Loop timing for RC Servo — Parallax Forums
edited 2003-12-03 23:15 in General Discussion
My knowledge of RC Servos goes something like this
Take a pulsed signal of period 20 ms long. Modulate the pulse-on
time between 1ms and 2ms and you get the Servo to move. 1.5 ms is
the midpoint- pulse widths less rotate the servo one direction, and
pulse widths greater rotate the servo in the other direction. Keep
sending pulses of a specific width (over and over and over again)
and you effectively have "position control" on the Servo. Very cool,
I like it.
So, I've been working through some of the experiments in the
Stampworks manuals, and especially the motor/servo programs. One of
the programs allows a Potentiometer to control the position of the
Servo (via RCTime) and goes like this (Note: I'm using a BS2sx).
'{$STAMP BS2SX} 'STAMP directive
PotCW CON 0
PotCCW CON 1
Servo CON 2
Scale CON $002C ' BS2sx
rcRt VAR Word
rcLf VAR Word
diff VAR Word
sPos VAR Word
Main:
HIGH PotCW
HIGH PotCCW
RCTIME PotCW, 1, rcRt
RCTIME PotCCW, 1, rcLf
rcRt = (rcRt */ Scale) MAX 250
rcLf = (rcLf */ Scale) MAX 250
sPos = rcRt - rcLf
PULSOUT Servo, (1875 + sPos + sPos + sPos)
Off_time: ' For 50 Hz
PAUSE 20
GOTO Main
The last line before returning on the loop (marked by
label "Off_time:" is supposed to specify 20 ms. So in an ideal world
one would expect a total (repeating) pulse period of about 20 ms
(min) or 22ms (max), which is good enough for these Servos (I think).
An upon hooking up a Servo, things seem to work as expected. Again,
this is nice to see things working out.
However, I then hooked the output of the BS2sx (the pin driving the
Servo) up to an Oscilloscope. I wasn't expecting to see a signal of
40+ ms in length! While the modulation of the 1-2 ms pulse width
checked out fine with the scope, the overal signal length was far
longer than I expected, given the "Pause 20" instruction.
I have decided/concluded that the other instructions in the loop,
particularly the RCTIME instructions are taking up a significant
amount of the loop time, and that added to the PAUSE 20 (and the
modulated pulse itself) all contribute to the overal output
waveform.
Is this correct? If not what else is going on?
Kevin Gordon
    edited 2003-11-30 00:31
    You are correct in your observations. I've gone so far in my programs
    as to estimate the time it takes for other lines of code to execute
    in between servo pulses but at least you have a scope and can
    determine the exact length and then subtract that of of the pause 20
    command to get the proper spacing in between pulses.
    -Dave
    cool,
    > I like it.
    > PotCW CON 0
    > PotCCW CON 1
    > Servo CON 2
    > rcRt VAR Word
    > rcLf VAR Word
    > diff VAR Word
    > sPos VAR Word
    > Main:
    > HIGH PotCW
    > HIGH PotCCW
    > sPos = rcRt - rcLf
    > PAUSE 20
    > GOTO Main
    world
    think).
    > waveform.
    > Thanks
    > Kevin Gordon
    edited 2003-11-30 06:16
    save yourselves lots of trouble and get an SSC (Serial Servo
    controller) The Basic stamp is not well suited to servo
    control if it is doing anything else. The SSC is pic based
    and dedicated to handling servo operations. The servo needs
    to be continuously sent the command signals and the stamp
    can do it, but is not practical do do it and anything else.
    Other sgtamps (javelin) do it rather well. If you look at
    most of the Stanp based projects that deal with servos,
    you'll discover that almost all of them farm the servo
    managment to a SSC of some time for this reason alone.
    Regards
    Dave Evartt
    American Hovercraft
    edited 2003-11-30 14:34
    The 20mS time between pulses on the servo is usually not very critical. I
    suppose if you lapse too long you will weaken the servo's "holding power".
    Have a look at http://www.al-williams.com/pak8.htm and
    http://www.al-williams.com/gp4.htm. In particular, look at
    http://www.al-williams.com/servobot.htm.
    Good luck!
    Al Williams
    AWC
    * Easy RS232 Power Supplies: http://www.al-williams.com/rs1.htm
    > From: Dave Evartt [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-qYJivwyQ6-cxzwGlihlfz_OOyLJ24k-yxqaf2Wogex_3bHUNiMnD4a31HOKyH-BzozArpA_kgThLD8oxFjMq8L2lgfgrdM]davee@a...[/url
    > Sent: Sunday, November 30, 2003 12:17 AM
    > Subject: Re: [noparse][[/noparse]basicstamps] Loop timing for RC Servo
    > Regards
    > Dave Evartt
    > American Hovercraft
    > from the same email address that you subscribed. Text in the
    edited 2003-11-30 20:25
    There are other servo controllers to look at besides the SSC.
    You can find ramping servo controllers in the co-processor I sell at
    www.bluebelldesign.com. It also includes other Stamp helpful features
    like A/D inputs and timers.
    There are some technical discussions covering servo control at my
    site too.
    Harry
    Stamp Robotics to the next level
    > Regards
    > Dave Evartt
    > American Hovercraft
    edited 2003-12-01 14:26
    We will politely disagree with you, David -- having sold nearly 50,000
    BOE-Bots that happily drive two servos while processing a wide array of
    sensors. Yes, programming is a bit trickier than using a servo
    controller, but it can be done with a stock BASIC Stamp.
    -- Jon Williams
    -- Dallas Office
    From: Dave Evartt [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ynQnEgh0WRjwjZ2keTBiG4K2MHZaHNvKQqtfioC73Y4tJnk6GMoVqwG-Jgbuu4mZfEcMTGTZyQeYgBCwFHMXacKohNmaXg]davee@a...[/url
    Regards
    Dave Evartt
    American Hovercraft
    edited 2003-12-01 14:55
    Jon,
    That's not really the point. I happen to love the Stamp,
    I've used over a hundered of them in the last ten years or
    so and I suspect that I'll go on doing so. I also have three
    boe bots and have built several robots around stamps. I even
    have one of your hexcrawlers, which by the way, uses two
    SSCs.
    The point is this: The stamp is a great tool, but it i NOT
    the total solution and you guys should accept that it is not
    the perfect solution. Don't lose any sleep over it.
    Because the stamp must continually resend the servo command,
    it must always remain in a tight loop that must resend that
    command. While this is not a difficuylt thing to do, it does
    make the software more complex than it needs to be. The
    whole idea is to make it EASY. That's where the stamp
    shines.
    Thirty years of systems programming has constantly reminded
    me to 'keep it simple stupid'. An SSC of any kind takes such
    a tremendous load off the programmer that only it's cost and
    extra weight should even be a consideration. Considering the
    very limited resources that the stamp possesses, it's no
    crime to suggest that it can use a little help from time to
    time.
    This is not an attack on the stamp, though everytime anyone
    mentions a lack of perfection in the stamp, it seems to be
    taken as an attack. You don't need to defend the stamp and
    you don't have to argue everytime someone says something
    about the stamp that you don't like.
    Now if the stamp incorporated some form of 'virtual' mode
    for PWM like the Javelin does, it would not even be an
    issue. In fact, I prefer the Javelin on the BOE because it
    does a much better job, but that is a different story.
    I know this will draw more heated argument and that's not my
    intent. I'll just leave it at that.
    Regards
    Dave Evartt
    American Hovercraft
    edited 2003-12-01 18:44
    ...even a BS1 will do it. Its all in how you write your code.
    Of course, what it takes me 10 lines to do, Jon can usually do in one.
    edited 2003-12-01 21:43
    Thanks for the advice, and also thanks for the advice of everybody.
    When I tuned the PAUSE Command, so that my "scope" showed the signal
    had close to 20ms periodicity, given other loop instructions, the
    Servo did indeed have better response (it might be the power of
    suggestion, or whatever, but I really think it got snappier
    acceleration, etc, and responded quicker), and the torque-load test
    I rigged up, which is a 40cm long bamboo rod zap-strapped to the
    Servo horn with varying weights suspended at the other end,
    responded better than in the prior experiment (when the loop timing
    was at 40+ ms).
    PS: I don't really have a physical Scope - I have this cute little
    Win-Scope software which reads signals sent into my PC's sound
    board. I run Windows XP. The Scope software is two channel (dual
    trace), with about 20 Hz to 20 KHz bandwidth. It uses the 8 bit A/D
    converter built into the sound card. No horizontal sync, and nothing
    very special (although it does do off-line FFT's and has storage
    capabilities). I find it very useful to test my 555 timers, H-Bridge
    and Stamp circuits.
    Check it out at;
    http://www.mitedu.freeserve.co.uk/Prac/winscope.htm
    http://www.geocities.com/nlradiofm/winscope.htm
    Note: I have no affiliation with this software. I just want to make
    some interesting animatronic stuff using Stamps and Servos. The
    discussion so far has been very educational.
    My next experiment is to try to control two servos, in a kinda
    articulated scissor lift mechanism - cobbled together with small
    bamboo rods (grown in my own back-yard), zap straps, duct tape, and
    Basic Stamps. I'll keep y'all posted.
    Kevin Gordon
    --- In basicstamps@yahoogroups.com, "nickel152" <nickel152@y...>
    programs
    execute
    20
    > -Dave
    >> wrote:
    >> Blah blah blah
    edited 2003-12-02 01:44
    Hi Kevin,
    Thanks for the link on Winscope. What are you using as a buffer
    between the signals the stamp is generating and your soundcard? The
    only problem I can see with Winscope is the low input levels which is
    a limitation of the souncards. I'm not sure if my soundcard would
    take a +5V to 0V pulsing waveform.
    signal
    > was at 40+ ms).
    nothing
    Bridge
    > and Stamp circuits.
    > Check it out at;
    > or
    > Kevin Gordon
    > programs
    > execute
    > 20
    > > -Dave
    > >> wrote:
    > >> Blah blah blah
    Here too. I have seven servos on my toddler-derivative. The processor can
    handle all seven servos concurrently at ten cycles per second. That's good
    enough for motion that is lightly resisted, but not for a servo under load
    like a driving leg or other limb.
    A 100 ms re-visit time is not fast enough for a servo under significant
    load, so I idle the three upper-body servos to get a faster real time loop
    for walking. Then I revisit the two lower-body servos under load twice for
    each time I visit the lightly loaded lower body servos. That gives me a
    smooth control of motion. I could increase the ratio of visits to the loaded
    vs unloaded servos and smooth things even more.
    It's a stock BS2 driving those four servos concurrently, not one of the
    faster models.
    Gary
