot with the DS1624 from your main
>program. There are some good docs on the Parallax site about the use of
>slots.
>Hope this helps,
>Jonathan
>www.madlabs.info
Just to avoid confusion, the BS-2 (plain) only has 1 x 2K memory and has no
banks like the other BS-2 products. The BS-2SX, BS-2e, BS-2p24, BS-2p40,
BS-2pe all
have at least 8 x 2K of program space, and do have slots or banks of memory.
An excellent Basic Stamp Model comparison sheet can be downloaded from here:
http://www.parallax.com/html_pages/tech/faqs/stamp_specs.asp
Bruce Bates
                            >Ben,
<snip>
>slots.
>Hope this helps,
>Jonathan
>www.madlabs.info
BS-2pe all
Bruce Bates
Good thing you are around to error check my posts ;-)
I'll try to be a little more careful in my statments. Thanks again for the
correction!
Jonathan
www.madlabs.info
Sent: Saturday, November 29, 2003 9:24 AM
Subject: Re: [noparse][[/noparse]basicstamps] out of variable space
> >Ben,
> <snip>
have
> >slots.
> >Hope this helps,
> >Jonathan
> >www.madlabs.info
no
> BS-2pe all
memory.
here:
> Regards,
> Bruce Bates
how do i save/download my program to another slot?
does it mean that i could have my sub-function in another slot?
regards
Ben
>Ben,
>slots.
>Hope this helps,
>Jonathan
>www.madlabs.info
BS-2pe all
Bruce Bates
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
>hi bruce,
>regards
>Ben
Hi Ben -
If you have a BS-2SX or any "larger" BS-2 Stamp look at the '{$STAMP xx }
directive in the Stamp PBASIC Manual for explicit instructions. If you have a
BS-2 (plain) there are no "slots" or memory banks available.
Here is the general format of that directive used to indicate the use of
multiple
program banks: ‘{$STAMP BS2sx, file2, file3, …, file8 } . The instructions for
use can be found in the manual at about Page 40.
Another excellent resource for multi-bank programming can be found here:
http://www.emesystems.com/BS2SX.htm
I hope that gets you started.
Bruce Bates
